Question about GE Refrigerators
I have a hot point refrigerator it gets hot around the doors it is a side by side and about 3 years old
  • Betty Fox
    Betty Fox Jul 15, 2010
    we cleaned the frig like you said now what do we do?
  • Betty Fox
    can we replace it ourself's we are retired and on limited income. Can you walk us through it? where might we get this part? Do you have any idea how much it cost?
  • 2,926 Answers
Take off the back access panel where the compressor is, you will see a condenser fan, make sure thats turning and blowing lots of air when the compressor is on, if its not, then that is whats causing it to get very hot between the front doors.
You may find dust and dirt that has accumulated on the fan and surrounding areas. Unplug the frig and vacuum these areas and any other aresa that show a collection of dust. Be careful of the fan blades while vacuuming.
Posted on Jul 15, 2010
  • 1 more comment
  • Betty Fox
    we cleaned it as you said but the fan didn't come on when we pluged it back up.
  • GetMeOttaHere Jul 15, 2010
    You will need to replace the condenser motor fan assembly. The motor should run at the same time the compressor is running and will turn off when the compressor is off.
    I'm not sure if you are able to perform this repair to be honest. It does involve electrical expertise with some mechanical skills. It is not real hard, but I can't speak for you with all due respect of course.
    A model number will be needed, and with the model number, you can than order the fan assembly. There are places online that sell them, as well as a local Appliance parts center in your area.
Freezing refrigerator
Seal around the door should be "warm" not "hot" in my opinion... Only purpose for the electric heat in door seal is to evaporate moisture that will condense on the otherwise cold surface of the door seal causing drippage or if door seal on freezer to prevent frost buildup. In design of unit no reason that engineers would want or need to have this seal 'hot" because a mild temperature say 50 F would be adequate to do the job. Perhaps some physical damage to the electric wire in this circuit causing a short and more current to flow making it heat up???
Maybe not a baffle problem at all...... To me the baffle is such a simple device it would be hard to imagine how it would get screwed up. The one on my old Norge is almost 50 years old.... [ Yeah, I know, I waste probably twice the KWH that you guys do.... but my wife insists on keeping this old coppertone fridge and I keep rep[airing it over the years.]
Mar 17, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Frig is very hot on the outside ban that meets the seal
That heat that you feel is part of the design of all refrigerators. Those heaters are there to keep water from condensing on the outside of the cabinet around the freezer door. Just like water condenses on a cup of Ice water. It will do the same on a refrigerator. If those small heaters were not there. The water would cause the paint to rust badly. There are various arrangements of heaters used on Freezers and refrigerators around the doors. Particularly the Freezer door.
As long as the fridge is cooling properly it is fine.
If the fridge fails to get cold, the outside of the cabinet will actually get quite hot.
Hope this helps,
Best, Mark
Dec 28, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer is warm at top and cold on the bottom.
Sounds as tho your evap fan is not running. Open door to freezer and should hear a fan running smoothly. If not most of the time the problems is with the main control board on back of refrigerator.
Jan 27, 2010 | GE Profile PSW26P Stainless Steel Side by...
I have a 6 yr old Suberba. The center post between fridg & freezer is HOT and has been for several days. Any ideas?
That is normal and you may have just noticed that it gets warm or a little hot there. It is a heat strip placed behind the metal around your door to prevent moisture from forming around the door seal. If it was not there water would appear around the door on a daily basis, Thank You Sea Breeze
Aug 17, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Both Freezer door and cooling door and a metal strip were hot
That is a good thing. you want that to happen what it does is it avoids condensation to form around the doors
Apr 26, 2009 | Samsung RS2630SH Side by Side Refrigerator
Center partition wall of refrigerator is hot !
Sounds like your condenser fan isn't working...Take the back cover off to see if there's anything stuck in the fan blades. Usually when the fan stops, the compressor & tubing that runs between the doors get really hot. You may also want to clean your condenser coils.
Feb 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Outside freezer hot and seals
Fridge has either mullion heaters around door or most likely steel pipes just inside the skin of the perimeter of the door, this is to stop ice or condensation forming around the door seals, mainly the freezer, they are part of the condenser circuit ( hot part of the refrigeration system).
It is normal for these to get hot, but in your case may be hotter than usual because of the constant running, the running may be caused by hot ambient temperatures, system being slightly short of refrigerant, faulty thermostat or in-efficient compressor.
I suggest if temp is ok inside fridge dont worry too much, if you notice fridge starts loosing its capacity to refrigerate, have a refrigeration tech look at it.
Nov 13, 2008 | Maytag MSD2756G Side by Side Refrigerator
Hot mtal beam between doors
you have a condenser fan mtr that has failed
Jun 01, 2008 | Whirlpool Refrigerators
Warm to Hot molding that seals the doors
The heat in door frame is normal but undetectable when ref at normal temp. Definitely cooling problem. Google ref not cold enough to get help to solve problem. Never use any oil for it will not help also health problem if not approved to be used around food. Fan motor must be replaced for it will just keep stopping.
Mar 31, 2017 | Kenmore 52642 / 52644 / 52649 Side by Side...
Something is burning on the freezer side of samsung side by side freezer
it is normal to the fridge to be hot of the side edge panel it is to prevent moisture around gasket. cluster pipe of condeser routed around instead to install elec. heater. its to hot from the start of applying power but once it reach lower temp it will be warmed and normal.
Jan 11, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
20 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
