Question about Mitsubishi Car Audio & Video
I have a pioneer 2050 mpg it keeps coming up error
I have a pioneer 2050 mpg car cd player it keeps coming up error 15 how do i fix it was working ok then went to put a cd in and comes up error 15 now
  • Mitsubishi Master
  • 17,130 Answers
It is possible that you player has got in a bad cd that had got entagled inside the mechanism orr doena damage into the system. If you are able to retrieve the cd fron the front without damaging the set please do it carefully other wise open the set's cover and carefully unwind the mechanism motor drive to retrieve. After this if a another cd goes in well and tracks your are lucky other wise, check if the cd drive is sppining well and the tracks are read if not clean the optical and try. if the cd goes in fine, spins and does not read then it could be a possible failure of the optical head. If not the loading mechansim should be checked for loading errors. check the motor drives for slippages or dirt. clean and try.check voltage onthe motor to confirm if motor has failed. Hopt this helps. Good day
Posted on Jul 20, 2010
How do i fix my error 15 codes pioneer cd player
Try a cleaning disc. The error means your device cannot find any data on the CD. As I suspect you have tried several CD's with the same result, if the cleaning disc does not resolve the problem, then your laser:
A. May be misaligned
B. Going bad
C. Already bad and needing replacement
But replacing the laser would be expensive. You have to weigh the expense of commercial repair vs getting another unit.
Dec 10, 2017 | Pioneer Car Audio & Video
I have a pioneer car radio and i am receving and error 12 message
I found the following information on Page 28 of the Pioneer manual for your DEH-P2900MP through the pioneer website:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/370967683DEHP2900MPOperationManual1027.pdf
ERROR-11, 12,
17, 30
Dirty disc Clean disc.
ERROR-11, 12,
17, 30
Scratched disc Replace disc.
ERROR-10, 11,
12, 15, 17, 30,
A0
Electrical or me-
chanical
Turn the ignition
ON and OFF, or
switch to a differ-
ent source, then
back to the CD
player.
I hope that helps
Jun 22, 2010 | Pioneer DEH-P2900MP CD Receiver...
Got a pioneer deh 2050 mpg car cd player, connected the wiring to the + and - and its not turning on,power is available at the leads.Its a second hand unit, I was told it worked before being removed from...
Well you will find a yellow leads,this must also connect with the positive leads,then you will see it will switch on.This yellow lead is for the memory of the cd player.
Dec 29, 2009 | Pioneer DEH-P2000 CD Player
Cd keeps ejecting on pioneer 1500 error code 10
The manual says a code 10 is Electrical or mechanical. The say the solution is to turn the ignition on and off, or switch to a different source, then back to cd player.
Dec 10, 2009 | Pioneer DEH-1500 CD Player
Front display panel keeps coming off cd player
You can purchase a new back piece to it and that should fix it . They generally run $20.00 or less
Jun 19, 2009 | Pioneer DEH-1100 CD Player
ERROR CODES 15 and 12
http://audio.manualsonline.com/manuals/mfg/pioneer/deh-2800mp_2.html
May 05, 2009 | Pioneer DEH-2800MP CD Player
My stereo is a pioneer avic-f700bt and it wont play my cds anymore it keeps saying code error 15 and code error 12
Try cleaning the Cd player with a cleaning kit? Does the cd have dirt or scratches? Most of your errors are not so uncommon check these things, and rate accordenly pls.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 22, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
My pionner avhp5700 dvd keeps coming up with error
I have the same issue with my unit but it seems to be worse in summer months. I don't leave cd/dvd in unit and have considered removing unit.
Nov 02, 2008 | Pioneer AVH-P5700DVD Car DVD Player
When I try to play a C.D. on my system it gives me the following information. FRMTREAD, Error 15. What does this mean and what do I do to correct this problem? My system is a DEH2000MP S.N....
Consult your owner's manual for error codes. You have a disk/disk reader problem. A similar model Pioneer Manual indicates FRMTREAD as what is displayed while reading a disk. Error 15 equates to "The inserted disk does not contain any data". If this occurs with multiple disks, try the disks in a known good cd player. If they work there, it is likely a reader problem (alignment, bad reader, etc.) which would likely not be worth repairing or replacing in that unit.
Jun 23, 2008 | Pioneer DEH-P2000 CD Player
Car Audio & Video Logo
108 people viewed this question
Top Mitsubishi Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Mitsubishi Car Audio and Video Expert? Answer questions, earn points and help others
