Question about RCA L40FHD41 40. in HDTV
Hi i turn the tv on and looks good but the mode don t change or the volume, channels nothing either with the control or at the tv. thanks
techman
  • 3130 Answers
SOURCE: Non Responsive 35" RCA
You are going to have to check all of the small tact switches behind the push buttons in the front of the TV set. In the past, someone may have cleaned the picture tube and the liquid dripped down onto the switches and corroded them, or one is stuck closed or the remote sensor is bad. The best way to test this would be to replace the entire switch panel in the front of the TV set. Good Luck
Posted on Aug 19, 2007
yambo
  • 230 Answers
SOURCE: RCA P52927 sound is static
Need adjust coil sound ( little metal beside Big IC or between tuner and IC). Turn a little right and left ( be sure leave same position) don't play with this coil too much, will mess up video signal , some times tuner need be re solder. I hope this will help you Thank you!!!
Posted on Aug 13, 2008
  • 317 Answers
SOURCE: Ghosts?
re- program...................................................
Posted on Aug 14, 2008
SOURCE: TV keeps changing channels
Out of 30 years in the repair field, I have seen this problem maybe 4 times. Once was a stuck button on the keypad of the tv. The other time was a second remote control with a book sitting on it and it would turn the tv on and off when someone would move something on the coffee table, another time was a bad solder connections on the microprocessor on the keypad circuit board and the last time was from a humorous neighbor in an apartment complex who thought he was funny who had an all in one remote control programmed for his neighbor's tv set.
Posted on Oct 03, 2008
likha
  • 790 Answers
SOURCE: television turns on and off, turns up volume and changes channels
Hi
Replace all tact switches at the control panel... all switches is have bad resistance thats why your system is abnormal!
Thanks!
Posted on Feb 25, 2009
I have a panasonic th42px60u my problem is that none of the controls work except the on and off volume is on but unable to increase or decrease the volume. What part do I need to buy to fix the problem,...
Good day Mr.Daniel Navarro..
The picture below is the sample 42" plasma TV (internal parts)..
If your TV won't adjust volume or change channel by pressing button on the front panel..The problem could be the digital control board,it is the one that have a rectangular red on the image shown..
But before you replace the board make it sure that the control button assembly is properly connected on the said digital control board ( no loose connection or loose solder)..
Also try this remedy:
If you have remote control you can use it for the mean time to adjust the volume and channel so that you don't need to replace the digital control board..
Hope it helps..
Thanks for using fixya and purchased my service..Please don't forget to rate my answer..
Nov 23, 2011 | Panasonic Televison & Video
Mitsubishi TV Channel Tuning/Remote Problems
To restore full functionality to your set you must replace the remote that came with set. Universals only control the most basic of functions.
Apr 27, 2017 | Televison & Video
I'm looking for the manual for a Mitsubishi VCR HSU447 with the remote control RM75502 so I can program my TV to it. Thanks
1.- Turn off your TV
2.- On the remote control, set the VCR/TV slide switch to TV position.
3.- While holding in SP/EP button, press the code button listed below that corresponds to the brand of your TV
4.- Press TV POWER on the remote control. Once your TV has turned on, your remote is set up to operate your brand
TV.
Brand of TV Brand Code Button
Mitsubishi 1,2,3
Fisher 0
G.E. VOLUME UP
Goldstar 2,9
Hitachi 8
JVC MUTE
Magnavox 4
NEC 2,9
Panasonic CHANNEL UP, CHANNEL DOWN
Pioneer 6
Philips 4
Proscan VOLUME UP
Quasar CHANNEL DOWN
RCA VOLUME UP
Sanyo 0
Sharp 3,5
Sony VOLUME DOWN
Toshiba 7
Zenith INPUT
I finnaly found my VCR Manual, and I'm glad to share this info with you, because I was looking for the manual all
over the web and FOUND NOTHING!. Bye!
Mar 15, 2009 | Mitsubishi Televison & Video
Television turns on and off, turns up volume and changes channels
Hi
Thanks!
Feb 24, 2009 | RCA 27V520T 27" TV
How to get TV/video mode without remote
some tv do that changing the channels.
in the control panels in the tv where r the buttons for change channel there must be video button, push it and there you go.
Good Luck
Jan 12, 2009 | Toshiba 14AF44 14" TV
"snow" screen, full volume, remotes don"t work
good day
due to the long time the buttons were not used, they tend to get stuck and this causes channels eighter to stay in one station or continou scanning. it could be resolved by spraying WD40 on the buttons and press it many times then dry it before operating the unit.
chris
Mar 25, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Wharfedale LCD3210AF Television- Digital problems!
Well there is still a problem with the TV. I found that by unplugging the power cable that the digital channels worked. But, when I turned the TV on today the problem had returned, I had to take out the power cable again!
Feb 11, 2008 | Televison & Video
Remote problem Hisense
I GOT A NEW HD WIDESCREEM POLAROID. DIRECTTV CONTROL PUTS ON POWER ON TV,CHANGES CHANNELS BUT DOES NOT CONTROL VOLUME NOR CONTROL DVD ANDVCR PLEASE HELP GODWIN
Jan 08, 2008 | One For All URC-4021 Remote Control
Sharp Aquos LC-42D62U VOlume Control
OK guys I'll save you. The tv is in hotel mode. To get it out from there you have to go in service menu but DO NOT CHANGE ANY OTHER THING IN THERE, only what i tell you. With the tv on and the K letter on the screen press in the same time vol- and ch- on the tv set. Now you'll be in service mode. On the remote press down arrow (not -channel) and you'll see up industry init. go there with ch- and press vol+ and enter. let the tv like that for few seconds and the tv will go green and hopefully industry init succsesfull will be on the screen. After that unplug the tv and replug it. Done!
Oct 19, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
RCA L40FHD41 40. in HDTV Logo
78 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
