Question about Sony VAIO VGN-FE670G Notebook
Vaio notebook cloudy/hazy/streaking display following spill
Intermittent display (cloudy and hazy, streaking mouse pointer, occasional complete failure/blackout) issues on a Sony Vaio VGN-FE670G (m/n=PCG-7N2L). I should also mention that on several occasions after a coldstartup, display was 100% with deterioration after 30+ mins of use (hazing/cloudy streaking gets gradually worse but occurs so slowly it's difficult to notice until things are obscurred beyond recognition - and it never encompasses the entire display, only 50-75% at the most). Problems began after a keyboard coffee spill (notebook belongs to family member; I'm a tech/builder); owner neglected to immediately pull battery and AC power so the notebook was on for a few mins and then abruptly powered off on its own. Disassembled per Sony model-specific service manual, cleaned PCBs, components, case, keyboard, etc. Coffee contacted PSU and boiled off leaving deposits; motherboard contact (and I'm assuming a subsequent short) occurred which explains the sudden powerdown. Liquid contacted integrated WNIC and dvd-ram. However no apparent contact with GPU or any part of the adapter, nor did anything contact the LCD. All of the aforementioned items were cleaned with appropriate solvents and microfibers, etc. Had to literally scrape dried deposits off the mobo and psu so used a toothpick and q-tips for removal. Compressed air and overall secondary cleaning completed, dehumidifier treatment for several days, then reassembly. Everything worked perfectly until about 2 months afterwards and the display began its slow downhill journey. Question: Is this going to be a GPU/video adapter issue? Unit is an Intel 945M Chipset. Other specs: Intel C2D/Centrino, 2GB RAM, 100GB Fujitsu sata hdd, Intel wireless NIC (and ethernet), optical drive is dvd-ram (and works fine, amazingly enough). I am wondering if the LCD could have been damaged via mobo/gpu connection... or if this appears to be isolated to the gpu (which is replaceable). LCD damage = end of game. Thanks in advance!
    Top Expert:
  • Sony Master
  • 57,112 Answers
Nothing we can do for this problem. throw it away and get a new one
Posted on Feb 27, 2017
5 Suggested Answers
  • 238 Answers
SOURCE: Sony Vaio PCG-K86P laptop
hi, the problem seems with the RAM, remove and clean the contacts with an rubber/easer, this should fix ur problem,let me know
Posted on Dec 20, 2007
Sony GRZ610 is a piece of ****. It overheats itself due to poorly designed processor cooling. With time processor performance degrades.
Black screen is an indicator of some fault condition ( I am guessing overtemp. related). Removing power helps clear the fault code.
Removing all the power (battery and ac input) overnight will work usually. However, the processor maybe as good as dead.
Posted on Jul 04, 2008
Pyrhyc
  • 2028 Answers
SOURCE: computer crashed
This is an operating system failure. You can try a system repair or reload with your recovery or operating system disc. Start with the repair, then the reload, if necessary. However, I've found that about 7 out of 10 times in a case like this, the hard drive has crashed and needs replaced. If you have any issues during or after the repiar/reload then it's the hard drive.
Posted on Jul 18, 2008
EMKartha
  • 163 Answers
SOURCE: Sony VAIO VGN-FE770G only runs on AC power, battery not working
This looks like the system is not able to sustain itself on the battery power. I have a doubt here. Is it a new or an old laptop. Either Case we have to suspect the battery charging and battery condition. One another reason could be that the battery contact is not good. But this could be of the least chance as the manufacturing of such devices would be perfect in all standards. Lets check the battery power first.
A sony Vaio never operates if the battery is not detected or the battery is not charging, while the system is up and running, you can see a small picture of the battery in the system tray which is at the right bottom corner of the screen. Run your mouse over the same and you will find a tooltiptext message and you can see if the battery is charging or not. If not, your hardware has a problem. If its charging but the battery charge is not increasing, then you have a battery problem. If its a battery problem and that the system is under warranty, you can well get a replacement for free. Hope this resolves the issue. Good Luck.
Posted on Mar 14, 2010
Testimonial: "Thank you for your help - I really appreciate it! My computer is 3 years old, so I suspect the battery is defective. "
The cursor jumps around on my ASUS K501J notebook.
