Question about Dirt Devil Vacuums
My vac. pet attachment exploded in my hand! I have talked to a debbie on the phone for a pick up of this machine, but I want to know whats going on with this certain machine! because it hurt the palm of my hand under my right thumb bad and I need someone to get back with me today!!!!!! SHERRI ADKINS P.O. BOX 1502 CHAPMANVILLE W.V. 25508 HOME #304-855-8868 CELL#304-784-6456
3 Suggested Answers
pippall
  • 1486 Answers
SOURCE: Pet hair and dirty water back on carpet
If you have followed the instructions.And your not happy i would return it.Get a repacement.
Posted on Aug 09, 2009
renevacdoc
  • 84 Answers
SOURCE: I need to find out how to attach the hand tool to
. In the front of the dirty water return tank there should be a removable square plastic piece. Remove the lid and slide that piece out. Replace wth the back end of the hose receptacle. when you return the lid to the top of the return tank, you must roll it on from the front(there are brackets the lid hooks under) to the back and listen or feel or the "click". Then, on the top of the base there is a hinged receptacle that you plug the small hose into. You should be all set! Hope this fixesya! Thnks, Rene (vacuum Doctor) let me know if this helps!
Posted on Nov 15, 2009
WonderTech
  • 268 Answers
SOURCE: I bought a used hoover steam vac model #F5887-900
Here is a link for a manual that should help you with your machine. It is not the same model manual but should work for you.
http://www.hoover.com/pdfs/manuals/F5857955.pdf
I hope this helps.
Posted on Feb 02, 2010
Are bags needed for a dirt devil hand held dust buster?
Dirt Devil Parts
dirtdevil.com/parts/
Dirt DevilNo promo code required. ... most popular: Bags: Belts: Filters: Cleaning Solutions: Filters, F1-F85: Filters, Adapters: Filters, ... vacuum cleaner: Attachments & Tools: Brushrolls, Hand Vacs: Brushrolls, Uprights ... Handheld Steam Cleaners.
Type G (10 Pack) - 3010348001 - Dirt Devil
dirtdevil.com/parts/details/3010348001/type-g-10-pack/
Dirt DevilGenuine Type G bags. Fits all hand vac models equipped with the paper bag adapter. Includes ... The Handheld Vacuum That Picks Up Where Others Leave Off ...
Ultra Corded Bagged Handheld Vacuum - Dirt Devil
Jan 01, 2016 | Dirt Devil Vacuums
Attachment not working
Hi! The issue with the attachment may be easily rectified.
Here's a quick link to our FAQ's.
http://www.bissell.com/faqs/?c=282&sc=3329875&cid=ccsocial
If you continue to experience difficulty, you may want to have a qualified technician at one of BISSELL's Authorized Service Centers inspect your machine. Here's a quick link to assis to in locating one in your area.
http://www.bissell.com/service-centers/?cid=ccsocial
Feb 11, 2013 | Bissell Vac Lift-off Pet Deluxe Deep...
My pet vac only pick up via the tools and the brushes are not spinning
1( test the belt , can be worn, and replace
2( test the power brush and clean, and replace if necessary
3( clearing the hose.
4( see the diagram.
5( test the motor if need Repair.
Sep 06, 2012 | Bissell Upright Vacuum - The Pet Hair...
My steam cleaner wont pick up water i have checked everything and its fine but still isnt sucking up water
Well Sexy mama ..are there any on~board screens that require clearing? Pet hair clogging up vac wand end? Is there vacuum power for attachment hose? Also, check that the wand /attachment switch is to vacuum and not set for attachments. Good luck !
Apr 30, 2010 | Bissell LiftOff Revolution Pet Vac 37602...
When vacuuming hardwood floor, hair gathers on brush and never sucks into vacuum. I spend most of my time cleaning off brushes. How do I clean hardwood floor with dog hairs.
1. Broom and dust pan, then mop
2. Wet dry vac with wide non-brush attachment
3. Here's a link to a vacuum professing to clean pet hairs well
http://www.evvive.com/shop-by-brand/miele-open-box-canister-vacuums/miele-s516-cat-dog-vacuum_2
4. Try to find a wide attachment for the hose that has no brush, maybe something from a wet dry vac.
5. Take your dog outside and brush every day. It helps, but no matter what you do, you will have pet hair if you have an indoor pet.
6. Go to the source. See if your dog will be vacuumed. Half serious on this one.
Mar 14, 2010 | Sebo Air Belt C2.1 Bagged Canister Vacuum
It won't pick up. I cleaned all of the filters. what next?
I would try changing the belt. A worn, stretched or broken belt can cause the vacuum to not pick up well. Here is a link to the belt you need and the manual which has instructions:
Bissell Lift-Off Revolution belts and manual
Nov 17, 2009 | Bissell LiftOff Revolution Pet Vac 37602...
Clean machine
This is what was wrong with mine....very simple solution to fix: Check the bottom of the water reservoir. It should have a black rubber washer attached to the lip that goes down into the main system. If that part is inside the main system, instead of attached to the water reservoir, the reservoir doesn't make a tight enough seal for the suction. Just carefully remove (I use tweezers) the black rubber part (almost like a thick washer) and put it on the reservoir. Should fix the problem!
Aug 24, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Vacuums Logo
Top Dirt Devil Vacuums Experts
Roger Potts
Nick Olsen
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
