Question about 2wire Wireless-G 802.11g ADSL Gateway
I have moved to new home. I am using 2wire wifi
I have moved to a new home. I am using 2wire wifi modem for the last 2 years. Now in this new house my 2wire modem is not working. It just get solid green light on power only after getting 3 other green light for few seconds. When I connect other ADSL modem (Non wifi), it works. Message comes on computer is ''network cable unplugged''. I called the my service provider and they say that modem is faulty. This can't be true as I tried with another brand new 2wire gateway modem but result was same.
  • 2,632 Answers
You can check if the ethercable is loose or if you have a spare ethernet cable (rj45) you can replace the one that youre using
Posted on Jul 20, 2010
I have my computers and laptop networked through my 2wire Home Portal 1000SW modem and am trying to connect my Coby Kyros MID8024 Tablet through wifi. The tablet finds my 2wire network but seems not to...
1st make sure that your using the proper WEP key (Wireless Password) 2nd make sure that their wirelessly compatible SW is a wireless b compatible to eliminate this issue you may also disable your WEP
majority of new technology uses wireless G and N
this wireless modem is a little bit outdated:
Data Link ProtocolEthernet , IEEE 802.11b , HomePNA 2.0 , HomePNA 1.0 , USB
see for your tablets protocol if this would match:
Aug 28, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
I have a 2wire 397 modem router from att in line ,i want to add another 2wire modem router in line to a different room to hook up a samsung 3d blu ray to go on the internet
you cannot have 2 modem routers on the same line, if your current modem router has wifi, you might consider using a wifi repeater that will pick up the signal elsewhere and give you added lan ports. alternatively, you could just run a lan lead to where your samsung is and use a 5 port lan switch.
Apr 26, 2011 | 2wire (2701HG-B) Wireless Router
Hi, I have a 2Wire 270 DSl Modem I had bought through Qwest since they are my ISP. My home is a 1500 Sft Ranch, if the modem is in the bedroom and the Mac Book is in the family room down the hall the...
If the walls in your house are made of lathe and plaster or concrete block, then the performance of WiFi through all the walls in your house will be very bad. The signal that you are receiving from your neighbor's modem is probably only going through two walls (the outside wall of their house and the outside wall of your house), while the signal from your modem is probably going through at least 4 or 5 walls.
I suggest that you do not buy a new modem, but buy a wireless access point, a spool of CAT6 cable and two Leviton RJ45 wall jacks. Run the CAT6 cable from the modem to your bedroom, install the Leviton RJ45 jacks on both ends of the cable, and then connect the wireless access point to the the jack in the bedroom and the modem to the jack near to it.
This will expand the wireless coverage in your house and allow you to buy much better wireless device than QWest would ever sell to you.
Here is a suggestion for Wireless Access Point.
You can buy the CAT6 cable and Leviton RJ45 jacks at Home Depot or Lowes.
Dec 30, 2010 | Computers & Internet
I have an AT&&T 2701HG-B Gateway 2Wire wireless router w/DSL modem. My Mac G5 computer is attached with an ethernet cable (my computer does not have wireless capability). All this is in my home...
there is an adaptor that you can buy
it is plugged into the power socket for the house , connected to the ether net connection
you have a second plug in connection that plugs into any other power point and that runs a ethernet cable to the pc or modem
I have such a system running from the shed computer to the house computer and modem distance of 100 yards
it is called a TP-Link and is available fro Jaycar or like electronic shops
it works by using the house wiring to transmit the data signal along with the house power
Mar 23, 2017 | 2wire (1000-400108-001) Router
2wire Home Portal 1800HW
This 2-Wire Home Portal is a DSL modem. It can be used by itself as a wireless modem. It cannot be hooked up to an existing modem.
Go to this link and download the user manual:
http://www.dsldepot.com/download.asp?fileid=96
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
May 05, 2009 | 2wire HomePortal® 1800HW Router...
How to monitor all traffic from PCs on ADSL wifi 2701hgv-w modem
to monitor all traffic from all computers your computer would have to run the internet connection(modem) and you would have to connect your router to that. that way all traffic would pass through your monitoring computer with watever software you use to do this. Pritty sure this is the case.
Feb 25, 2009 | 2wire (1000-000057-000) Modem
My 2wire router will not connect to my nintendo ds wifi system.
The DSi only works with WEP encryption. The 2Wire and most other newer routers use WPA encryption.
Simply logon to your router with a web browser. The default IP for it is 10.1.1.138 but it might be different, just check the manual or internet for the IP. Go to "Home Network" then "Advanced Settings" and change the security from WPA to WEP and save.
Thats it!
Hope that helps.
Nov 18, 2008 | 2wire (1000-000057-000) Modem
DSL connection
Wow, that router is at least 4 years old. I have not seen a working 2wire 1000hw for about 2 years. I would purchase an aftermarket modem at best buy or off of ebay if you want to go cheap. I have worked for ATT for about 10 years. Hope this helps
Aug 07, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Wireless router
I think 2wire routers are good in providing signal strength. Contact the 2wire vendor regarding your requirements.
take care
May 01, 2008 | AT&T High Speed DSL Modem
Can a 1800HG gateway in my garage/workshop link *wirelessly* to my 2wire 2700 HG-B wifi AP internet in the house?
try going onto http://192.168.1.254/xslt?PAGE=J30&THISPAGE=J29&NEXTPAGE=J30 on the computer connected to the 1800hg and set the router onto bridge mode (deselect enable routing). You might be able to set the two routers to connect then from here: http://192.168.1.254/xslt?PAGE=J09&THISPAGE=J30&NEXTPAGE=J09 or somewhere else in the MDC, not sure if it will work as I haven't tried it, but I hope it helps.
Feb 19, 2008 | 2wire 1800HG Router (RG1800HG00)
Open Questions:
See all 2wire Wireless-G 802.11g ADSL Gateway Questions
2wire Wireless-G 802.11g ADSL Gateway Logo
175 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
