Question about Whirlpool GEW9250 Electric Dryer
The roller doesn't spin, though there is heat coming out. What can be the problem
  • 5,911 Answers
If the dryer is heating, but the drum fails to turn, this is usually caused by a broken dryer belt. To replace the belt on a Whirlpool Duet series dryer, you need to follow these steps:
1. UNPLUG the dryer before servicing. Dangerous voltage is still present inside the dryer even when it is turned off.
2. Remove the top panel of the dryer by locating and removing the screws holding the panel in place in the rear of the dryer. With the screws removed, the panel will slide back, then come off. The belt should be present tightly wrapped around the drum. If not, its likely the belt is broken and lying in the bottom of the cabinet.
3. Open the door and remove the lint screen. IMPORTANT: You will not be able to remove the air blower cover with the lint screen in place.
4. Remove the lower toe panel directly below the door. The panel comes off by locating and removing the screws under the bottom front edge. With the screws removed, the panel will drop down, then come off.
NOTE: Propping the front feet of the dryer up can provide you better access to the screws (a 2x4 works well for this).
5. Disconnect the auto dry sensor plug (usually yellow wires with a white plug to the right of the blower assembly) and any ground wires that may be connected to the front panel.
6. Remove the air blower cover by locating and removing the mounting screws.
NOTE: This is a good time to clean the blower fan housing, squirrel cage motor and dryer interior cabinet.
7. Locate the two screws that hold the operator console in place. There should be one on each side under the top panel. Remove the screws and carefully lift the panel straight up.
NOTE: You do not need to disconnect the ribbon cables. Carefully lay the console across the top of the dryer out of the way.
8. Disconnect the door switch connector plug and remove the dryer front panel by locating the four screws that hold it in place. Loosen the two screws along the bottom of the panel and leave in place. Remove the top two screws and lift up and turn the whole front panel slightly counter-clockwise to release the drum supports from the dryer drum.
NOTE: Make sure the dryer door is closed when removing the front panel to avoid damaging the door hinges.
9. Reach in behind the air blower with both hands and pull the idler pulley to the right with your right hand to release the tension and remove the dryer belt (if still attached) from the drive motor.
10. Install new belt around the dryer drum making sure the ribbed side faces towards the drum.
11. Reinstall the dryer belt by releasing the belt tension pulley again (as described in step 9), then, with your left hand loop the belt over the drive motor pulley. Release the idler pulley making sure the belt rests on the drive motor pulley. You should feel the belt tighten with tension.
NOTE: If you need further clarification on how to properly route the dryer belt you can go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, locate the "Dryer Belt Diagrams" link under the Special Features section. Refer to diagram K.
12. Reinstall the front panel by turning it slightly counter-clockwise and aligning the front drum supports under the front of the drum. Once the supports are under the drum, turn the front panel clockwise and lift up, placing it on the bottom two screws. Reinstall and tighten the top two screws.
13. Reinstall the door switch connector plug and reinstall the operator console. Use caution not to put too much stress on the console ribbon cables.
14. Reinstall dryer top panel.
15. Reinstall air blower cover and reconnect the auto dry sensor and ground wire.
16. Reinstall toe panel by inserting the top portion first and pushing up. Push lower portion of the panel in place and reinstall screws.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices will vary between sites so shop and compare. The drive belt part number for the model you listed this question under is 661570.
NOTE: This model dryer has a broken belt switch mounted on the belt tension puley. If the pulley loses tension form either a broken belt, or a tension pulley spring that has come loose, the dryer will stop tumbling. So, if the belt is still intact, check the tension pulley for a loose or missing tension spring. The first three web sites I listed have exploded view parts illustrations to assist you locating and properly identifying any part you may need. Refer to the "Cabinet Parts" section for an illustration of the belt and drive components. The belt is listed as item 30 and the belt switch is listed as item 5.
I know this may seem like a lot, but its actually fairly simple if you follow the steps provided. Read through everything before attempting any repairs. If you have any questions, please post back and let me know. I hope this helps you.
Posted on Jul 15, 2010
FIX GAS DRYER
even though the video is changing the rollers, you'll see the belt being removed and install.
http://www.partselect.com/2019709-1-M-Whirlpool-22001682-Lid-Switch-Assembly.jpg
Jun 06, 2012 | Dryers
Dryer spins but doesn't get hot. Model #11077522600
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 09, 2011 | Kenmore 73952 Gas Dryer
Dryer spins but doesn't blow hot air to dry clothes
heatman101-=
Aug 27, 2011 | Dryers
I have a Kenmore Stackable washer & dryer Model # 417.93702200 and my dryer will come on and spin but it doesn't get any heat to dry my clothes. what could be the problem? Where can I get the...
heatman101
Aug 19, 2011 | Dryers
We have a whirlpool duet dryer and it will not heat up. I've checked for blockages and there doesn't seem to be any. It does spin but no heat
heatman101
Jun 29, 2011 | Whirlpool Dryers
My ge dryer DBXR453EVOWW , drum doesn't spin, does heat
heatman101
Jun 12, 2011 | GE Dryers
My Hoover brush spins, but doesn't have very strong suction. I've checked the filter, tubes, but it seems as though something is stuck inside. Can you tell me how to check behind the roller to...
To get the roller out.Turn the machine upside down.You will see some screws.Remove them.That allows you to remove that plate.The roller will just lift out.Some have a cap on it and can fit tight.On the back of the machine are two more screws that hold the hose on.You can take the hose off there ,if you have not already.Running a straightened out wire hanger through the hose will insure that there is not a clog you may be missing.As it is a few years,replace the belt while you have the roller out.It is on one end of the roller and the other end slips on a small wheel.It is easy to do and may improve the over all performance of the vacuum.
May 16, 2011 | Hoover U8145-900 Savvy Bagless Upright...
Squeaking Noise coming from Dryer
Could be the roller next to the heating element. Heat tends to cause more wear in it. Use some HVAC oil to lube those noisy rollers. 6b5c930.jpg
Aug 02, 2010 | Maytag PYE2300AY Electric Dryer
My dryer rumbles when it is spinning. But it also
The drum support rollers are worn. This will cause loose belt tension and a rumbling sound. You will need to pull the drum to find the rollers at the lower back of the drum. Check the roller shafts for wear and replace them at the same time as the rollers if needed. Check the belt and tensioner for wear before reassembly. This should fix ya...
May 08, 2010 | Dryers
Eats belts immediately
HI There,
Usually when the belt breaks immediately, this indicates that your roller brush has gone bad and needs to be replaced. I have never seen the motor shaft being damaged and causing belts to break before. When the roller brush can't spin because it's bearings have worn out, the motor shaft continues to try and turn the belt, but since the belt can't spin the motor shaft at that point burns right through the belt.
To make sure that it's your roller brush, remove the brush from the vacuum cleaner, and hold it using just your two pointer finger tips, holding just the bearings caps at the end of the bar, and not the bar itself.
Try to spin the brush using your thumbs. Does the brush spin freely without resistance? It should spin completely around 3-4 times on each spin. If it doesn't spin, then your bar is bad.
If the brush doesn spin, and it continues to break belts, this means that the belt is being installed incorrectly, and is being pinched by the roller brush. Pull the belt forwards after installing to make sure the brush spins freely.
Hope this helped you,
Chris Jones
GoVacuum.com
May 01, 2010 | Dirt Devil M086355 Bagged Upright Vacuum
Whirlpool GEW9250 Electric Dryer Logo
143 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
