Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
The auto drainage isn't working properly
Our GE dishwasher is washing and rinsing the dishes seemingly just fine,
yet the washer never seems to drain all the water out of the machine.
Subsequently the odour of the water after a couple of days takes over the aroma of the kitchen..Any suggestions on possibly repairing the dwashe.
thanks.
rob.
  • 166 Answers
You will need to check the drain hose to make sure that you don't have a partial blockage. If you have an air gap check that to make sure it is not partially stopped up. If you don't have an air gap check to make sure your drain hose is not lower than your sink drain allowing water from the sink to drain back into the dishwasher.
Posted on Jul 20, 2010
  • mreid542
    mreid542 Jul 20, 2010
    It is normal for a little water to stay in the sump of the tub but it shouldn't be standing in the bottom of the tub and it shouldn't be smelly.
  • gabriel Sep 18, 2010
    hi. i have a nine year ge TRITON dishwasher. now, the water stays inside the tub after the washing process. i replaced the air gap above the counter sink. i vaccumed out all of the water and cleaned out the bottom screen. i checked all of the lines under the sink and the dishwasher is working fine. no leaks what-so-ever. what the drain located behind the wall in the backyard which is exposed out of the wall? so i loosen it to check any debris inside?
What means of auto drainage?
Posted on Sep 15, 2010
Water will not drain out of bottom of dishwasher...... dishes do not seem to be rinsed completeley when cycle finishes
Two issues can be present and might also point to the control board. The pressure pump and the drain pump is not working which has resulted in the inefficiency washing and draining.
so check on the power to these pumps to confirm if the pump is faulty or the controller unit is faulty.
Sep 03, 2010 | GE Dishwashers
My GE dishwasher is leaking out the bottom of the front door. Everything seems to be sealed properly. I took the inside of the door off and couldn't find anything obvious. Is it possible to be overflowing...
You most likly need a new bottom door seal. Usually 3 screws down each side of the door and then two screws hold the bottom door seal in place. The bottm door seal can look fine but if its leaking out the bottom front this is the problem 99 % of the time, Unless someone is using dish soap to preclean the dishes or using regular in the dishwasher.
Mar 20, 2010 | GE 24 in. GSD3330C Built-in Dishwasher
Dish washer \does not rinse good leaves white flim
Hi:
Some things you can do to try to improve your dishwasher's performance:
1) Make sure your dishwasher rinse agent dispenser has rinse agent in it. The filler is usually close to where you put soap in the dishwasher.,
2) Consider switching brands of dishwasher detergent, if you are experiencing problems. Depending on the water condition in your area, certain brands work better than others. Ask your neighbors what works well for them.
3) try different wash cycle's with your dishwasher. Sometimes the economy cycle doesn't work as well as it should.
Dec 17, 2009 | GE Dishwashers
Dishes do not clean same detergent and rinse no change to amount
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Jul 06, 2009 | Bosch 24 in. SHX46A05UC Built-In...
Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
May 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Water seems to be hot enough, drains properly, arnms not blocked, dishes not being cleaned at end of cycle. Almost seems like it is skipping the wash cycle.
Hi smiller8565,
There is 3 basic problems that will cause a dishwasher to not clean the dishes. You can check these problems and see if any will solve your problems.
1: If there is water or suds left in the dishwasher after the cycle is complete. This will cause dirty water to be used in the final rinse and the dishes will not get clean.
2: The pump that supplies water to the spray arms is jammed or defective and unable to pump the water properly, thus causing the dishes to remain dirty.
3: Timer, the timer is not allowing the machine to work in the wash cycle.
The solutions for these 3 are as follows.
1: check the drain line for blockage, if you have a disposal make sure it is clear and water flows down the drain properly. If you have suds left in the dishwasher, clean them out and run a couple cycles with not detergent to rinse away the old suds.
2: Look down in the bottom for any obstructions in the pump. Popcorn seeds, broken glass, etc.
3: If the unit is skipping the wash cycle you will most likely need a new timer or control assembly.
Good luck and I really hope this will Fix Ya
Mike
Sep 24, 2008 | Dishwashers
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
458 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
