Question about LG LDC22720ST Stainless Steel Bottom Freezer French Door Refrigerator
I just bought an LG LDC22720ST Stainless Steel Bottom Freezer and want to add a water filter to the ice maker.... I don't know where to get the right water filter or what the right water filter is.
SOURCE: water pooling and freezing inside bottom freezer
I had the same problem with my LRFC25750 and have finally figured out what's happening! The water that is pooling and freezing on the bottom of the freezer is definitely coming from the defrost cycle. It is pooling inside the freezer compartment because the drain inside the back of the freezer intended to carry the defrost water down to the external evaporator tray underneath is blocked with ice. As a result, the defrost water from the coils overflows the collector under the coils and runs down the inside back of the freezer, pools on the bottom, and re-freezes when the cycle is over. this continues until there's so much ice on the bottom that the water from next defrost cycle runs out on the floor. The "easy" solution is to unplug the unit and let it completely melt out (this could take 24-36 hours). I couldn't wait, so I removed the freezer drawers and their tracks and pulled out the back panel inside the freezer -- saw the ice in the collector and blocking the drain and I melted it away with hot water and verified that water could now flow down to the external evaporator tray. Unless you want to do this, I'd say give it a good 24-36 hours for all the ice to melt away. I think it all started when we left the freezer door ajar for a whole day and probably had a lot of frost build-up on the coils. The next defrost cycle was not enough to clear all the frost and things began to build up from there. Once the drain is frozen, though, you're finished -- the defrost heater doesn;t reach down that far and you have to melt it down completely or it will continue to leak forever. I've heard that you can get a drain heater to ensure that the drain never freezes over or at least so that it is sure to clear with each defrost cycle. I'll post an update if I locate one.
Posted on Sep 03, 2007
  • 400 Answers
SOURCE: Bottom Freezer has ice built up
Possibly the defrost element is faulty, this is located behind a cover in the back of the freezer compartment and is attached to the fins of the evaporator. It also has a defrost limit thermostat which could also be the problem. I presume that the fan is working after you have defrosted the unit?
Posted on Mar 05, 2009
david04928
  • 102 Answers
SOURCE: Build up of ice on bottom of LG fridge freezer
Is it supposed to be self defrost? If so then either underneath the freezer needs to be cleaned. coils if dirty will cause freezer not to work well. I that doesn't help you might have a freon leak which would make it under charged and would ice up like that.
Posted on Mar 15, 2009
  • 36 Answers
SOURCE: Ice Maker Hookup for LG side by side with freezer
ok...1st there is only one connection to the fridge at the valve.2nd check the filter and see if one is present.3rd make shure the child lock out feature on the dispencer is not activated.
Posted on Aug 08, 2009
  • 161 Answers
SOURCE: our freezer bottom gets filled with ice
You have a drain that is freezing up. Pull the cover off the bottom back inside the freezer and bend the heat element down closer to the aliminum drain tray. It is too far away to heat the aliminum trat. The element is black and it is below the evaporator coil which has fins on it.
Posted on Jan 22, 2010
Ice maker water won't shut off when you turn on ice maker.
Check for a sticking water solenoid on the ice maker line.
Sep 04, 2015 | LG LDC22720ST Stainless Steel Bottom...
LG Model lfx28978sw french door freezer door hard to open
its likely you have frost inside your tracks. best option for you is to defrost the freezer and let the ice inside the tracks thaw. then after the ice thaws the tracks should work better. If that dosen't help you may need new tracks for the freezer door
Aug 03, 2013 | LG LDC22720ST Stainless Steel Bottom...
Water dispenser very slow
Check the filter and replace if necessary.
Oct 26, 2012 | LG LMX25981ST Four-Door French Door...
My LG refrigerator model LDC22720ST just stopped working.No lights..no power....plugged it to a different outlet and still it did not work.
Somewhere in the back there should be a removable plate which covers the computer that makes this unit work. I have a feeling that you will find something burnt on the "solder side" of the board.
May 09, 2011 | LG LDC22720ST Stainless Steel Bottom...
The ice maker is not making ice, it makes the first set of ice but keeps it there and it doesnt make anymore,what can nit be?
1 keep the shut arm down position
2 check the water filter , water filter replace every 10 m
if water filter ok. check water valve
good lock
Jan 12, 2011 | LG LFX21960 Stainless Steel Bottom Freezer...
Have a LG model lfc25760 that our subdivisions water was off for 12 hrs 2 days later the ice maker quit ,any ideas
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 26, 2010 | LG Panorama 20.7 Cu. Ft. Side-by-Side...
Ice maker not working no water but the water in door disp.works
heatman101
lkj;fds
Nov 02, 2009 | LG LMX25981ST Stainless Steel Bottom...
Limited amount of ice
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...thumbs up
Aug 17, 2009 | LG LMX25981ST Stainless Steel Bottom...
No ice
IPour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 12, 2009 | LG LFX25960ST Stainless Steel French Door...
Fridgew/ice maker. ice tastes like sulfer.
This sound like you need a water filter change to the refrigerator.
Aug 05, 2009 | LG LFC20760ST Stainless Steel Bottom...
LG LDC22720ST Stainless Steel Bottom Freezer French Door Refrigerator Logo
151 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
