Question about TurboChef C3 Single Oven
OVEN DOOR IS NOT CLOSE PROPERLY.
I HAVE TURBOCHEF OVEN. I USE IN SUBWAY BUT OVEN DOOR CAN NOT CLOSE PROPERLY AND HEATING IS GOING TO IN DOWN.I WANT TO REPAIR MY OVEN.CAN YOU CONTECT ME.
    Problem Solver:
  • 14 Answers
Which subway are you , if the door doesnt close properly you may need new hinges
Posted on Jul 22, 2010
Oven showing door close error with _ _ M
there are little switches inside that the door hits when you close it. open both side panels then open and close the door. you'll see them in the upper left. there primary, secondary, and monitor. PSM. they either broke or something need adjusted. easy and cheap fix. you could take the leads off and jump them until you get switches. but they are a safety feature so do at your own risk.
Jul 12, 2015 | TurboChef TORNADO Electric Oven
I bought my turbochef NGCEW ex Subway. It heats up no problem and then shows the Subway menus but I can't seem to access the edit menu. Also, some of the keys don't beep when I press
This might help you out:
http://www.basequipment.com/v/service/TurboChef/NGC.pdf
It's a service manual for the TurboChef NGC Tornado.
Pay particular attention to pages 15 through 19. It shows you how to edit menus and to reset everything.
Oct 21, 2014 | TurboChef TORNADO Electric Oven
Hi i have turbochef speed oven in subway and on display show F6 ec Temp . what is problem
F6 faults occured when temperature reached to 150 degree faharanite in the electrical compartment.
Solutions
1. Clean the dust in the electrical compartment.
2. There is an temperature sensor on the controle board which gets dirty and throw wrong values.Clean it and then try.
3. Check the exaust fan in the top rear location is working properly.
4.Check for proper air ventillation.
Apr 15, 2011 | TurboChef TORNADO Electric Oven
I am working on an NGC subway oven and the store manager told me it would only heat up half way
Check the IR element. check the heaters. check the high limit switch on the back of the oven. Usually the IR element will have burned wires where it enters the oven and will need replacing.
Oct 06, 2010 | TurboChef TORNADO Electric Oven
Where do i find parts - like fuse
go to 3wire.com recommended by IPC, also you get crazy deals. Be sure to register as a subway to get the subway discount.
This will save you hundreds of $$$$ so be sure to thumb it my answer
Aug 12, 2010 | TurboChef C3 Single Oven
I have NGC tornado Turbochef, it is toasting too
the subway ovens are supposed to be around 1000 dont change any of the settings if you think you are having programming issues speak to your field rep and ask them to reprogram your oven. they have a smart card for doing this. it will give you all the latest buttons including hashbrowns and breakfast stuff.
most common problem with toasting to dark is that you are using the wrong buttons
try cooking the next sandwich on the 1meat hotwell setting and select the sandwich size. you will notice the sandwich cooks much lighter.
if you cook using the combo subs button this could be your problem. most of the time re-training is just needed
Dec 11, 2009 | TurboChef TORNADO Electric Oven
This is the 3rd time for this turboChef oven - door not closed.
it is because the switch kits are not setup properly.they need to set to open and shut in the right order,hope this helps regards lse
Jan 16, 2009 | TurboChef TORNADO Electric Oven
About my turbochef toster oven it has f8 low heat problem
there is a high limit reset button on the back of the oven .reach around left side if you are facing oven. if that is it but it trips again you have other issues. if that is not it you have other issues possibly k4 k5 ssr or element problems
Nov 15, 2008 | TurboChef TORNADO Electric Oven
Turbochef Oven Repair
goto http://www.hobartcorp.com/default.aspxs site its hobart.Find the nearest office to you,either they will service your equipment or can lead you in the right direction.
Nov 16, 2007 | TurboChef TORNADO Electric Oven
TurboChef C3 Single Oven Logo
467 people viewed this question
Top TurboChef Ovens Experts
Dennis Boxerman
Craig Butler
Craig Butler
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
