Question about Western Digital My Book Essential 1TB External USB 2.0 Hard Drive
External Hard Drive not working
My Wester Digital 1TB External Hard Drive, is not being recognized by my desk top computer. When I open (My Computer) the icon for the HD is not showing up. Although it is plugged into the USB Port, and the power supply is connected, and it appears to be on. I have tried to trouble shoot with the windows Hardware help. This process says my hard drive is working properly
  • 6,831 Answers
Body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
Cant see my passport external drive on new windows 8 laptop
Try unplugging from usb and plugging it back in. Also, you may need a SAS driver for your computer to recognize the drive. Some drives have internal encryption and require a driver before the computer recognizes them. Check the Mfg website to see whether this drive requires one.
Jan 03, 2014 | Western Digital 1TB My Passport Essential...
Western digital 1TB notebook essentials, cat knocked it off of desk, now I canot access it, my computer doesn't recognize that it is there. you can hear it start up and spin but then it goes to a...
When it hit the floor it either knocked the reader arms loose or damaged them in someway or possibly damaged the Plates inside the drive. Unfortunately, in most cases it will cost more to repair the drive than it will to replace it. There are some companies out there that can recover the information from the drive platters but they are expensive and normally geared to big business.
Aug 22, 2011 | Western Digital My Book Essential 1TB...
My drive is not being recognised and im not sure why up in till this point it has worked fine? It is a WD Essential Model - Wdbaaf0010hbk - 1TB drive it has alot of valuble information that i would hate to...
when your external drive does not appear in "my computer" or not recognized in windows vista or windows 7, then just right click on my computer, click on manage, the go to disk management. Find your external drive there and right click on it, then select assign new drive letter. Select a letter from the midlle of the alphabet like m, then enter. The icon of your external drive should appear inside my computer
Oct 03, 2010 | Western Digital My Book Essential 1TB...
Toshiba 1tb external HDD that works fine on TV not on PC anymore
Try using it on another computer. If it doesn't work the drive may be bad.
Mar 14, 2010 | Western Digital My Book Essential Edition...
Wester digital external is on computer not reading it
Is the drive operating normally except for the lights not working correctly?
Nov 22, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
I am having a problem with my seagate freeagaent Desk 1tb ext hdd
Sounds like the Partition table has become corrupt.
Try some of the free tools from here:
http://www.freedownloadmanager.org/downloads/rescue_ntfs_partition_software/
Hopefully one of them will be able to repair the partition table on the drive and allow rescue. If not download a trial of Ontrack Easyrecovery Professional and run a scan firstly for damaged NTFS/FAT volumes and if that fails perform a RAW recovery of the filetypes you require.
Jul 23, 2009 | Computers & Internet
Will not open
try to install the cd that comes with the hard drive. Vista was installing generic drivers that might not work with your drive.
Feb 10, 2009 | Western Digital My Book Essential 1TB...
Computer does not recognize new 1TB ext HD
First I had to reseat one of the drives which had worked loose and become unseated during shipping. Then I had to format the hard drive and finally I had a 1TB external hard drive I could use. The light is still red.
Jul 31, 2008 | Cavalry Storage Cavalry CADB001U32 1TB...
Western Digital My Book Essential 1TB External USB 2.0 Hard Drive Logo
153 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
