Question about Frigidaire ATF6000ES Front Load Washer
My front loading washing machine by Frigidaire will not progress through the wash cycle. It gets stuck at each stage but will not spin at all. Any ideas on if this is fixable or not?
  • 10,319 Answers
Faulty timer mechanisum that will need to be replaced
Posted on Jul 15, 2010
  • csgerard Jul 15, 2010
    I spoke with one repair man who guessed that something needed to replaced and the cost of the part that would be $300. He did not come look at it because he said he couldn't justify coming out to look at it since it would be so expensive. The machine is 7 yrs old and he said it they are meant to last 6-8 yrs. So the issue is, do I pay $100 to have someone come look at it or buy a new one?
    I have searched the internet for "timing mechanism" to get an idea of how much it costs to repair this and I can't find anything. Does it go by a different name?
GLTF2940ES3 - Frigidaire Front load washing machine e59 error code
http://www.ehow.com/info_12127418_frigidaire-gltf2940fs1-not-spin-error-e59.html
May 02, 2014 | Frigidaire GLTF2940ES Front Load Washer
Spin cycle
sounds like a faulty timer unit.
Aug 26, 2013 | Frigidaire ATF6000ES Front Load Washer
Washer tumbler does not spin in final stage
hi sounds like the gearbox has slipped a cog and stuck that will cause the belt to burn
Nov 01, 2011 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire model # GLMV167OAS Makes a loud buzzing noise during the spin cycle. Completes the cycle but clothes are still sopping wet. What to do???????
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 22, 2011 | Frigidaire ATF6000ES Front Load Washer
Fridgidaire 7 cycle - older model top loading washing machine wont drain
could be a stuck gear box. motor trying to turn it on the reverse rotation for spinning. it could be the motor that hums. or the belt could just be loose.
inspect the belt and see if it is loose and adjust it if necessary.
tnx 4 using fixya,
drcool
Oct 17, 2008 | Frigidaire CWS3600AS Top Load Washer
Hoover 1300 washing machine
hi there this is a common fault you will need to replace the control module and selector switch/timer
Dec 01, 2007 | Hoover H130E Front Load Washer
Washer doesn't stop
select a hot wash of some kind and check if the water heats. if not, problem could be heater or associated stat
Mar 30, 2007 | Hotpoint WF430 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
65 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
