Question about Xantrex Technology XPower Powerstation Inverter
Will not charge. Sat for a long period dead.Can the cells be replaced? If so where can they be obtained?
    Scholar:
  • 142 Answers
If you can open the box, you should find inside a normal sealed lead-acid battery 12V/60Ah .
If you take its dimensions you can by any equal in size and Ah sealed battery, no matter of producer, but it should be kept charged, and if not used it should be set for charging every month.
Posted on Jul 19, 2010
Ezgo cart is fully charged but will go about 3 minutes then slows to a stop
How old are the batteries? Carefully check the fluid level of the batteries. Wear gloves and full face protection if possible as batteries are filled with corrosive acid and there is a chance of explosion. If the cart sat with dead batteries for a extended period of time without being charged the cells in the battery will harden up due to the low charge state making it hard for the battery acid to chemically react with the lead cells when you are trying to charge them. Try replacing the batteries and making sure all of your contacts are clean and are snugly secure.
Feb 11, 2017 | Cars & Trucks
Charging battery on Tablet which is totally dead
Depends on how long it sat for with no charge. LION batteries dont recharge from totally being dead if they are left discharged for long periods of time.
Jul 29, 2013 | Polaroid 7-in. Internet Tablet - Other
Car sat all winter and now it wont start
thaw the battery then charge it.
Make sure it is not frozen because it might explode.
Mar 14, 2013 | 2001 Chevrolet Impala
Tracfone LG410G (not yet activated) has been on charge for more than 12 hours and still says "please wait"...when unplugged goes dead.
Perhaps a hardware problem. But if your cellphone is new go to the store where you bought it and ask for replacement if its still covered by the warranty replacement period..If it is already not covered by the warranty replacement period but it was still covered by the free parts and service bring it to the nearest accredited service center and bring your receipt. Hope it will help you..
Jul 01, 2011 | Cell Phones
I have a 2000 BMW Z3 that has sat for about a year. I started it periodically and it always started right up. I went to start it one time and the battery was dead. I charged the battery and tried again....
I think that if the battery went completely flat the vehicle may have lost the security code, or the same can have happened if you did not follow the boost charge instructions when starting. If that has happened you'll need to have the unit re-encoded by a dealer. Keep in mind that starting a vehicle periodically is good but if you don't run it as well the battery will become exhausted and finally fail. The start up of any engine drains more power from the battery than any other operation. You need to start it and give it a run.
Regards Johngee10
Feb 08, 2011 | 2000 BMW Z3
Acer aspire one battery not charging to 100% despite prolonged periods of charging
You have one or more dead cells. What happens is after a long period of time, electrical "fingers" grow across the plates of the cells, caused by the chemical reactions within the cells, and short circuit each cell in time. Putting a high current for a very short period of time through the battery, can reform the dead cells, but not usually for long.
Fit a new battery.
Oct 31, 2010 | Acer Computers & Internet
Truck sat for 6 weeks battery went dead. Charged
If checking battery cables and wiring to the starter and ground points doesn't help. Have the battery checked for a bad cell. Preferably before you charge it.
Feb 16, 2010 | 2004 Ford F150
My ipaq rx5915 acts like its gonna load windows but stops
Well I would think so. batteries cause all sorts of headaches even when brand new, so I personally would get a new one, install it charge it up for required period as recommended, and see if that works.
Feb 03, 2010 | HP iPAQ rx5915
I plug it in and there is no power output. I opened it up and put a voltage meter on the internal batteries and they were nearly dead. Do they need to be replaced? Plugged in to recharge. Unit sat unused...
After batteries sit for an extended period of time they slowly discharge. Sometimes charging them for a day or two may help. Sometimes not. The chemical action inside the battery has been used up, and will no longer recharge.
My advice would be to replace the batteries.
Oct 31, 2009 | Furman SB-1000 Uninterruptible Power...
Xantrex Technology XPower Powerstation Inverter Logo
306 people viewed this question
Top Xantrex Technology Electronics - Others Experts
Jimmer_9
Level 1 Expert
richie46
Jay Plesset
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
