Question about Dell Dimension 4600 PC Desktop
Monitor display "No Signal" tried with other Monitors but not working either.....can i use a video card??
  • mybradley7
    mybradley7 Jul 19, 2010
    are you using a lcd?
  • 86 Answers
You can use a video card. It is possible that your motherboard is fried which is preventing the video output from working. You can try using another video card and see if that works.
Posted on Jul 19, 2010
No signal detected message on monitor, cpu and monitor are on
Good Day Jboone563!
You need to check if the VGA cable is properly fix to the monitor and video card. Loosen connection or no contacts is the reason for the "no signal" display on your monitor.
This means that there is no signal coming out from the video card, going in to your monitor. If by fixing the VGA connection did not fix it, try removing the video card from the motherboard and then reseat it properly to the motherboard slot.
If this do not resolve the problem, Jboone563, I'm sorry but you will need to replace the video card.
May 26, 2011 | AOpen 19" LCD
Hyundai U220WD LCD monitor displays OFF MODE (on a black backgroung). How do I restore the display? What does the MWE button do?
Hi
If the screen is connected to a computer usually its a video card/ video cable problem and not the LCD monitor. Try to check the video cable look for loose connection or bent pins, if none try using a different video cable or checked the video card component of the computer too see if its still working,. Your monitor is dependent to your video card signal inside the computer. Without the signal monitor will not work.
thanks for using Fixya
Mar 25, 2011 | Hyundai Electronics N220W 22 inch LCD...
Monitor display no signal message
Hi. Check the cables if it is firmly connected to the video ports. If nothing happens, try removing and reinstalling the video card then reconnect the cables. It works wonders!!!
^_^
Jun 03, 2010 | HP w2207 Monitor
Display on left half is correct and right half is slightly faded
Uninstall reinstall drivers from Device Manager of Display or check out for video card defects
May 30, 2010 | LG 22" FLATRON LCD Monitor
Monitor not connecting to tower. it is plug in to the tower. but shows that it is not connected.
three things can be the issue here:
1. No signal from the tower (VIDEO CARD)
2. Bad cable or bent pin on the d-sub 9-15 pin vga connector.
3. Bad signal board inside the monitor itself.
Things to try:
1. another computer.
2. check the signal cable for bent pins.
3. check the video card in the tower.
Before you "think its a bad monitor" you always want to assume the computer first as computers are 9 times out of 10 why the monitor is not coming on such as BIOS errors, Bad video card, bad power supply etc etc.
PLEASE BE CONSIDERATE! When rating and leaving positive feedback for your free answer today.
May 27, 2010 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
No signal to monitor. Cable is fine and so is the Video Card -
your motherboard may be going out is your keyboard also acting crazy
Aug 15, 2009 | Impression Products Impression 7LSP 17"...
Monitor says: no signal input check video cable Even though the computer is on and hooked up
if it says so....it indicates that the display card is gone bad. check with the display card...
or try inserting New Graphic card or PCI VGA card... works for sure....
Jun 23, 2009 | Hannspree HANNS-G 19" Widescreen Monitor
Worked fine now no display
one of few possibilities, either no input form video card (possible bad video card), or loose video cord. or on flat video cards, you can choose from the menu to use digital signal or analog signal, if you have chosen what u do not have , u might have gotten that result.
Jun 17, 2009 | Acer AL2017 20" LCD Monitor
THE HAVE LIGHT,NO DISPLAY YELLOW LED
This is generally caused by no video signal from the computer. Try the monitor with another known working computer. If it works there, the video card (or onboard video) of the original computer is faulty. Otherwise, it is a problem with the incoming signal circuitry of the monitor (or cable).
May 26, 2009 | Acer Computers & Internet
Newer monitor to older xp pc
If your monitors are displaying "no signal" they aren't receiving input from the video card. If your PC has two video outputs (onboard) try charging to the other output to see if it will come on. Also reseat your video card in its slot. Also, what can you see that lets you know the keyboard and mouse are not working?
Dec 29, 2008 | Computers & Internet
Dell Dimension 4600 PC Desktop Logo
81 people viewed this question
Alun Cox
