Question about Sunbeam 4817 Oskar Food Processor
How do you remove the bottom bowl to clean - Sunbeam 4817 Oskar Food Processor
    Problem Solver:
  • 7 Answers
See page 8 in this manual to find out how to remove the container from the base motor:
http://kitchen.manualsonline.com/mdownloads/c44fa16e-225f-49e2-84e5-348ee18b9c1b.pdf
Posted on Aug 26, 2010
My bowl will not turn by itself anymore on my Oster Regency. How can i fix this problem?
Unplug electricity cord from wall and disassemble bowl carefully. Clean dirts on moving parts. Be careful not to leave any liquid on any piece.
If motor output shaft rusted; use some rust remover on piece of cloth and clean it. Be carefull; don't use too much rust remover and don't let it go into motor to prevent electrical shock. Try to turn output shaft by hand. If it turns easly assemble everything back again. If it doesn't turn that means; motor might has some issues. There is no way to fix it but changing motor with a new exact one.
Nov 19, 2014 | Food Processors
Tip
The cusinart pro classic food processor is not working ?
Try this procedure:-- It usually goes something like this, with minor variations depending on model number:1.Remove the work bowl completely from the base
2.Plug the food processor in and turn it on
3.Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4.Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the work bowl
5.Place the lid on the work bowl with the tab slightly left of the center of the work bowl handle – slide the lid counterclockwise until it won’t slide any more
6.Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7.Slide the lock to the right into the locked position
The food processor should now work.
This will help.Good luck.
on Mar 08, 2010 | Food Processors
Need to clean inside the handle of the KFP600WH
SORRY but fixya has no idea what you can do about cleaning .
Oct 22, 2017 | KitchenAid KFP600 Ultra Power 11 Cups Food...
How do you take bowl off for cleaning
Hope you've worked it out by now, but there are 2 notches at the bottom of the bowl that slot into the base. To remove the bowl, take the lid off and rotate the bowl clockwise so the notches disengage from the base, and simply lift it off/. I assume if you couldn't do this the bowl must have had a lot of gunk stuck in the notches which prevented it from moving - yuk! I put my bowl and lid in the dishwasher - no prob.
Jul 02, 2012 | Sunbeam 4817 Oskar Food Processor
I have a Moulinex Ovatio 2 food processor. it looks as though the handle to the processing bowl can be removed...but I just cant work out how! It needs cleaning as the design of the handle lets water and...
It is safe to remove the white part - I just did it. Lever it off with a knife at the bottom then two clear plastic parts and the spring can be removed. Just don't lose the spring!
Aug 22, 2011 | Food Processors
It won't start. The cup locks - the top, not so sure. Any ideas?
I have the same problem, It is better after I scraped the top surface of the bowl with a supersharp knife held vertical to the top of the bowl lid, and removed the resulting burr from both sides of the bowl. I presume that it was too much friction between the mating parts of the bowl and the lids. It is better now and hopefully will be easier with use. The problem might have been insufficient cleaning of the mating parts after use and consequent gumming up.
Narender Grover
narender_grover@hotmail.com
Nov 07, 2010 | Cuisinart DLC-5 Food Processor
I Cuisanart mini prep and removed the bowl, lid,
Make sure the tab on the lid is making contact with the "tower" in the back and that the work bowl is locked properly into place so that the plastic tabs show on each side toward the bottom of the work bowl.
Aug 12, 2009 | Cuisinart DLC-2 Mini Prep Plus Food...
Need to clean inside of handle on KitchenAid food processor
The plastic for the work bowl / handle is molded and one piece and cannot be disassembled. My best recommendation is to call Kitchenaid customer service to see what recommendations they have. Within one year warranty, they may replace the work bowl at no cost.
Their toll-free number is: 1-800-541-6390.
Jun 28, 2009 | KitchenAid KFP750 Food Processor
KitchenAid Food Processor 770 won't run
I am assuming the unit is getting power. The "power" LED should be lit up on the front of the unit.
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
If this has not resolve the issue, please ensure the outlet is receiving power.
If the unit is still not functioning, take a close look at the bottom of the work bowl where it meets to the motor base. The work bowl, when locked in, depressed a gray plastic peg. This is the safety mechanism. You may trying depressing this peg on your own with a pencil. If this activates the motor, this may indicate your work bowl is no longer seating correctly.
Also check the work bowl handle to make sure nothing is cracked. There is a plastic assembly in the handle that acts as a second safety feature.
If either of these things seems to be the culprit, I would suggest seeking a new work bowl or work bowl lid to correct the issue.
Jun 18, 2009 | KitchenAid KFP670 Ultra Power Food...
Cannot get food bowl off the Oskar food processor
My Oskar has two locking teeth on the bottom of the bowl. One at the 3 o'clock position and one at the 9 o'clock position. Grabbing the bowl at the bottom with one hand (using thumb and one finger), I twist clockwise (to the right) about 1/4 inch and the bowl unlocks and lifts off directly. (my unit's spindle doesn't have anything to do with locking the bowl. My unit must be 15 to 20 years old btw)
Jan 13, 2009 | Sunbeam 4817 Oskar Food Processor
Sunbeam 4817 Oskar Food Processor Logo
129 people viewed this question
Top Sunbeam Food Processors Experts
Jaime Hernandez
eyecam
dwood429
Level 1 Expert
Are you a Sunbeam Food Processor Expert? Answer questions, earn points and help others
