Question about Sanyo PLV-Z5 LCD Projector
I have a Sanyo Z5 and turned it on and it was really dim. I figured since the bulb had 2100 hours it needed a new one. I replaced it and same problem. The screen is so dim I can't use it. Any ideas? Thanks Joe
    Problem Solver:
  • 17 Answers
Ahhhhhhh it is the wall or the lighting in the area!!
Posted on Jul 15, 2010
I have a 42" Sanyo LCD that does not power up via light on front. I've replaced power board but still didn't fix it. Can you help?
Does anything turn on at all? Do you any indicator lights turn on? Does the screen turn on but is it really really dim?
Jun 30, 2016 | Sanyo Televison & Video
Epson Powerlite 50C too dim
The ballast module is bad. It controls the lamp. Don't throw away the original lamp. Once the ballast module is replace you'll have 2 good lamps.
Nov 18, 2013 | Sanyo PLC XU35 Multimedia Projector
The display projected is very faint. The lamp light is not blinking to indicate a problem. Is this an issue with the settings?
Check the bulb hours remaining through the menu. The bulb gets dimmer with age, so it could be close to life expectancy (2000 hrs regular, 3000 hrs Eco) and failing. The indicator light is based on hours only and will shut down the projector after (2100 or 3100 hours of bulb use), so it could still be the lamp failing or a power supply issue, especially if it's dim right from start up. Hope this helps.
Feb 08, 2011 | NEC VT695 LCD Projector
Sanyo PLV Z5 I changed bulb but it wont start up?
reset the lamp timer. if the fans won't start up either, you may have a power supply issue.
Dec 09, 2009 | Sanyo PLV-Z5 LCD Projector
I replaced the bulb in my projector and now it
You need to hold the help button on the remote control for ten seconds, that should reset the lamp hour. NEC decided to make it inoperable after 2100 hours on the bulb.
Nov 13, 2009 | NEC VT700 Projector
Rechargeable maglite won't turn on.
I found out the light bulb was bad even though it looked good. Had a fine break in the filament that I couldn't see with my eyes. Pulled the light bulb part way out, put a voltage meter on the two prongs. It showed I had voltage right up to the light bulb which told me the light bulb was bad. Ordered a new one and it works.
Dec 22, 2008 | MagLite - Mag Charger System 110v (M)...
Can you tell me why the optoma HD72I lamp will turn off after just a few minutes of running, the lamp is still fine
I have the same problem. I got a new bulb and it worked for about 1000 hours, then the new bulb started having the same problem. So, I was about to buy another bulb, and I figured why not try the original bulb. IT WORKED! For a couple weeks... Then it started doing it again. Obviously there was nothing wrong with the original bulb, and there is nothing wrong with the new bulb, but I have 2 bulbs that do it now. So, is there any way to just tell the projector run the bulb till it actually dies and not turn it off because it thinks it is about to die.
Aug 01, 2008 | Optoma HD72 Multimedia Projector
Image goes Dim
Hi there
Keep in mind that the light will only flicker if the bulb reaches a certain amount of hours or if it is damaged completely.
Try taking out the lamp and check on the inside of the shaft if you see any black vein looking marks on it or if there is a bubble at the bottom of the shaft - this normally causes the lamp to be very dim and will need replacement.
Mar 18, 2008 | Sanyo PLC XU35 Multimedia Projector
PLV-Z1 no longer powering up - Ready light is green and the Lamp light is red
I have a Sanyo XU35. Mine was starting up and showed a picture for about 15 - 30 seconds then shutting down. My lamp warning light was not coming on. When I put it in for repairs it turned out to be the lamp that needed replacing. The technician said it is not uncomman for the lamp to be gone and the lamp warning light not to come on. I got my lamp on e-bay from ping_ngo for a great price.
Aug 11, 2007 | Sanyo PLV Z1 Multimedia Projector
Sanyo PLV-Z5 LCD Projector Logo
167 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
