Question about Westinghouse 24 in. MDP531 RF Free-standing Dishwasher
My Westinghouse dishwasher SB907/915/925 is not heating water.
I am told it could either be the heater or powerboard,although they have never found the heaters to fail - just the powerboards. How do I get hold of a cheap powerboard as I have been quoted $175.00 and this is prohibitive?
I have had the same problem. I removed the heater element and checked the resistance with my multimeter and got the reading of 26.4Ohms which sees ok. I then removed the printed circuit board and found that a joint on the back had burnt out. I have resoldered this joitn and all seems fine now.
My Westinghouse dishwasher SB907/915/925 is not he - 10_30_2011_8_59_11_am.jpg
Posted on Oct 30, 2011
    Genius:
  • 1,075 Answers
You dont tell me your problem???????.any way,type in the name of the machine and serial to your internet and it will soon come up or type in [cpc board].adrian,,,,,
Posted on Jul 15, 2010
I have a Westinghouse WGRTNG199 tankless water heater. It will stop heating water and show code 42 on the screen when someone uses one specific shower in my house. This is the closest bathroom to the...
There is an outstanding chance that the shower causing the problem has a required flow restrictor installed in it. If you take the shower head off and look in the connection are you should see a colored screen or similar plastic piece. Take it out. The water heater has to have a flow of at least 1/2 gallon per minute.
Dec 22, 2017 | Water Water Heaters
Hi, my westinghouse wsf6605xr dishwasher is not drying dishes. Any ideas?
The heating element may be burned out, pull it out and test it for continuity of the coil.
Feb 23, 2017 | Westinghouse Dishwashers
Dishwasher not heating water already replaced in line heater element no change
Hello
Possible causes;
Incoming Water; Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat;The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan; The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon
Sep 07, 2011 | Westinghouse Dishwashers
No heatinh - Westinghouse SB925SJ*00 - suspect dual water sensor (Water presence and temperature). Require price and availability. Thanks.
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 30, 2010 | Westinghouse Dishwashers
Westinghouse SB915 wont heat up water
found the 2 large lugs mounted on the circuit board had been hot and had dry solder joint's removed solder cleaned with sand paper then re soldered and tested it now heats up .
Jul 26, 2009 | Westinghouse Dishwashers
LG Dishwasher LD-2050WH with HE error code
This is a heater error. The cause is either a bad heating element or bad thermistor (the thermistor is part of the heater assembly). The heater assembly will need to be replaced.
Jan 14, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Westinghouse dishwasher virtuoso SB 925 not heating the water and not drying the dishes , still workig thou. Would it be expensive to repair?
I also had this problem of the water not heating up but the washer still did its thing. what i found was the problem, is the soldered joints on the circut board were cracked (dry joints) around the relay area, i just resoldered them and hay presto its all good
Aug 20, 2008 | Dishwashers
Dishwasher not emptying
No solution as yet, will most likely replace the dishwasher.
May 31, 2008 | Westinghouse 24 in. MDB421 RF Built-in...
Dishwashers Logo
1,085 people viewed this question
Top Westinghouse Dishwashers Experts
JonSnell Electronic
JonSnell Electronic
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
