Question about Mitel Lands Phones
Problem with lev-9 busy . Cant found the code to release it.. Have a Mitel X50 system
Mitel 4025 voicemail never picks up
Before voice mail will answer, the phone has to be programmed to forward to the voice mail pilot number on a busy and no-answer condition. Example, if your voice mail system is on extn 555 then program the phone to roll over busy/no answer to ext 555. (there will need to be a companion mailbox on the voice mail system that matches your extension). Hope this helps.
Apr 08, 2014 | Mitel Superset 420 Corded Phone
Is there a way to block a specific phone number on Mitel Superset 4025?
Normally no. Your phone is part of a business telephone system. The system allows the sharing of incoming/outgoing telephone lines. If you need a specific phone number blocked, it will have to be blocked on these in/out lines. Unfortunately such lines are considered business class lines and you normally cannot block a specific number from calling you.
If you have trouble with a specific number, I believe you will have to contact the police before your carrier will be able to provide a block.
Apr 12, 2011 | Mitel Superset 4025 Corded Phone...
I need to change the time on my Mitel 5212 ip phone
The time on the phone is managed by the phone system. I suggest you contact the system administrator or system vendor.
The newer releases of the 3300 ICP, now known as MCD, can synchronize it's time. Older systems can't sync the time unless you have OPSMAN.
Nov 08, 2010 | Mitel 5212 IP Phone
Need Vizio TV code for my Samsung HT-X50 home theater remote!
Mine is 5. Press the TV button and let it go. When it quits glowing press the power button and hold it down. Then press a number (1-86) on the keypad while holding the power button down. If the TV turns off, you are done. Press the power button again and the tv should come on. If it does not work. Release the power button for a second and then repeat with a different number until the tv turns off.
Jul 05, 2009 | Samsung HT-Z310T Theater System
Contact support on mitel phone system
contact support on my telephone system
Jun 03, 2009 | Lands Phones
Mitel SX50 Equipment Busy Problem
Press "function", then 32. This will clear all alarms and error codes.
Apr 06, 2009 | Uniden 5.8GHz Cordless Phone
Y-JACK headsets with Mitel 5212 ip phone
You can find allot of headsets that will work by googling the set type and the word headset. But I think what you are looking for is found i the programming of your phone system. In the class of service you can have the option for silent monitoring turned on and in feature access code add a code for Monitoring. Yes you are correct this is something for your Mitel vendor complete but i'm sure they would be happy to help.
Jan 19, 2009 | Mitel 5212 IP Phone
Making the HT-X50 Region Free
Remove all discs from player.
2. Turn off the player
3. Unplug the power cord to the player
4. Wait 30 seconds, then reconnect the power cord.
5. Turn on player with the remote control. Wait until player LCD says 'No Disc'.
6. Press 'Enter' on remote control. (There will be No On-Screen Response.)
7. Press 8, 4, 2, 6, 9 on the remote control. (There will be No On-screen Response.)
8. Press Enter on the remote control. Player will power off.
9. Turn player on using remote control.
10. Open the tray.
11. Close the tray.
12. Turn player off then on.
13. Player is now Region Free
Dec 31, 2008 | Samsung HT-X50 System
Lands Phones Logo
Top Mitel Lands Phones Experts
Dustin
Dustin
David Payne
David Payne
Marvin
Marvin
Are you a Mitel Lands Phone Expert? Answer questions, earn points and help others
