Question about Fedders A&B Chassis A1A07W2B Air Conditioner
When a/c is on, it makes a humming rattling sound... but when the fan is on, there is no such sound.
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 04, 2010
LG fridge making loud noise
Bonjour,
jeepers are we talking about a wheeze, a clunk, a whirr, a buzz, a rattle, a hum, random modulated or cyclic, low or high frequency, persistent or intermittent? Or could you just be hearing fan noise.
If it sounds like tin pieces clinking against something metallic. The fan blades may be striking ice or frost or the shroud.
Could be a bad or worn fan motor bearing, or a defrost problem causing frost build up.
Just a FYI
Some LG models have been reported online as having many many operating issues.
Hope this helps
Jul 11, 2012 | LG Refrigerators
Microwave won't start but rattles when close door.
It is possible you have one or more door switches that are bad and need replacement.
May 05, 2012 | GE Microwave Ovens
Rear end rattle and clunking sound when put into gear
check unversal on drive shaft. put in neutral and shake drive shaft
Sep 14, 2017 | 1999 GMC Sierra
Fridgeair dishwasher not working making loud sound. water comes in and I can make it drain out but washer does not start
Hello
bearings in the heater fan may get worn out or rust. If this happens, it may become very noisy, either grinding on the bearings, or scraping against the rust. If this happens you need to replace the fan motor. Sometimes, a fan blade may come loose, and you need to replace it.
Sometimes it's the motor that makes the noise you hear. The motor has bearings in it which may become worn or get rusty. When the bearings get worn, they allow the shaft to wobble which can get quite loud. If there is a spin seal leak, water may get inside the motor, washing the bearing grease away. If the spin seal is leaking, you'll notice water leaking from under the dishwasher. There is also a disc attached to the top of the motor called a slinger. It sometimes breaks off and spins around the motor's shaft while it turns, causing some noises. You will need to replace the motor if the bearings are bad. You also need to replace the motor if the slinger is broken as well.
Newer dishwashers may make a squealing or rattling noise on the first run. This is because it has not had any water in it yet, and the motor seals are dry. You may hear this in a unit that hasn't been run in a week or more as well. You should operate the dishwasher regularly to keep the sump water from getting smelly, and to keep the seals lubricated. You can add a quart of water to the sump before running it.
Rattling noises may be produced by dishes rattling inside the dishwasher due to the water pressure from the sprayer arms on the dishes. To determine if the rattling is a loading issue, run the unit empty. If the sound is persistent, it may be that there is debris in the pump.
dishwasher water-inlet valves are noted to make a hum that lasts about 60-90 seconds several times during a washing cycle. This hum is a different hum than the sound of the motor running.
A rhythmic knocking or thumping sound may be caused the sprayer arms hitting something as they go around and around. Rearrange the dishes and resume the wash.
A clunking or clanking may be heard when the detergent cup opens; while a clicking sound may be produced by the timer or electronic control panel.
A solenoid makes a snap sound when it opens. This happens about six times during each load.
Pipes rattling or banging may be caused by a water hammer effect. Water hammer sounds are caused by a valve closing in the system, and yet the water in the pipe is still flowing because of its kinetic energy. The sound is caused by the water slamming into the closed section of pipe. A plumber can install an anti-hammer device.
Small objects can sometimes get stuck in the pump. When this occurs, you'll need to open the pump and then remove the item that is making the noise or replace the pump. The dishwasher pump is usually mounted directly to the motor and runs off the motor as well. The pump is also attached to the bottom of your dishwasher.
Send this page to your printer
Aug 06, 2011 | Dishwashers
I come home and water is on the floor due to my freezer not working. I think its a condenser problem; so I vaccum out my condenser coil and restart the condenser fan. But the condenser is still making an...
check that compressor is running. if your hearing a hum and then click you probably have a faulty compressor relay. most times you can pull it off and shake it and you will hear little bits rattle, well it should actually make no sound. but it could still be bad if compressor fails to run. compressor may or may not be warm.
Jan 21, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Convection oven making rattling sound.
It is most likeky that the fan bearing is worn and thus causing the rattling sound. You will probably need to replace the fan. Check first that there is no obstacle in the way of the fan rotating.
Replacement of the fan will require the back of the oven to be removed giving access to the fan unit, which will need to have the wires disconnected and the fan assembly unbolted. Fitting is the reverse.
Always remember to switch off the power before working on electrical equipment.
Jan 07, 2010 | GE Ovens
Fan Won't Spin
Is it humming like a stuck motor or rattling, like a loose fan. If it's rattling, the fan could eith be loose on the motor or, the center hub could have broken loose.
Aug 10, 2009 | Carrier 38CKC036 Air Conditioner
Fan making a rattling sound
check whether any wire is touching it or the blades touches the outer circumference in someway...
Sep 27, 2008 | Toshiba (P000247220) Fan Assembly
Fedders A&B Chassis A1A07W2B Air Conditioner Logo
63 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
