Question about Kenmore Refrigerators
Kenmort model 596.79272993 bottom-freezer. Freezer is working properly. refrigerator portion is not going to proper temp.
  • 4,070 Answers
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).Heavy buildup of ice indicates a defrost problem.
Posted on Jul 15, 2010
Kenmore side by side Refrigerator top portion is not getting cold. The freezer is working and the bottom portion of the refrigerator is cold but not the top portion of the refrig,
the refrigerator simply by transferring the cold air from freezer via circulation fan the temp controls tells the fan to circulate cold air until the thermostat is satisfied I would check to see if the fan is blowing on most models I have seen its located in the left rear wall closest to the freezer above the top shelf
May 02, 2012 | Kenmore Refrigerators
Model WBM412 - Freezer works but fridge does not cool at all.
Its due to freezing behind the freezer coil by which freezer fan gets logged to function. Defrost the refrigerator and then run. Keep freezer temp between -14*F and 8*F and fridge temp between 36*F and 46* F. And also check defrost cycling is properly working.
Thanks, helpful?
Feb 26, 2011 | Whirlpool WBC3525 (12.36 cu. ft.) Bottom...
No cold air
Look into the rear of the freezer and see if there is a frost line building up on the rear panel. If yes the begin by unplugging and manually defrosting the freezer. Im going to locate your service manual and send it to you. You are sure the MBF2254H is your model? Sea Breeze
Nov 15, 2009 | Maytag MBF2254H Bottom Freezer...
Jenn-Air Refrigerator side by side
make sure the two vents inside freezer and refridgerator nside are not blocked....normal range is approx -15 to + 15 in freezer,...and 37-42 in fridge...take temp readings inside of both....a full freezer and fridge retian colder temp more...
Jan 03, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Refrigerators Logo
101 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
