Youtube videos are free online for some cribs, but that model is not specifically shown in Google.com search. I only saw two manuals online for Simmons cribs but did not have your model number.
Several links show recalls, but unable to determine the age of your crib.
Simmons has received more than 800 reports of bracket hooks breaking. In one
case, a 6-month-old hit his chin on the side rail when the mattress dropped.
Simmons is offering a free repair kit, which includes replacement
brackets and instructions. The repair can be made easily in the home.
Most of the recalled Simmons cribs were made in 1998. Those sold at
Sears were made in 1998, 1999 and 2000. Only "98" cribs of all models are
recalled, except for Sears cribs. For Sears cribs (which are model numbers
025260 and 065060), the years "98" "99" and "00" are recalled because the
problem bracket hooks were used all three years. The brackets on all other
Simmons cribs except for Sears changed to different type attachments after 1998.
The cribs were sold under the name "Little Folks". Simmons and the two-digit
year of manufacture are written on a label affixed to the crib's headboard. The
year is the two-digit number following the model number. "Little Folks" is on
another label affixed to the headboard. The cribs are constructed of maple or
ash, and are painted or stained in more than a dozen different colors, including
natural, golden and white. "Simmons" is written on the top rail. Simmons will
help consumers identify if their crib is recalled.
Discount, mass
merchandise, juvenile product and department stores, including Sears, sold the
cribs nationwide from January 1998 through December 2000 for between $200 and
$600.
Consumers should stop using these recalled cribs immediately and
contact Simmons to receive free replacement brackets by overnight mail.
Consumers can contact Simmons anytime at (800) 421-2951 or at
www.simmonsjp.com/recall.cfm
Other than calling Simmons (good luck) your local hardware store should have
a selection of bolts that will work. Lowes is very good for this. Just take a headboard or
footboard, one siderail and size up the bolts you need. Most common are what are called
1/4 (quarter) 20 bolts. Pronounced Quarter Twenty as they are 1/4 inch wide with 20 threads
per inch. All you need is the right length and that will be between 2" and 4" depending.
Good luck, it's not hard to do. Go for it.
No, the Simmons recall affects cribs built in 1998, 1999, and 2000. The '02' after the Model number indicates yours was built in 2002. More information on the recall can be found: http://www.cpsc.gov/cpscpub/prerel/prhtml01/01087.html
www.simmonsjp.com
I believe there is a recall on this crib model.. you should check it out..can contact Simmons anytime at (800) 421-2951 or at www.simmonsjp.com/recall.cfm Simmons is offering a free repair kit, which includes replacement brackets and instructions. The repair can be made easily in the home.
Most of the recalled Simmons cribs were made in 1998. Those sold at Sears were made in 1998, 1999 and 2000. Only "98" cribs of all models are recalled, except for Sears cribs. For Sears cribs (which are model numbers 025260 and 065060), the years "98" "99" and "00" are recalled because the problem bracket hooks were used all three years.The brackets on all other Simmons cribs except for Sears changed to different type attachments after 1998. The cribs were sold under the name "Little Folks". Simmons and the two-digit year of manufacture are written on a label affixed to the crib's headboard. The year is the two-digit number following the model number. "Little Folks" is on another label affixed to the headboard. The cribs are constructed of maple or ash, and are painted or stained in more than a dozen different colors, including natural, golden and white. "Simmons" is written on the top rail. Simmons will help consumers identify if their crib is recalled.
http://www.simmonskids.com/ also you may want to call this number.. i believe your crib had a recall..
can contact Simmons anytime at (800) 421-2951 or at www.simmonsjp.com/recall.cfm Most of the recalled Simmons cribs were made in 1998. Those sold at Sears were made in 1998, 1999 and 2000. Only "98" cribs of all models are recalled, except for Sears cribs. For Sears cribs (which are model numbers 025260 and 065060), the years "98" "99" and "00" are recalled because the problem bracket hooks were used all three years.The brackets on all other Simmons cribs except for Sears changed to different type attachments after 1998. The cribs were sold under the name "Little Folks". Simmons and the two-digit year of manufacture are written on a label affixed to the crib's headboard. The year is the two-digit number following the model number. "Little Folks" is on another label affixed to the headboard. The cribs are constructed of maple or ash, and are painted or stained in more than a dozen different colors, including natural, golden and white. "Simmons" is written on the top rail. Simmons will help consumers identify if their crib is recalled.
This site has instructions for the cribs listed below.The 1st two listed seem to be generic cribs with a metal mattress support. It worked for my used crib. www.milliondollarbaby.com/help.milliondollarbaby.com/ *For cribs with snap-in spring hangers hooks & metal mattress support.w/ spring hanger hdware. *For cribs w/ bolt-in metal hdware for metal mattress supportw/ metal hdware. For cribs with Safety Glide nylon(rodless) hardware Sleigh Convertible 3001 Crib Sleigh Convertible 3091 Crib - Safety Glide Jenny Lind Crib Ashley/Alexandria Crib (1 piece headboard) +Day bed info. Ashley/Alexandria Crib (3-piece headboard) +Day bed info Lauren Crib) +Day bed info Emily Crib (One piece headboard)) +Day bed info Emily Crib (Four-piece headboard)) +Day bed info Mini Emily Crib Anastasia Crib Bridget Crib Valerie Crib) +Day bed info Bailey Crib ) +Day bed info Ellie Crib Day bed and full bed info Kalani Crib Day bed and full bed info Bordeaux Crib Day bed and full bed info Annabelle Mini Crib Italian Cribs-Metal Barrel Nut Italian Cribs-Nylon Nut Canopy cribs with snap-in spring hanger hardware Canopy cribs with metal bolt-in hardware
