Question about Sony Playstation 3 (PS3) Console
Won't do game updates always times out
When I go to play a game and it says it needs an update I click ok sometimes it will make it to 7% finished and other times it won't make it past a black screen. My nat type is 3. And I am connected to the Internet evrything says it works but it won't
    Problem Solver:
  • 8 Answers
If you have an Internet connection that is slow or intermittent is can slow or stop the uploading updates.
Even with a fast connection it is a slow process so patience is essential. It can take 1 hour with a SONY BRAVIA TV.
Suggest you check your Internet connection, then if it is OK and still will not update or upload properly, call out your Internet provider engineer to check it properly.
Posted on Jul 15, 2010
Vizio vbr210 error 11000404 How do I update firmware to watch newer blu ray movies?
I had the same problem -- we even returned the disc and got a new one. Go to the Vizio site and download the firmware for your player. Put it on a USB stick and plug it into the player. Follow the onscreen instructions (basically just press OK). The entire process takes less than 5 minutes from download to finish.
The Hunger Games works perfectly now.
Aug 21, 2012 | Vizio VBR210 Blu-Ray Player
Hey! so i recentley remembered the game Hype: the time quest in the back of my head and i brought back the cd from 1999 and tried to install it on my new windows 7 64 bit computer. it was a failed...
64-bit versions of Windows can't run the CD installer due to it being a 16-bit application. Trying to run the installer in Windows 7 x64 will cause the process to freeze in the background and require the task manager to close. One workaround is to install the game on a 32-bit copy of Windows and transfer the installed game to a 64-bit computer. A virtual machine will also work such as VirtualBox if you don't have another computer available. When installing the game select 'Full Installation'. The game installs to three locations:
  • Your specified install path. The default is C:\Ubi Soft\Hype - The Time Quest . This is where the game data is stored and the two executables for Direct3D and Glide mode.
  • C:\Windows\Ubisoft . This has an application called SetupUbi that shortcuts point to to play the game, various *.dlls, and Ubi.ini, the settings file for the game.
  • The registry key location is HKLM\Software\Ubi Soft\Hype - The Time Quest . Only a version string is stored here.
Copy the game data folder to your 64-bit windows and place the Ubi.ini folder into a C:\Windows\Ubisoft folder. The other files in the Ubisoft folder are not needed to play the game and SetupUbi has the same problem as the installer on the CD. The registry key is also not required to play the game.
The executables to play the game are MaiD3Dvr_bleu and MaiDFXvr_bleu for Direct3D and Glide mod respectively. Neither will work with default settings in Windows 7 x64. Set the compatibility mode for the executables to 'Windows 2000' to get the game to run without immediately failing. To change the game settings run 'UbiAssistant' as an administrator or edit the Ubi.ini file in the C:\Windows\Ubisoft folder. There is a patch available at Ubi.com labeled 'Voodoo 3 and Direct3D'. It is uncertain if this is required but is recommended to install. The patch is ~4.01 MB if the Ubi.com link goes down and a replacement download needs to be found.
The Direct3D mode will suffer serious graphical glitches that render the game unplayable by the end of the intro. There is no available fix for it. nGlide is a Glide wrapper available at Zeus Sooftware which does support Hype - The Time Quest. Download and install it and then download the patch for the game. The patch is in the compatibility list at the bottom of the nGlide download link and then search for the entry for Hype - The Time Quest. The patch says to turn videos off but this is not a required step but it is recommended. The game will still play with videos but besides the Ubisoft logo video at the start of the game there are only two others at the start and end of the game and playing the video may cause future issues. Turn it on when you start and finish the game but turn videos off at all other times.
Run MaiDFXvr_bleu.exe to use the glide wrapper, remember to set compatibility mode to Windows 2000, and Hype - The Time Quest should run on Windows 7 x64!
Jul 06, 2011 | Ubi Soft Entertainment Hype: The Time...
