Question about Toshiba TDP-MT200 Multimedia Projector
Lamp The picture is getting very dark and flickering.The lamp only has 740 hrs on it. Is that the problem?
  • 563 Answers
Hi Striker 53
Yes , a flickering image and dimming is a very clear indication that the lamp is going.
To make 100% sure and to give you some peace of mind - take out the lamp and you will either see vein like looking marks on the lamp or discolouration or even that there is a bubble at the end of the lamp's shaft.
Do keep in mind that a lamp normally gets a rating of say 2000-3000 hours , but that is only a estimate from the manufacturers factory. I've had lamps that had less than 300 hours on them , that needed replacement.
Once you replaced the lamp , remember to reset the lamp timer.
Posted on Apr 21, 2008
The picture has suddenly gone dark. We can still see the picture, however it is really dark. We tried shutting it completely down and unplugging and restarting it. We tried to adjust the color via the...
The tv LED light on the tv front bazel frame face have the word "LAMP" light up or blinking?Yes.The tv projection lamp been inside this tv like 1 1/2 or 2 years already,tv used it everydays like 4 or 5 hrs daily?Yes.Than the tv projection lamp life are over,that why it dim picture tv now must have it tv projection lamp to be replaced.
Jun 12, 2011 | Samsung SP50L6HX 50" DLP HDTV
I have a 50" RCA Scenium which I purchased in 2003. ($3000) I changed my third lamp yesterday...(the picture was getting dark after 3 years), and was very happy with the picture. Today, after about 2 hrs...
No, you do not have a bad circuit board, the problem is still from the lamp you fixed on it. Have it checked once again to see to it that there was no slight difference in the way you have been fixing it.
If you have a bad circuit board, there would be a complete alteration in the functioning of the television.
Since the problem has to do with the lighting and picture of the television, it has to do with either the lamp or t-com board, so check them both.
Take care
Oct 10, 2010 | Televison & Video
Samsung hlr5667w TV made a popping noise then the picture started
Most likely. You should remove the lamp door, pull out the lamp, and inspect it. Look into the center of the lamp, does it look dark or swollen? Does it look chalky on only one side? Did it burst? If so, you definitely need a new lamp. I hope this helps.
Mar 16, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Dull laptop screen back light
You may have a faulty CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.lcdparts.net
Dec 30, 2009 | Dell Latitude C610 Notebook
My screen is dark
You could have a defective LCD screen, If the laptop appears to be running and the hard disk is spinning but the screen is dark then, to determine if you have a LCD screen or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jun 21, 2009 | MSI M670 Notebook
Screen getting dark on sharp pc-m4000
You most likely have a defective screen - a defective inverter or a CCFL lamp. To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 03, 2009 | Sharp WideNote M4000
Friend's Laptop Screen has become too dark to work with
You could have a defective screen - a defective inverter or a CCFL lamp.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Apr 24, 2009 | Toshiba Satellite U205-S5002 Notebook
Acer screen looks dark?
Apr 23, 2009 | Acer Aspire 5315 Notebook
Dark display
You most likely have a defective CCFL backlight, it may have the following symptom:
Apr 11, 2009 | Computers & Internet
Dark monitor screen with hidden display in the dark.
Apr 07, 2009 | Acer Aspire 5040 Notebook
Toshiba TDP-MT200 Multimedia Projector Logo
259 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
