Question about Sanyo DS24425 24" TV
Vertical Tilt on Screen & Occational Blue Spot
When watching wide-screen movies there is a vertical tilt of the image. This is also evident when anything is written on the top or bottom of the screen because there is a tilt in the words and some of it is cut off.
How do I fix the vertical til of the image?
Also,once in a while there is a blurred blue/green spot on the upper left location on the TV screen...this only happens during black/white movies occationally and sometimes during a darker scene. What should I do?
Thanks!
  • 3 Answers
Firstly check the 1000micro farad near the ic vertical,u have to change it.
secondly for the blue green change the positor,if you dont know where it is!!!! it the near the degassing plug
Posted on May 06, 2008
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
Tip
How to Troubleshoot Vertical Lines on an LCD TV Screen
<p>There are two prevalent formats for video programming: full screen and wide screen. LCD TVs are designed to show a wide screen picture to go with high-definition (HD) programming. When standard-definition (SD) programming is watched on an LCD HDTV in its default settings mode, there will be two vertical lines on the right and left sides of the picture. You need to go into your TV settings menu to troubleshoot this issue.<br /> jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); <span><br /></span> <span>Instructions</span> <ol> <li> 1 Press the "Menu" button on your remote control and open the "Picture Settings" sub-menu.<br /> </li> <li> 2 Select "View" from the list of options.<br /> </li> <li> 3 Choose a viewing mode that will eliminate the vertical lines. Select "Zoom" to crop the on-screen image to fit the screen. Select "Wide/Widescreen" to stretch the on-screen image to fit the screen, or select "Panoramic/Panorama" to stretch the sides of the onscreen image to fit the screen (recommended).<br /> </li></ol>
on Dec 27, 2010 | Televison & Video
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
5 inch wide blue vertical stripe on lcd
It can be but rarely the main board, most of these sets have either one or two boards that drive the image on the screen, different names like T-con or Y out etc. the right side board could be the problem or a bad connector or ribbon cable for that side of the screen unit.
Several possible cures and none are a snap to find in most cases.
Dec 06, 2012 | Toshiba 46LX177 46 in. LCD HDTV
When watching movies on my computer, I am getting a weird line through the middle of the screen at times, also, when things are moving on screen faster, more lines seem to show. I guess they don't really...
i think your vertical IC ( if vertical lines are shown) / horizontal IC ( if horizontal lines are shown) of your monitor has damaged. you may contact a mechanic and change the corresponding IC
Sep 16, 2010 | CTL 261UW 26Inch Wide Screen LCD Monitor...
Having a big yellow spot background in the middle of the picture.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 09, 2010 | Hitachi 50VS69 50" Projection HDTV
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Single Blue vertical line appeared on the sanyo 42'' LCD screen
vertical ic fult or vertical section supplys missing
Jun 12, 2009 | Sanyo Televison & Video
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
IMAGE IS TILTED
theres a service bulliten out on this problem called"TVP0424" It explains about wide screen format problems and adjusting vert bow and hH trap adjustment. Good Luck
Apr 25, 2006 | Sony FD Trinitron WEGA KV-30HS510 30" TV
Sanyo DS24425 24" TV Logo
73 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
