Question about Whirlpool LXR6432JQ Top Load Washer
Missing balance ring clips on whirlpool washer model # LXR9445JQ0
Whirlpool washer model # LXR9445JQ0
The (8) balance ring clips have fallen off and gone through the pump causing it to seize up. I have removed 3 of the clips and the other 5 must have gone through and out the drain. I can't find them. Will it hurt to run my washing machine without the balance ring clips? It is still working, I have tried it without clothes in it and the pump works and the drum spins. It just makes a really loud noise when the drum stops spinning and the balance ring keeps going for a bit. I just need it to work for a bit until I can buy a new set. Thanks, Monica
    New Friend:
Just buy the clips, watch a video to remove the housing of the washer. it is a simple fix. should be below $20 to get the clips, j
http://www.partselect.com/PS874751-Whirlpool-3956205-Balance-Ring-Top-of-Inner-Tub-White.htm?SourceCode=1&SearchTerm=LXR7244JQ1&ModelNum=LXR7244JQ1#Instructions
Posted on Apr 14, 2013
2 Suggested Answers
SOURCE: drum seems out of balance, lots of noise even
Chances are you have a rear bearing either gone or on it's way,had the same problem with mine manufactured in Apr. 2000. I am getting a repair price but I think replacement is more lodgical
Posted on Aug 06, 2009
How do you remove the cover for Cabrio Platinum Top Load Washer to see if clothes have gotten stuck between wall & basket of washer. I can not wash one load without getting the UL Off Balance Code!
it is extremely unlikely that clothes have got to the position you mentioned
unbalance comes from
1--- clothes out of balance in the tub--too much on one side
2--machine not level on the floor --- rubber feet missing from adjuster bolts
3-- suspension rods and insulators for the tub broken or missing
these suspension rubbers/ plastics break on a regular basis and allow the tub to sit at an unlevel state causing an unbalance situation when spinning
top covers are either held in place with screws at the front and back ( under plastic trim buttons ) or simply clip on to the side walls at the top
talk with a service agent as to how to remove the top or download a workshop manual for the machine from the net
Oct 29, 2016 | Whirlpool WTW6400SW Cabrio Washer
Whirlpool top load washer is running across the floor. I've replaced all springs. I've also made it 100% level. What's the next step?
The following images identify an invention that most newer machines included, The ring about half filled with water automatically balances the basket of the washers. If the water has leaked out or the ring has failed the machine will not achieve balance. The ring is replaceable by qualified DIY.
Most units only have the ring on the top of the basket, but some as the bottom image shows have two.
Hope this helps?
Mar 29, 2016 | Whirlpool Washing Machines
Spins out of balance even emty
http://www.askmehelpdesk.com/plumbing/whirlpool-out-balance-spin-cycle-18991.html
http://fixitnow.com/sbrvrs/washers.htm
http://www.repairclinic.com/Washing-Machine-Troubleshooting
This model of washer does not have an out of balance cut off switch. If the load is not balanced properly the tub could hit the cabinet sides. If the unit spins evenly while empty & out of balance while loaded, I recommend checking & balancing the load. If the basket spins out of balance while empty, I recommend having the suspension springs & balance ring checked. Be sure not to wash light fabric with heavy fabric clothes. Also ensure that the adjustable feet are level, that's most important.
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
My Whirlpool front load washer is out of balance when spinning. It makes a loud noise. How do I get the tub back in balance? GHW9200LQ is the model.
Whirlpool front load washers have shock absorbers that helps them in moving the washer around the place. Due to regular usage of the washer it may tend to break.This will result in drum hammering sound . To clear this problem pull the bottom front off and check the shocks. Typically the rings where the pins go through are where they will break. You have to grab them and should have a complete check by moving them to see that whether they are broken.
Thank you !!
May 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water in the basket floatation rings.
after three years and multiple repairs i drilled holes in top and bottom float rings eg
balance rings and drained out the water, than resealed the holes and washer is working like new still junk but atleast it will spin out without unbalance code
May 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer is out of balance when spinning.
Your problem is probably much more than the washer being out of balance. The front load washers have shock absorbers that hold them from moving all over the place. These have a habit of breaking. Then the drum hammers and sounds like things are flying apart. Pull the bottom front off and check the shocks. Typically the rings where the pins go throuhg are where they will break. Sometimes at first they look okay and you have to grab them and move them to see that they are broken.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Nov 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Can you repair balance ring/tub unit on whirlpool direct drive washer or must you just buy a new tub? I think the fluid has leaked from the balance ring.
some units had balance held in place by clips those could be replaced separately those where balance slipped around outer edge of tub are not a separate part that can be ordered
Sep 17, 2008 | Whirlpool Washing Machines
Whirpool Washer, Loads become unbalaced in spin cycle.
it has a bad balance ring on the top of the basket no so hard but not that easy either
you have to remove the case to get to the balance ring
go to www.sears.com and go to parts and put in the full model number, under the parts tab in appliances and select view brakedown and it will explain it better with you seeing it
May 08, 2008 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool Washing Machine Balance Ring
this is now 2009 the machine you speak of is a piece of junk so by now its probably trashed you don't need my help
Nov 07, 2007 | Washing Machines
Whirlpool LXR6432JQ Top Load Washer Logo
164 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
