Question about RIM BlackBerry Pearl 8100
Blackberry storm battery won't charge and device won't turn on.
I started off with a charged battery and within 6 hours it completely drained i tried charging it again and it wouldnt charge there was a red flashing light so i took out the battery left it out for 1 minute nothing happened. so i took out the sim and 8gig memory card then put it back into the device after 1 minute nothing happened so i put the charger in and a white screen appeared with a battery and the battery had a lightning thing through it. I tried turning on the device and it won't turn on and i don't know what to do???
Do i buy a new phone?
Hi! My phone had exactly the same problem a few days ago! I got a new battery - it worked fine for a couple of days and here we go again... It is dead! Please let me know what you did with your phone! I have a new BB curve! Thank you!
Posted on Jan 12, 2011
Just bought a new Blackberry storm 9530 and it is not getting charged. Please help
Usually for brand new phones, the battery needs to be charged for two hours. But if you found out after it's been a while and it's not charging, make sure the battery is inserted correctly. If it's and the led is not on or no charge indicator, do the following, take out the battery, unplug the charger from the phone, press and hold the power button for five seconds. This drains out the battery. Now put the battery back in, plug the charger into the phone and let charge. Don't worry if it doesn't recognize it immediately. I hope this helps
Mar 09, 2011 | RIM BlackBerry Storm 9530 Smartphone
Blackberry storm charging problem is plugged into the computer to
I've had this problem just since the last software upgrade. New charger, cable & battery haven't solved it.
Dec 14, 2009 | RIM BlackBerry Storm 9530 Smartphone
Unlock blackberry storm 2
Don't worry about it. it is very simple to Unlock your Blackberry Storm2 by entering Imei Unlock Code . you can get your Mep Unlock Code for Blackberry by third party or your network provider.
third party give your Imei Unlock Code within hour. but your network provider take time to give you Imei Unlock Code. and charge huge amount. you can buy Blackberry Imei Unlock Code from third party. they will charge little amount.
i hope this will help you.
Nov 24, 2009 | RIM Research In Motion Blackberry Storm...
NOTHING SHOWS ON THE SCREEN OF BLACKBERRY STORM, HE CANNOT SEE THE KEYS TO FIND THE MASTER RESET, IF THERE IS ONE.
If you are able to see any light lit on you are blackberry.First charge your mobile for atleast 1 hour,and switch it ON you have to remove the battery when mobile is turned ON and wait for few seconds re insert the battery then check
If problem still exsists connect your blackberry to computer check wheather its recognising the device If "yes" you need to take a back up of your hands set and re-install the operating system of your Blackberry. Or else please visit the nearest service centre.
Nov 22, 2009 | RIM BlackBerry Storm 9530 Smartphone
Blackberry curve 8300 suddently died
Try somebody else's battery, if the problem persists, it's most likely a logic board issue. There are blackberry repair websites that show you how to do the replacement yourself, otherwise here is a service that can repair any Blackberry Bold, Storm, Pearl, Curve, 8800 for screen, lenses,
track balls, usb ports, waterdamage etc.
The website is: Blackberry Repair
Jul 27, 2009 | AT&T Blackberry Curve 8300 Smartphone
Battery Icon with red line through it? Durring a back up, my Storm turned off and when I turned it back on this battery icon is all I get. I have a fully charged new battery in it now and it still shows...
This usually means the bb and battery got a little wet or has other issues. Try these solutions in order. They go from easisest to hardest. NOTE: If you have an insurance policy on the bb probably best just to take it in.
1. Remove the back cover. Remove the battery and the SIM card. Wait 30 seconds. Replace SIM, battery and back cover. Reboot. Plug in the bb and charge fully.
2. If that doesn't work, allow the bb to remain unplugged but ON for about 24 hours to drain the battery. Remove back cover and battery. Allow battery and opened bb to sit in a dry environment for 24 - 36 hours. Relace battery and cover. Reboot. Plug in the bb and charge fully.
3. If that fails retry step 2 but allow battery to FULLY drain then dry out again.
4. Take in.
Jul 18, 2009 | RIM BlackBerry Storm 9530 Smartphone
Blackberry Storm 9539 Smart Phone will not come on
Unplug the charger from the phone. Pull the battery and wait one minute. Reinstall the battery and then reconnect the charger to the phone. The phone may not start up if the battery is completely dead, but you should see the green light fade on and off. If this is happening, let it charge for an hour or so before attempting to power it on. Also, make sure you use the correct home charger. I have had charging issues when I previously used car chargers in this situation.
May 05, 2009 | RIM BlackBerry Storm 9530 Smartphone
Red led light is flashing while charging and it won't turn on
I just called Verizon Wireless who said that the phone may need to be charged completely for a few hours. Try taking the battery out and putting it back on as well.
May 02, 2009 | RIM BlackBerry Storm 9530 Smartphone
RIM BlackBerry  Pearl  8100 Logo
370 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
