Question about Konica Minolta magicolor 5430 DL Laser Printer
Scratch on hot roller
If I have a scratch on the hot roller, is there anything I can do to repair it or do I need a technician to fix it?
  • 589 Answers
No, there is no way to repair the roller. It has a teflon / silicone coating (similar to a frying pan), and must be replaced.
The fuser unit (has the upper roller, lower roller, and other parts) is usually replaced as an assembly. I'm not sure on that particular model, but it may be user replacable.
Posted on Apr 20, 2008
We get irregular blue bands from side to side of the page, about 30mm depth. Would changing the drum cure this? Any other suggestions?
if the bands are occurring at regular intervals down the page it usualy means that there is a scratch in the drum, a visual inspection will tell you.if there is a scratch then it needs to be replaced if not then inspect the fuser roller for a scratch. the same remedy applies.
replace the fuser roller.
Apr 15, 2016 | Office Equipment & Supplies
Engraved / carved markings or scratch in laminating roller
probably will be best to junk it and get another one as the cost to repair will probably exceed the new cost.
Jul 06, 2014 | Office Equipment & Supplies
I met with small accident and my scooty pep has scratch..thus how can fix scratch..
The fix depends on how deep the scratch is, and how high quality you want the result.. If it's light, use rubbing compound and a fresh coat of wax. If it's through the color coat, down to the primer or metal, you need to mask the repair area, sand until smooth, reprime, paint,and clear coat.
Nov 01, 2013 | 2011 TVS Scooty Pep Plus
Scratch on the front panel, how do we repair. Does it have to be replaced?
Scratches aren't an easy or inexpensive fix. However, if, like most appliances, your's has a protective clear coat on it, you can try using a small applicator (like a Q-tip swab, etc.) and a very, very light amount of clear lacquer and lightly dab it onto the scratch and quickly wipe off the excess with a clean, lint free, cloth.
You can buy a can of clear aerosol lacquer that closely matches the type of finish on the fidge panels, (matte, satin, gloss).
The trick is to NOT spray directly onto the panels, but rather spray a small amount into the cap of the aerosol and using the swap, dip it into the liquid and, again, dab it lightly onto the scratch.
Another option is to purchase one of those automotive scratch repair kits that you see advertised on TV or in auto parts stores and follow the directions for fixing the scratch.
If you take your time and go lightly and carefully with the application, you can get a pretty decent repair that will make the scratch all but disappear. If it's also dented, then you've got another issue to deal with, but in any event, attempting a repair of the scratch will cost you hundreds of dollars less than buying a replacement door panel.
I hope you find this Very Helpful and best regards!
Oct 14, 2009 | KitchenAid KSSC36FMS Side by Side...
How do I fix a deep scratch on the screen, it is a wide scratch,maybe like a small toothpik size, when black background is on, it shows as a white scratch, I have tried vasoline, but it does not fill in...
Unfortunately there isn't anything you can do. The LCD surface itself has been physically damaged and no longer works properly. This isn't simply a scratch. The only solution is to replace the display panel, and they are nearly impossible to find unless you are an authorized servicer working on a warranty repair. There are companies that sell parts removed from sets, but most sets are junked because of bad displays. Since the display is the single most expensive part, if you can find one it may not cost much more just to replace the TV. There's always a sale going on somewhere, and many online vendors as well.
Jun 10, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Scratched Xbox 360 motherboard
Im sorry but this is the equivelant of a car being written off. It cant be fixed, simple as that. If it is possible to be fixed, it would work out cheaper to just buy a new one
May 20, 2009 | Microsoft Xbox 360 Console
Cost to fix scratch
take some tooth paste and rub the scratch , many time this will repair if it's not too deep .
Feb 12, 2009 | 2004 Ford Explorer
The disc is unreadable
Is it just dusty, or are there scratches?
If it is just dust, clean is with something soft- t-shirts work quite well ni the abscence of anything else.Make sure to clean from the middle to the edges in lines, not circles.
For small scratches, a sometimes very useful solution is toothpaste.Put some toothpaste by the scratch and rub it it, then wash of excess toothpaste and dry the disc.The toothpaste fills in the scratch, leading to a temporary fix.
May 16, 2008 | Video Game Consoles & Games
Help
hi im jules_09,check the fuser unit paper are folded because the rubber roller is worn out then the black line is also cause by scratch or damage upper or hot roller in the fuser unit.if the hot roller or uuper roller is fine check the drum unit if the opc drum is damage or scratch then check also the drum cleaning blade or roller,blak line in copy indicate one or two part either in the fuser unit or drum unit is damage.
Nov 15, 2007 | Panasonic FP-7735 Black and White Copier
Konica Minolta magicolor 5430 DL Laser Printer Logo
109 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