Every time I try to play my xbox 360 console says I need an update to play the game.What is the update and where do I get it?
If you have xbox live and you are connected to the internet your xbox will prompt you to update your game/console. At this point you have to be connected to the internet. At this prompt it should give you the option to download and install the update. Choose this option and it will start automatically and finish in time. DO NOT TURN YOUR XBOX OFF. Once this is done you should be able to play the game and your console/game will be updated.
Jun 13, 2011 | Microsoft Xbox 360 Console
Bejeweled 3 loads.But it won't play. I Have windows 7 64bit. Bejeweled 2 no problems.
judging by the operating system you are running this shudn't be a problem but sometimes windows 7 has compatability issues. make sure that java is fully updated. you can check this by going on the website and downloading the latest java software.
if the game icon is on your desktop them right click and select troubleshoot compatibility and if that dont work right click and select run as administrator.
hope this helps
Jun 11, 2011 | Computers & Internet
I cant conect to internet
Once you have all the wireless settings of the router, you are ready to connect the WII to the wireless network.
Nintendo WII
Go to Wii Options in the lower left. Click on Wii Settings to the right. From this first list, click the right arrow. Now on page 2, click on Internet. Then click Connection Settings. From this list, click Connection 1. Then, click Wireless Connection...
and then click Search for an Access Point.
It will briefly search for any access points and when this screen comes up, click OK.
The following will be a list of nearby access points. If the one you are looking for doesn't show up, click Try again. Then, click the one you have access to...
When the following screen appears, click OK...
and OK again.
It will test the connection...
And if successful, the following will drop down. Click Yes to update Wii.
Sometimes the above screen is false, saying there is an update when there isn't and the following will appear...
Now, back in Wii System Settings, click on WiiConnect24.
From the following list click WiiConnect24.
Click On and then Confirm to save your settings. This feature allows for updates to be seemlessly sent to your Wii so you don't have to do the final step every time.
Ok, the final step, just as a way to make sure your Wii is up to date. Click the right arrow from the 2nd page of Wii System Settings.
Click Wii System Update...
click yes...
it will test your connection for a few seconds...
an update screen may quickly come up and tell you there is an update (whether or not your Wii actually needs one)
and the following screen will appear. Click Wii Menu to finish.
Trouble connecting to the internet on X-box ,Play station or WII ?
You can try to reduce the MTU settings on the router. if the MTU on the router is set to 1500 then change the MTU to 1365. Also you will need to open the ports on the router.
For WII port numbers are - 28910, 29900, 29901, 29920, 80, 443.
Click Here to know How to open the Ports on the router.
Jan 23, 2011 | Nintendo Wii Console
GAME WONT PLAY, GET ERROR MESSAGE
update quick time, Java, and if you have windows vista or windows 7 and the game is for windows xp then right click on the game (if you can't access the game then right click on a shortcut and click find target) and click compatibility mode windows xp, also see if your graphics card is compatible with the game.
Feb 11, 2010 | Video Game Consoles & Games
My internet explorer broswer doesnt work but my mozilla firefox broswer works? Cannot connect to database and lag spikes on my computer
if you update the system recentely you must accept and add to the webside.
1.- click on TOOLS
2.- click INTERNET OPTIONS
3.- click SECURITY
4.-click TRUSTED SITES
5.- click SITES
6.- click ADD
7.- click CLOUSE
8.-click ok
Then refresh the page, thats it.
Your rating is very important to me
Was this helpful?
May 29, 2009 | YouTube Videos
Interactive internet play on the wii
and OK again.
click yes...
Mar 19, 2009 | Video Game Consoles & Games
Prism3d Engine has stopped workimg
prism3d engine - as in the trucking games engine ?!?!
if so check u;re directX. try to reinstall it ... Or u;re video card drivers !
Aug 08, 2008 | Computers & Internet
Sony Playstation 3 (PS3) Console Logo
43 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