Step 1
1. Open Mouse by clicking the Start button, clicking Control Panel, clicking Hardware, and then clicking Mouse.
2. Click the Pointer Options tab, and then do any of the following:
To change the speed at which the mouse pointer moves, move the Select a pointer speed slider towards Slow or Fast.
• To make the pointer work more accurately when you're moving the mouse slowly, select the Enhance pointer precision check box.
To speed the process of selecting a choice when a dialog box appears, select the automatically move pointer to the default button in a dialog box check box.
To make the pointer easier to find when you move it, select the Display pointer trails check box, and then move the slider towards Short or Long to decrease or increase the length of the pointer trail.
To ensure that the pointer doesn't block your view of the text you're typing, select the Hide pointer while typing check box.
To find a misplaced pointer by pressing the CTRL key, select the Show location of pointer when I press the CTRL key check box.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Step 2
If you are using touchpad, try reducing the Touchpad sensitivity and check
1. Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers."
2. Select the "
Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop.
3. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "
Apply."
4. Pick the "
Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings."
5. Read the information provided in the next dialog box. It gives you options for tapping your
touchpad, using the buttons, scrolling, pointer motion and sensitivity.
6. Make any changes you want from the various topics. When you make a change, click "
Apply." Click "OK" when you finish making all your changes.
7. Do some work on your computer for a while, If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Step 3
If the issue persists try to perform a clean boot and check whether the issue is still persists.
Follow the steps mentioned in the article given below.
How to configure Windows Vista to start in a "clean boot":
http://support.microsoft.com/kb/929135
Note:Once the troubleshooting is over, reset the computer to start as usual.
Also I would suggest you to keep in touch with mouse manufacturer
Oct 08, 2012 | ASUS K50IJ Notebook
Is there a way to adjust the sony vaio vpc-f13ufx touchpad sensitivity?
go to control panel then mouse then pointer options and set the pointer speed slowed then it already is.
May 12, 2011 | Sony VAIO VPC-F13UFX/H 16.4-Inch...
My touchpad pointer jumps around, doesn't go where i want it to go, moves by itself, etc ... my os windows 7 home premium
for the meantime try using an external mouse to control your pointer. Go to Sony's website http://esupport.sony.com/ look for the model number of your Vaio and then download the driver for your touchpad.
You can also try adjusting the settings of your touchpad by going to the control panel make sure that it's in Large or Small Icons view instead of category. Look for the mouse and touchpad icon.
Apr 12, 2011 | Sony VAIO VPCEB42FX/BJ Notebook
Jumping cursor on windows7
change ur driver, update os, and install antivirus, download reginout intel partner may fix it
Sep 03, 2010 | Sony VAIO Notebook
My mouse pad is acting up and seems like it has a delay on it... Do I need to recadjust it?
Yeah, simply use this:
Control Panel - Search "Mouse" and click on Mouse.
Then click on Pointer options, and adjust the pointer speed slider to the speed you want. Also, verify that any accessibility options are off.
Jan 10, 2010 | Sony VAIO PCG-K23 Notebook
Black screen with mouse pointer after lcd screen repair
If you can see a mouse pointer clearly, you have a software issue especally if see a post..
Apr 20, 2009 | Dell Inspiron 1525 Notebook
Sony Vaio Laptop boots but no display except mouse pointer
It could be the hard drive going bad but it also could be a virus. I would formatt & do a clean OS install.
Dec 31, 2008 | Sony VAIO VGN-FS690P Notebook
Gray cloudy spot in center of photos;distorted light streaks
Time for another. Sell yours to a repairman in an ebay auction, keeping your accessories, and buy a working used on without accessories cheap.
Or this may be a good time to either buy another TZ3 refurb w/warranty(90 days I think) or a new one one Ebay. They are very reasonable since being replaced with the newer TZ5.
Oct 12, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Screen draging
here's my guess =)
maybe you have the mouse pointer option set to Display pointer trails? if this is the case... this is the solution.
  • go to control panel: START > SETTINGS > CONTROL PANEL
  • select mouse
  • go to Pointer Options
  • look for Visibility section
  • uncheck Display pointer trails
Jun 03, 2008 | Lenovo ThinkPad T61 Notebook
Sony VAIO VGN-FE670G Notebook Logo
182 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
