Question about HP Pavilion dv6000z Notebook
How can I buck-up my computer?I tried in many ways but all of them had no results
    Problem Solver:
  • 7 Answers
Another ridiculous "solution" from Mr. mmdoh. Ignore the troll.
Posted on Feb 16, 2013
    Sergeant:
  • 180 Answers
Be sure to feed power supply for the device!
Posted on Jul 15, 2010
  • muhammad mamdoh
    muhammad mamdoh May 07, 2013
    I apologize for this disregard of the problem and this follow-up. In the event that the computer does not want to respond and take off from the initially operation of the switch only Remove the battery from the device first make sure that the charger connected to the device and works well and you can through tested by Afumitr or use charger last. whether the charger works did not take off the device to be in front of a malfunction in the device.
Buck stove 27000 fan runs on low but when goes to high will shut down moved temp gage to front and rewired with harness won't fun on manual either.
Buck Stove ' Hearth.com Forums Home
www.hearth.com/talk/threads/buck-stove.45094/
Jan 6, 2010 - I replaced the blower motor. immediately blower would run for... ... Buck Stove 26000 insert (1982, in the living room fireplace) Has kept ... I throught the same thing so I fired the stove really hot, motor would not run past low setting and ..... I have a pre-1979 Regular Buck 27000 where the thermal disks are ... Anyone burn an insert without the surround?
Jan 8, 2012
Insert Blowers - to use or not?
Jan 3, 2011
Buck Stove Fan Noise
Dec 27, 2010
Any HVAC Techs or Electric Motor Gurus Here?
Nov 22, 2010
More results from www.hearth.com
Nov 08, 2015 | Cars & Trucks
Penn foster exam answers
The Call of the Wild.
Aug 01, 2014 | Clothing
Why does my echo 230 weedeater not throttle up
This is usually a result of the diaphram in the card being too dry to open and close properly fromt the vacum of the engine. I have replaced just the diaphram for around 12 bucks or replaced the whole carb from Ebay etc around 30 to 50 bucks.
Jul 12, 2014 | Echo Garden
2000 chev truck runs ruff
Run the scanner and computer test in order to get better result and exaclty diagnostic. Othewise you must waste your time and money.
God bless you
Jul 24, 2012 | 2000 Chevrolet Silverado
My 1997 Honda Civic failed it's Emissions Test. See below the ASM Emission Test Results. What do you suggest I do to get the car to pass the smog test? ASM Emission Test Results: 15mph - RPM = 1587...
Jose, I don't know if this will give you the answer you are looking for because there are many things to consider here. The exhaust gas recirculation valve (EGR) is one of the main things involved in reducing NO emissions. This valve is controled by the power control module. (PCM) This is your vehicles computer. The PCM monitors the vehicles speed and will command the EGR to open when the vehicle attains a certain speed, which is why the ASM test being done is recorded at two different speeds. At 25 MPH your vehicle failed the hydrocarbon (HC) emissions limit and this could be for a number of reasons. When is the last time you car was tuned up? Old spark plugs, wires, clogged air filters, oxygen sensors, leaking injectors (personal experience) or the PCV valve could be contributing to the results of the test. I guess that the easiest way to go is to tune up the engine replacing the spark plugs, wires, air filter and the PCV valve and don't forget to have the oil changed at the same time. Only then should have the vehicle retested and see what the results are. Should it fail again you may have to consider having the EGR or the catalytic converter replaced depending on what portion of the test fails. If the NO fails I would consider the EGR. If the HC fails then I would consider the catalytic converter. Good luck with this.
Apr 05, 2011 | 1997 Honda Civic
My iPod has been frozen for about 10 hours, wityh ...
send a letter to apple be very polite about the problem they will give you another ipod and 10 bucks
May 19, 2010 | Apple Ipod Nano Second Gen. Green (4 GB)...
After the dishes are supposed to be clean I find a film on everything. the dishwasher does not seem to get things clean. I have tried different settings with no results. Any ideas what could be wrong model...
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Mar 08, 2010 | Frigidaire FDB1502RG Built-in Dishwasher
Shut-off while compting. Now it won't power up.I have green light on the power adapter but no green lights on the computer.
that sounds like total power failure. likely a diode or rectifier on the motherboard has blown out, and does not allow the charger to charge the machine or power it. You can take it to a shop where they will try another power adapter. If that works, you are in luck, because a universal power adapter is usually not more than 50 bucks. You might also be able to get a used power adapter for that unit online for about 25 - 40 bucks. If however, the computer shop cannot get it powered up, you are better off replacing that unit. the c640 was fine in its day, but now there are d600's for 250 bucks online, and they are way better. You can also get one (not exactly NEW) off the dell outlet site Outlet.Dell.Com. They have lots of refurbished and "used as a display" computers that work just fine, and come with all the same guarantees as a new one off the line.
Oct 26, 2009 | Dell Latitude C640 Notebook
Monitor will sometimes show graphics, other times will say no signal found or be totally black. I've tried 2 different monitors, and same problem with both.
Either way, it appears as though whatever video hardware you are using is on it's way out, due to your having tried two different monitors with the same results.
If you are using the onboard video, take a jaunt to your local computer parts store and spend a few bucks on a PCI-Express video card. If you're even remotely handy with a screwdriver it's a ten minute install process, and will save you the expense of having a tech do it for you.
By the same token, if you are already using a third-party vid card, remove and replace it.
Oct 08, 2009 | Gateway GT4016 Desktop PC
HP Pavilion dv6000z Notebook Logo
29 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
