Question about HP Officejet 5610 All-In-One InkJet Printer
Hpofficejet5610allinone how to hookup to cable,
Hpofficejet5610allinone how to hookup to cable, phone&internet modem .Can't get it hookedup right so i can fax.
  • 45 Answers
Hey i'll be sending u two files
Posted on Jul 14, 2010
I have a Dell dimension 350 pc with just a modem connection for a phone line. I just got cable installed which has the ethernet hookup. i would like to still use my 350 with win. 98 if i can. how can i...
Does your cable modem have wireless internet? If so, you can buy a Netgear wireless usb port adapter for about $20 and use that to connect wirelessly to the internet. Your pc has usb port connections - right? (Usb port looks like a rectangle)
If you don't want to use a wireless connection you can purchase a cable modem with a usb connection for about $65. You run the ethernet cable to the modem and then a usb cable from the modem to your pc.
If you have a serial cable connection on your pc (looks like a round circle with tiny metal pins in it) you can buy a gender changer and convert that to usb (in case you dont have a usb connection or need another one). You can buy one for about $11.
You can buy an I/O Gear bluetooth usb adapter for $13 and pick up the internet via bluetooth by putting it in your usb port but I'm unsure how well it would work with Win 98.
If you have another pc that has an ethernet connection you could use good old fashioned bi directional printer cable and network both computers together. You may need to upgrade to win xp for networking capabilities.
Mar 26, 2012 | Dell Dimension Computers & Internet
Can't get online to play this new PS3. The console is hooked up to the TV & Belkin Wireless router. The internet, computer and phone line are in a different room and can't reach to hookup. AT&T is...
There should be no HDMI cable to router. In any situation.
Try the following:
Turn off PS3 system..
1: Reset your modem by unplugging it from the main power source.
2: After a few minutes, plug modem power back into modem. Allow all connections to configure
3: Turn on PS3 system.
4: Go to "Settings" then scroll all the way down to "Network Settings"
5: Make sure that the "internet connection" (the second menu) is "Enabled"
6: Go to "Internet Connection Settings" and choose the appropriate settings. (What's highlighted is going to be the best option, continue to hit the right button on the analog to go through the stages.)
Be sure to choose "Wireless" when configuring the settings if you are using wi fi for connectivity.
Jan 24, 2011 | Sony Playstation 3 (PS3) Console
I cant use my samsung gt-c3303k as a internet modem. so what i need to do to use my phone as a internet modem.
At first you have to install samsung champ pc suite in your pc, then connect your phone to the pc via data cable. open the pc suite & in the pc suite window you will get an icon "widget" in bottom left of the window. click on it, a small window will open in which there will be an internet connector icon. click on the icon. a dialog box will open, click on a icon on the right bottom of the box, select the service operator & insert ISP number. click on OK bottom. Then, on the left bottom of the box, an icon "connect" is there. click on it. then a dialog box will open, click yes. Dont unplug the data cable, let the process continue. Then, it will automatically connect to the internet.
Jan 13, 2011 | Samsung Computers & Internet
Just the internet light is flashing
If you are just setting up your connection your service provider may need to establish your IP address and/or Subnet Mask.
Also the signal or connection to your modem is not available due to your cable line not having a direct path back to the hookup at the house or a loose connection.
Hope that helps get things right. If you need more help just let me know.
Thanks
JHH
Nov 08, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I have gone to numerous forums and IT friends for support but to no available...nothing at all. My problem I would think not to diffucult but obviously it is. I have a Gateway 560GE running XP. Modem...
When you use USB for networking the "Network" it is on is 10.10.0.1 or similar, Now the Ethernet is 168.192.0.1 or similar. You simply MUST enter the correct address if you wish to change anything. Use the Connect to the Internet wizard and ensure you choose correct net, address. & if you have two Nic's Ethernet & USB, you must make sure you choose right one too.
Feb 07, 2010 | Toshiba Slim Port Replicator II
Belkin router is unable to connect to 2Wire ADSL modem/router. 2Wire router has DHCP server enabled and Belkin has DHCP server disabled. Belkin is set to obtain an IP automagically. 2Wire IP is...
If the Internet light is off then there is a problem with the phone line to the ADSL modem or the modem is faulty or there is a problem at the telephome exchange.
Disconnect the phone cable at the ADSL modem and connect a phone handset to this cable - check for a dial tone and that you can dial out.
If you don't get a dial tone, use a different or new phone cable.
If the phone line is OK then : -
Ring your ISP to get them to test your connection to your ADSL
modem.
Oct 17, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
How do we get wireless hookup to PC in rural area no cable or DSL
You will have to use a wireless cell phone type of modem. Some hi end cell phones like, blackberry's and some blackjack's have this capibility, to be used as a computer internet modem, see your local cell phone co. This service will be a bit expensive.
Aug 31, 2009 | Compaq Presario 5000 PC Desktop
How To: USB hookup for computer while having ethernet hookup to Xbox 360.
USB to PC is fine, make sure you have the original installation disk for it. Then you can connect the Xbox via network cable. There shouldn't be any problem as your modem can take 2 connections by the sound of it.
May 21, 2009 | Westell Wirespeed LiteLine 6100...
How to hookup dvr cable hd box to dvd player with surround sound
If you have HDMI on the dvr and the tv use this cable connection this will handle audio and the video at it`s best, if you do not have HDMI, use the 3 component video outputs to the tv and a digital audio connection from the dvr to the tv
Feb 01, 2009 | Audio Players & Recorders
HP Officejet 5610 All-In-One InkJet Printer Logo
94 people viewed this question
Seeker5211
Seeker5211
