Question about Philips Magnavox 42MF521D/37 Television
Picture Size My 20" Magnavox flat screen tv has to be set on special sizes to fill the whole screen. When it is set on normal, the picture covers less than 75% of the screen. Is there an adjustment that can change this situation. The people look fatter when I set it on the optional picture sizes.
    Guru:
  • 352 Answers
Keep in mind that not all programs and show are in widescreen format. When set to normal, you will get those black bars on the sides because the program is sized for the older TV's. Some TV's will have a zoom option, but that will cut off some of the top and the bottom of your picture.
Until everything goes widescreen, you are stuck in normal with those black bars or widescreen with the fat people.
I hate distortion in my TV image, so I am perfectly fine with my TV on normal.
Good luck.
Posted on Jul 14, 2010
How do we get shows (programs) to cover the whole screen on our tv
You can access either through the TV's remote, or the cable box remote picture settings for choosing picture size (i.e., normal, wide, stretch, wide zoom, etc.).
Oct 20, 2014 | Televison & Video
How do I fix this picture to fill my screen on a 16.9 setting
depending on source you may not be able to , it will depend on what your source is ,IE cable , over the air tv , you can go into settings and change the screen size by zooming in , but that will make less of the show (movie ) seen on the set .
Oct 03, 2014 | Samsung Televison & Video
Make the picture fill the screen
The TV will produce a picture that is set by the aspect ratio of the film. You can however expand to an unatural size to fill the whole screen.
THE PICTURE IS WAY TOO LARGE. THE PEOPLE ON THE SCREEN FILL UP THE WHOLE SCREEN. IT USED TO LOOK NORMAL SIZE & ON CHOPPED WE USED TO BE ABLE TO WATCH ALL 4 CHEFS COOKING. NOW ALL WE SEE IS ONE CHE
Ad? Turn off "store" or "display" mode in menu. Look for picture size or "aspect" in menu. Remote should have button for "Size" or something.
Feb 12, 2014 | Vizio Televison & Video
LG 55ln5700 picture does not fill screen
Go to picture/video settings and make sure your screen size is set for 16:9 or wide screen ratio.............
If you have dish or cable go into menu settings and check and make sure the same is true
Sometimes on the remote there is a picture size/mode button you can press to change the screen size
Normal or Wide would be widescreen
Stretch is zoomed picture that fills the screen
Letterbox is the square box screen
It sounds like a picture setting problem to me
I would try those things first
Jul 09, 2013 | Televison & Video
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
Picture won't change sizes
If you are using a cable box, the settings you want are in the setting menu under "format" or "display" . Typically the choices are Normal or stretch, Select stretch.
The "small picture is how the old NTSC format displays in "normal mode" on a High definition set.
While you are in the settings menu, you might want to verify that the box is set to output at least 720P if not 1080i.
www.mcveyelectronics.com
Apr 07, 2009 | Toshiba 42HL167 42 in. LCD Television
Cannot fill screen with normal picture size setting
assuming you all have comcast and using an hdmi cable
first access menu (hit it twice) and go to set picture format, choose passthrough....or in your case auto hdmi
then turn box off, press guide and info on the front of the box, proceed through the setup, advanced is more in depth..lol...
select 1080, 720, and then either the standard or widescreen 480s to your liking.....
voila....
now check your tv settings to accommodate
Nov 17, 2007 | Sony BRAVIA KDL-40V3000 Television
Display appearing stretched
the original image size was probably recorded in 4:3 aspect ratio...meaning your widescreen is a 16:9 ratio size screen and is stretching it outwards to fill the whole screen. If you want the image to look normal.. ie. not short and fat people.... you need to change the picture size in the settings from widescreen 16:9 to normal 4:3 tv in the settings menu most likely...Also most remotes will/should have a button for that.
Oct 26, 2007 | ViewSonic VA1912wb 19" LCD Monitor
Philips Magnavox 42MF521D/37 Television Logo
920 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
