Question about Sony Alpha DSLR-A100 Digital Camera
Sony alpha dslr 100 error code
My camera will focus but when I puch the button for the shot I get a camera error code = 0x56. The only way I have found to clear this error code is to cut the camera off and back on but then it repeats the error when I try to take a shot
  • nzabi audrey Apr 28, 2008
    a chaque fois que je veux prendre une photo le message CAMERA ERROR CODE=0x56 s'affiche . NB: je suis en afrique ( CONGO BRAZZAVILLE )
  • Anonymous Jul 03, 2008
    What a piece of garbage this camera. I thought I fixed the problem after hours of searching the internet and finding out that 0x56 error is related to red eye reduction. I changed the setting, it worked for a while, and then same problem again. Updating the firmware did nothing. Sony claims this is not a problem I hope some one would do a Youtube demo so every see the problem with the Sony Alpha 100 and Alpha 700 cameras.
SOURCE: Sony DSLR-A100, error code 0x5b
Same here. My camera gives me the same error code unless I shoot with the largest aperture/smallest F-number.
Posted on Aug 30, 2008
  • 218 Answers
SOURCE: LOSS OF INSTRUCTION MANUAL FOR SONY DSLR ALPHA 100
Here's a link to the Sony website where you can download the manual.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSLRA100&LOC=3
Posted on Nov 17, 2008
yvonmagic
  • 82 Answers
SOURCE: I can't format any memory card (CF) with my Sony Alpha 100
you have a lock on your memory card check that !!
Posted on Jan 03, 2009
  • 9 Answers
SOURCE: Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.]
Best regards - Michael
Posted on Feb 16, 2009
Obertelli
  • 3006 Answers
SOURCE: MY BUILT-IN FLASH NO LONGER WORKS WITH MY SONY ALPHA 300 DSLR
In that case it's broken and is not a DIY fix. Usually it's either the flash tube or flash charging circuitry/capacitor, and they're the sort of things which can just fail suddenly.
Your camera will still be under the manufacturer's one year worldwide warranty, so contact Sony in your country to find out what the local arrangements are.
You'll need to provide proof of the purchase date, if you cannot do so then the repair will be chargeable; Sony have a fixed fee policy for dSLR repairs and if you're in the UK then it's currently £114.56.
Note that if you're in the UK then you additionally have Sale of Goods Act protection for up to six years (five in Scotland). The Act states thaty goods must be of durable quality with respect to the price paid and intended use. Clearly the camera should not fail within such a short space of time so you may be able to return the camera and demand a refund from the retailer. Enforcing your rights is sometimes a different story altogether, but note that if you accept a repair from the retailer then you future rights to reject the goods are severely reduced.
One further VITAL point: if there is even the slightest evidence of any unauthorised repair attempts, all your consumer rights vanish.
On balance, I'd strongly recommend that you either return the camera for exchange/refund or return it to Sony under warranty.
Hope that this helps, all that I ask in return is for you to take a moment to rate my answer.
Posted on Feb 03, 2010
How can I use timer on sony alpha 33
Using the timer should be fairly straightforward once you read instructions on doing it from the user manual:
Sony DSLR A200 manual
Apr 20, 2014 | Sony Alpha DSLR-A200 Digital Camera
Sony a200 Flash pops up then flashes as if its shorting and I am unable to take any photos.
Are you shooting in low light? Sometimes the flash will fire multiple short bursts to aid in focusing. If the camera is not in focus, then depending upon your setting it will not fire.
Oct 31, 2012 | Sony Alpha DSLR-A200 Digital Camera
Sony Alpha DSLR-A100 lens got wet and now it does not focus. Will buying new lens solve the problem?
If the lens was the only area to get wet then yes replacing it should resolve the issue.
May 27, 2012 | Sony Alpha DSLR-A100 Digital Camera
Mi camara da herror de las Naciones Unidas Herror code = 0x59
On my Sony Alpha 100 I keep getting this error 0x59 when I press the shutter button. It takes the picture but I have to turn the camera off and then back on to use it again
Oct 23, 2010 | Sony Alpha DSLR-A100 Digital Camera
The lens kit of my Sony DSLR A200 produces noise
If it's in continuous auto-focus and doing it, then it is just not locking on to one thing and jumping back and forth between two objects that are very close together in distance and it is normal. It should stop in manual, single shot or single point auto-focus. Sony uses Nikon auto-focus technology and my D-300 with a 70-200mmf2.8 will do it if I turn the auto-focus tracking time(lock-on) all the way down with the auto-focus in full auto.
Sep 29, 2009 | Sony Alpha DSLR-A200K Digital Camera
Error 0X5b
Такая же фигня. Фотал нормально. Отключил автофокус, потому что фотал летящих птиц. Две фотки сделал и на третьей выскочила ошибка Camera errop code 0x58 . Выключение и вытаскивание аккумулятора не помогло. Вкл/выкл. автофокуса тоже. Не знаю, что делать. Завтра понесу в сервисный центр сдавать. :( Грустно.
Aug 08, 2008 | Sony Alpha DSLR-A100 Digital Camera
LCD - Focus
DSLR camera was not made to be used as a point and shoot camera and you cant preview the shot before taking a picture. You are to use the eye piece to focus right. Also before taking a picture, push the exposure button just a little to let the camera focus right.
Jul 04, 2008 | Sony Alpha DSLR-A100 Digital Camera
Quantaray 7500 flash
You will need a minolta pct-100, the will allow your flash to work with your Sony A-100
May 22, 2008 | Sony Alpha DSLR-A100 Digital Camera
Sony Alpha 100 won't acknowledge memory card
I would suggest that you give the camera to Sony service to have a look at it. The regular shop would not have the proper test facilities to properly diagnose any in depth problems with this type of camera unless they were an authorized contracted service rep. The problem may be involved.
Jerry G.
Feb 23, 2008 | Sony Alpha DSLR-A100 Digital Camera
Sony Alpha DSLR-A100 Digital Camera Logo
572 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
