Question about Intertherm P3RA-036K Air Conditioner
Where is the compositor located at?
Where is the compositor located at on the outside unit?
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 04, 2010
I have a RUUD Model UGPH10EBRJR. the compositor near the blower motor in the ****** is bubbling out some kind of jell substance. Do I need to change it and do I call it hte run or start compositor. wh
Hi Jerry, yes, whenever you see either end of a capacitor bulging and or leaking fluid, the capacitor is bad and needs to be replaced. It may still be operating the motor ok, but it will eventually fail and the fluid is also highly corrosive. Simply match up the proper voltage and uf to get the proper replacement. Example: 5uf 370 volt or 7.5uf 370 volt or 10uf 440 volt. The uf stands for microfarads. Hope this helps!
Jan 17, 2015 | Ruud Heating & Cooling
Sta rite pro jet 3/4 hp seems to be frozen..turn on and it hums then quits ..no water pressure
it sounds like you have a bad starting compositor. If your compositor is a black plastic one look next to the spade connectors in the cap and you'll see a little resest hole with a brown stopper in it. If that stopper is black, burnt or leaking oil it is bad. If you have a metal one you can set it on it's base on a flat surface. If it rocks it is bad. If the compositor is good you may have a problem with the windings and either need to replace the motor or have it rebuilt.
http://www.austinpooolspecialist.com/
Jun 25, 2014 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Don't work
The compositor is probity bad. If you have a volt meter you can test the microfarad to see if its week. It will tell you on the ole one what it should read. The motor may need some oil on the bearings. Should be 2little caps on outside of motor where you put the oil. Last thing is to check the windings in the motor.
Feb 21, 2013 | Heating & Cooling
Forming a horizontal white line when I turn on the TV, if I give a gentle tap reset, that could be, thanks for your help
when you tap on a flat panel it might restore the unit to fully functional but it can make it worse,obviously the unit has a loose compositor that needs to be welded please take the unit into a authorize lg service center.
Apr 02, 2011 | Televison & Video
Can the outside unit in a split system be located higher than the
The outside unit is on the roof. If possible,get a ladder and get on top and you should see unit. To clean unit,remove screws on the sides, remove top cover.If coils are dirty, spray with a garden hose to clean.
Feb 23, 2010 | Dometic Rooftop RV Air Conditioner
I have a booster pump to increase the water pressure to my RO.The problem I have is that when I initially turn my pump on the motor hesitates to turn for around 3secs before it starts.Please could you help
you want to check and see if it has a unload er valve to the unit. also check the amp,s to the unit. example 12 amps to run 24 to start. check your starting compositor. good luck
Oct 13, 2009 | Plumbing
Blown capacitor on 4 year old ac hampton bay is
Not common, keep in mind compositor work almost like a fuse but restrict certain amount of voltage to flow through, power surge or unit overload from AC compressor kicking on and off can cause the resistor to fail; its parts of electronics working. My AC unit trip my main fuse box once in the great while, nothing surprises me when it come to electronics.
Jul 16, 2009 | Hampton Bay Heating & Cooling
Compressor fan and compressor not running new 2 yr old system puron
No power to outside unit. Check to see if contactor on outside unit is pulled in. Most AC units inside have float switch. When the drain stops up it shuts off outside unit. Located in overflow or underneath unit. No Problem Rusty
Jun 05, 2009 | Carrier 38CKC036 Air Conditioner
Outside unit not working
If the heating and cooling is working O.K. and maintaining the proper temperatures it is possible that your outside unit is in its off cycle. If the inside unit is running and the outside unit is not with an elevated temperature inside check the power supply to the outside unit. Most units have a disconnect located near them. Check the disconnect and make sure it is set to the on position. Listen for a hum noise at the outside unit which could indicate that the control power is being supplied to the contactor.
Jun 15, 2008 | Samsung AS18A6RB Air Conditioner
Intertherm P3RA-036K Air Conditioner Logo
247 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
