Question about Whirlpool 24 in. GU3200XTP Built-in Dishwasher
Dishwasher will not start. Clean light flashes. Time display shows --. Manual states "The diswasher has malfunctioned". (Obviously) "Call for service to check heater circuit". Will replacing the circuit board solve the problem?
  • BLO Jul 15, 2010
    To add to the thread.....Lights seem to be working correctly now. Machine fills with water. Water level rises just to the bottom of the heating element. Switches to the next cycle and does nothing...just continues counting down the minutes. If I push cancel/drain it drains it out. Are there two pumps...one to pump the drain water and another to pump it through the spray arms. I have cleaned everything out to ensure it is not clogged. WHAT NEXT?????
  • BLO Jul 15, 2010
    Thanks.....It is working. Running it with a cup of vinegar for a good cleaning....D/W is just a few months outside of the 5 year warranty so thankful it was fixable.
  • Whirlpool Master
  • 2,605 Answers
Hello, welcome to FixYa.
I understand how vague those manuals can be, very frustrating.
In regards to the fault, while the control can be an issue and ultimately require replacement...that is a worst case scenario and certainly not the "starting line".
Typically this fault is prompted due to poor water circulation, which in turn allows the heater to get too hot, ( water circulationg keeps it from overheating under normal conditions ).
The place to start is to pull the pump filter, spray arm and check for food deposit, broken glass, undesolved detergent and general water deposit built up in the sump well.
The key is to get in there and clean it all out, I`ve attached a link at the bottom that will show you how to go about it. It is not really referring to the heating issue, or maybe even your model, ( Most Whirlpool, Inglis, Kenmore, Kitchen-Aid, Jenn-Air ) but it is the same procedure.
It is also possible the heating element is faulty, but I would focus on this solution first and go from there.
When you`re finished, shut you power of to the dishwasher for several minutes and that should clear the error code. Run it through a test cycle and see how it goes.
Let me know how you make out and what you find.
macmarkus :)
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
Posted on Jul 15, 2010
  • 2 more comments
  • BLO Jul 15, 2010
    Think I have narrowed it down to the wash pump. Is there a way to test that pump?
  • Mark MacDonald
    Mark MacDonald Jul 15, 2010
    Hello, there is indeed two pumps. one for washing ( circulation motor ) and one for draining ( drain motor ).
    Based on what you`re describing the wash motor is either seized ( no good ) a wire harness came loose ( check underneath, it plugs directly into the motor towards the back ) or something is jamming it inside.
    I would suspect the pump is seized based on my experience with these machines. That is quite a job and best left to an appliance pro.
    At the cost it may not even be worth while, pump & motor assembly available at "repairclininc.com" for approx. $165.00 part # 1548519...but you`ll have to decide that based on the condition of the rest of the unit, it`s age and so on.
    Pump & motor looks like this...
    Let me know what you find or if I can assist you further. Good luck.
    macmarkus :)
  • BLO Jul 15, 2010
    Thanks for the utube link. I took everything apart again...their was a little rock lodged under the garbage disposal wheel. Reassembled it and it is working.....yeah... Thanks for your help. Brenda
  • Mark MacDonald
    Awesome Brenda ! I love happy endings, thabk you for accepting my help. We here at FixYa can only be as good as those receiving the info we relay...you received it awesome !
    macmarkus :)
  • 5,911 Answers
The blinking clean light is an interruption in the dishwasher program that usually indicates a component problem or program malfunction. If a component is defective, it's commonlly attributed to the heating cycle or a thermostat failure. To rule out component failure, or program error, the following link explains how you may be able to clear (or reset) the blinking clean light problem and possibly avoid a service call:
http://www.fixya.com/support/r3575752-dishwasher_blinking_clean_light
Keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
In many cases, I found this to be a momentary glitch in operation. If the problem keeps reoccuring the number of flashes is an indication of WHICH circuit is causing your problem. As all dishwashers differ in operation and features, refer to your tech sheet for the recommended troubleshooting steps.
NOTE: Some dishwashers use the Sani-Rinse/Air Dry combination, some use the Sani-Rinse/Heated Dry combination. Some use a sequence of three, others use a sequence of 5 pushes of the buttons. If the tech sheet is not located behind the lower toe panel, it should be affixed somewhere under the dishwasher. I have also found them located inside the inner door panel. Please post back and let me know if you still need assistance.
  • BLO Jul 15, 2010
    Thanks. The Normal Wash/Heated Dry sequence brought it through the Diagnostic mode.
    The tried Starting a normal cycle. Displayis working...no blinking lights...Time Remaining starts at 60 and counts down. D/W fills, heating element gets hot...... and that is all she wrote. Just stays in the mode. Can cancel and it drains out..... Suggestions ???
    Appreciate your help.
    Brenda
We started the dishwasher and it started. during the cycle, the soap dispensor didnt open and now it flashes clean. I've tried to cancel sequence, it goes through the draining process but when I go to...
Many diswashers do not remember settings after total power failure, so I would disconnect the appliance from the mains for a few minutes to see whether the problem clears. If the dishwasher is sophisticated enough to remember settings, it will also probably allow you either to continue, or start a new cycle, in which case, choosing start a new cycle should correct whatever programming loop the machine got into during that minor malfunction.
Dec 27, 2017 | Sunbeam Dishwashers
Whirlpool dishwasher model number GU3600XTSY2 is flashing: The clean light is flashing! It's not the heater circuit either. It says the dishwasher is malfunctioned. Call for service to check heater...
The clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again
Mar 17, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Diswasher malfunction - won't start clean light flashes 7 times The clean light keeps flashing green. Can't get the washer to start. The only operation it will do, is drain when the cancel / Drain button...
This information may help in your situation. This can be a common problem on some Whirlpool manufactured dishwashers. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now, keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Nov 10, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
The dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Apr 14, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
Clean light keep on flashing
The solution is...press cancel one time and you will see the red light, press another time and the red light will disapear, after press one time on heated dry and after press one time on normal wash after press start and it's suppose to work. For me it was the solution, I hope it will be the same for you.
Apr 05, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
The digital display is showing S2
try switching off the power for a short time it might reset itself
Jan 01, 2009 | Kuppersbusch K 24 in. IGVS 669.1 Built-in...
Flashing Power Failure Light on Frigidaire Diswasher Model # FD989GFC2
I have a Frigidaire that does the same thing. I was able to push the start cancel button then select a cycle and press the start button, shut the door and presto it worked.
Oct 17, 2008 | Frigidaire 24 in. GLD2162RDC Stainless...
Help for my asko diswasher
Unplug the washer for ten minutes, see if this clears the problem.
Aug 28, 2008 | Asko 24 in. D3350 Dishwasher
665.17019401 - Kenmore diswasher
It indicates a water temp problem. If water temp doesn't rise at a certain rate, by the heater, it goes into this error. Probably a problem with heater or wires to it.
Nov 22, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Bosch
f is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
Apr 01, 2006 | Bosch 24 in. SHU6802UC / SHU6806UC...
Whirlpool 24 in. GU3200XTP Built-in Dishwasher Logo
97 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
