Question about Acer Aspire 4520-5582 Notebook
Would someone please tell me if I have a battery problem or a fried suffocated Acer problem? My Acer 4520 was setup on a mattress bed then placed into hibernate mode after an hour. 20 minutes later I heard a strange PC tone. I was unable to turn the PC back on. I thought maybe the battery just got run down. I plugged in the Charger and got a yellow charging battery light. I hit the power button then all lights flashed and then turned off. After several tries I removed the battery and plugged in the charger again. The same result happens with all lights flash then turning off each time with no response from the PC. TIA, Ted
I don't think that it's hard disk problem either.
Check if you can at least access to Bios (turn the computer on & by pressing the F2 key when the system starts). If yes, it's not cpu or motherboard problem either.
from onceonli
Posted on Jul 18, 2010
    Problem Solver:
  • 5 Answers
Obviously it's not a battery problem. When you power on Acer, there's some running noise or not ? If there's such noise & just LCD has no sign of life, and you can't even access to Bios, it's just LCD cable connection problem. Often, LCD cable is disconnected from motherboard. It can ba happened very easily on shaking your laptop. It's possible that your hard disk is sick, then your Bios can't ditect its presence;
Posted on Jul 14, 2010
  • tlascellesr Jul 15, 2010
    There is no noice, no LCD only flash of electrical current on the Acer ligts then nothing. Is that a fried Hard Drive or fried CPU motherboard?
What are the things to consider before buying a baby crib for newborn?
There are various things to consider before buying a baby crib like type and style of the crib, design as well the safety. It is necessary for the parents to look the quality of materials and construction while buying the best baby crib. After that parents can buy a baby crib which provide more safety and comfort to newborn. If you are looking to buy quality baby crib and accessories at most discount rates then visit : http://www.baby-direct.com.au/
Feb 17, 2016 | The Baby Care
I have a Parsons metal ledge platform bed and I'm worried the mattress is not going to stay in place. What should I do?
I have the exact same bed and since the mattress sits right on top of the frame, I worried about this as well! Since you (no offense:) and the mattress weight a lot combined, I have you don't need to worry about it sliding off the frame. If for some reason it does move a bit, i suggest securing the mattress to the frame with velcro strips that can be purchased at any Ace or Home Depot.
Feb 16, 2014 | Furniture
What type of mattress is best to buy for a sofa-bed?
The best type of sofa bed mattress are:
1. Latex Mattress
2. Spring Mattress
3. Foam Mattress
4. Pillow Top Mattress, etc.
It is really a tough task to choose a mattress for a sofa bed. You can consider color combination and several factors of the mattress to buy the best one for you and your house.
Aug 16, 2012 | Furniture
What is the difference between a sofa-bed and a futon?
One of the major differences between these two items is the mattress. On a sofa-bed the mattress is attached to the frame; whereas on futons, the mattress is separate and needs something to be held in place. In regards to futons, the cushion is the mattress.
How to prolong the life of my mattress?
In order to prolong the life of your mattress you should try and keep the following.
1) Using a mattress pad or a protective cover will help you avoid stains.
2) Use a good and quality bed frame
3) Try to avoid jumping or standing on the edge of your mattress in order to eliminate bends
Jul 18, 2012 | Furniture
Hello..my acer aspire 4520 does not on if i press the power button..if i plug the power adapter the battery light blink continiously..can u please tell me wat is the problem..
just conncet the power cord and leave the laptop fro 10 -15 minutes and then try to on if it on well otherwise remove the battery and direclty switch on the laptop on main power.
Jan 20, 2010 | Acer Aspire 4520-5582 Notebook
My acer aspire won't power up
Try to connect your PC with the battery on the power outlet if it lights and charge normally. If the lights still orange, try to open the hard disk case and pull it out then try to put it in place again. If still doesn't go, try the memory card and clean it.
But I suspect that the battery has been overly charged. Try to look for another battery of the same model if it works with another and new battery.
Thanks
Nov 27, 2009 | Acer Aspire 4520-5582 Notebook
Acer 4520 Power up for 1 second and turns off
Can you hear the system fan running? If the fan fails, the PC shuts down itself to protect the processor from FRYING.
Apr 14, 2009 | Acer Aspire 4520-5582 Notebook
Acer aspire 4520 webcam
This is not your fault, if their sound and their video is messed up then it is either the audio quality or it is because of their camera/audio setup. Hope I Helped!
Jan 28, 2009 | Acer Aspire 4520-5582 Notebook
Changing from a crib to a toddler bed
1-Lower drop side to lower position. Then on the opposite side of the crib, remove stationary side. To remove stationary side, press the small tab on the end hardware(brown plastic piece that connects the rail to the frame) and then pull rail up.
2-Before reinstalling the conversion safety rail(csr), remove the mattress support bolt that is on the side the the csr opening will be(the foot of the bed). A new bolt will be used to reattach the mattress support in the next step.
3-Slide csr hardware onto the hardware on the crib ends. Insert two 1/4-20x2" bolts into each end. One bolt will replace the mattress support removed in step 2. Be sure to put the bolt back through the mattress support bracket before screwing into the end.
I have the instruction page with pictures if you would like a copy emailed.
jmsmith2003@msn.com
Sep 15, 2007 | Childesigns Carrollton Crib
Acer Aspire 4520-5582 Notebook Logo
144 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
