Question about Maytag Performa PAV2200
Dryer will not heat up and constantly running
  • Maytag Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
Dryer gets too hot in any cycle setting, even air only
If this machine is an electric dryer you probably have a short in your heating element causing constant heat when ever machine is running. Replace heating element.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gary_58e9c3508cafe590
Aug 05, 2013 | Dryers
Does Not Shut Off
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Apr 21, 2012 | Roper Dryers
My whirlpool LGR5636LQO gas dryer does not heat up and runs constantly.
heatman101
Oct 15, 2010 | LG DLE5932W Electric Dryer
My maytag atlantis dryer will constantly run without heat. Also when you open the dryer door the light does not come on. Any ideas of what the issue is?
IF IT RUNS WITHOUT HEAT ALL THE TIME, YOU NEED TO CHECK THE THERMAL FUSE OR IGNITOR. IF IT'S GET WARM SOMETIMES AND TAKES A LONG TIME TO DRY YOUR CLOTHES, CHECK YOUR VENT TO THE OUTSIDE, RADIANT SENSOR, AND COILS
Jan 24, 2010 | Dryers
Amana gas dryer ALG331RAW timer does not work and no heat
HI, the timer is defective. the heating process can be affected if the timer isn't functioning correctly. replace this failed timer asap. this will fix the issue.
Jun 19, 2009 | Amana ALG331RAW Gas Dryer
Runs but does not heat
Sounds like the timer may have failed if the dryer continues to run for hours and hours. And this may be what keeps the heating elemnts from coming on.
Reply your findings and I can help you more.
Jan 18, 2009 | Whirlpool LER5636P Electric Dryer
Electric dryer - drum turns but no heat
If it has a conventional electro/mechaniacal timer, then the timer is faulty, as it should advance, unless of course it has a time delay function, if it has, make sure it is off.
This probably explains why it is not heating.
Plz rate this solution.Thanks.
Dec 26, 2008 | Dryers
Dryer doesn't heat and runs constantly
depending on the model; if the timer is in the automatic cycle it will not advance if there is no heat, it must heat in order to satisfy a thermostat to tell the timer to advance this is what makes it automatic. If the timer gets to the end of the timed cycle and will not advance to off, sounds like a bad resistor connected to the timer, I would first check the heat circuit to find out why its not heating. Dont mean to complicate, but everything in the dryer has something to do with heating, element,thermostats, temp switch, timer and even the motor. Check for burnt wires at the terminal block for the cord. hope this helps.....
Nov 19, 2008 | Dryers
Kenmore dryer heating coils stay on when dryer is off
That's no good....hopefully your house is still standing. Your coil is shorted to ground, so there is constantly 120v being applied to the heating element. It won't get as hot as when running, but because there is no airflow it poses a serious fire hazard.
Jan 10, 2008 | Kenmore 659 Electric Dryer
Washing Machines Logo
52 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
