Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
No Power No lights on panel - just completely stopped. The breaker is good, and that's as far as I got.
    President:
  • 228 Answers
Its the main board i have the same problem. i replaced the digital board and still have the same problem i metered all the other devices. they are okay. the only thing left is the main board. it's cheaper to try to buy it on the internet. localy it's about 200 dollars for me. good luck!
Posted on Jul 25, 2010
  • ruben sanchez
    ruben sanchez Jun 25, 2011
    I bought the main board locally for about 200 dollars but it came with a lifetime gaurantee.
    it's an upgraded version from the original.
Perfectly working unit, now completely dead...power supply 220 v to circut pane is good
Is there an external outdoor isolator?
Make sure power going through switch as required( put volt meter on neutral and power cable to test not the earth and power) this can also be checked at terminals at outdoor unit, a missing neutral will cause power failure but will not trip the breaker,
Dec 20, 2015 | Heating & Cooling
Electric is off in 2 rooms but no sign of braker off.
Push breaker fully off and then back on.
What have you tried so far?
http://waterheatertimer.org/Troubleshoot-household-electricity.html
What kind of breaker?
Are all outlets off on same breaker, or just some of them?
Gene
g
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 24, 2013 | General Electric 20 Amp, 1 Pole Thick Type...
Why do i get power at the 120v outlet but nothing works when its plugged into the outlet
It sounds like a bad neutral wire. Somewhere the neutral is not properly connected. Most residential wiring operates on a 240 single phase system comprised of two seperate 120 volt legs. Connect between either leg to the neutral gives you 120 volts.connect btween the two legs gives you 240 volts. If the neutral is not present the circuit will search out the other leg to try to complete the circuit causing dimming of lights extremely bright lights and all around chaos. Check ahead of the main to see that the voltage is correct. Check each leg to neutral with a voltage tester. Have some one turn some lights on and off while checking as sometimes a load is required to get fluctuating readings. If the reading fluctuate wildly the problem is between the power grid and the panel. If not recheck on a a couple of breakers and if the readings fluctuate it is on your side of the system.
. Hope this helps
. Bob
Nov 21, 2011 | CUTLER HAMMER BR4040B200V BREAKER CIRCUIT...
Drivers side window goes down 6" and stops. how do i remove the door panel to get access to the window mechanism to see what's stopping it?
The circuit breaker that is built in to the power window motor is weak and keeps cutting out.
When the window stops after a couple minutes it will move a bit again. That would be a faulty power window motor. You have to remove the complete window regulator system to change the motor.
There are 2 screws in the armrest by the door handle and plastic clips all around the door panel.
There is a hidden screw in behind the light at the back of the door panel if it has one.
Sep 12, 2010 | 1995 GMC Yukon
Power windows stopped working
If ALL the windows quit working, then it's either a bad circuit breaker or a short circuit. There are two fuse/relay/breaker panels: under the hood and under the back seat cushion. The power window circuit breaker is under the back seat cushion, near the battery. Remove the back seat completely, then remove the fuse panel top and inner cover. The fuse diagram is inside the top cover. Circuit breaker # 57 is the one. Pull it out. Use your voltmeter/multi-tester to check for continuity through the breaker. If there's no continuity, the breaker is bad and needs to be replaced. If it's good, then you have a dead short somewhere that causes the self-resetting breaker to uncouple when you attempt to operate a window. If so, the short will need to be traced down and repaired. Good luck.
Jun 27, 2010 | 2000 Buick LeSabre
Our inverter microwave stopped completely and now has no power!
Amanda, If yours is newer construction (less than 40 years) the microwave is likely to have it's own circuit breaker in the electrical panel (in the garage or basement?) so no other lights or outlets might have gone out. I have never seen a microwave that had it's own user-replaceable fuse or circuit breaker.
Feb 10, 2010 | Panasonic MCM INVERTER
Sanyo DP5747 Plasma TV no power
Found 1 of the 2 ac supply ( 8amp) fuses blown on the main pwr. supply. Replaced fuse and good so far. Looked over the ps for damaged components, none found. Checked current with ampmeter with tv on, showing 3amps. Cheers
Jan 03, 2010 | Sanyo Televison & Video
My protron pltv3250 stopped working
The power supply in the pltv3250 is a known bad problem, and thankfully replacements are easy to find on ebay or other internet sellers. Symptoms are usually a red light or no power light and completely unresponsive to the touch panel or a remote. I was able to find one at Power-On.com for $59.00 plus shipping, far cheaper than others on ebay. Their part code is lcd 194-3f (194W LCD power supply). It takes approximately 30 minutes to replace, from removal of the base to re-installation of the base.
Sep 27, 2009 | Protron PLTV-32 Television
I have a Kitchenaid Dishwasher about 5 years old. It has completely stopped working no lights power nothing. Water standing in the bottom. We have flipped the breaker but it doesn't seem to be an...
Removed power line from panel board # 11 as seen in appliance parts pros and shocked the board. It came to life and completed a cycle nominally. Then it died again. Tried to shock it again and sometimes it works but most times it doesn/t. Similar posts indicate a transistor failure in the board assembly. The board is easy to replace and costs about 90$. I'm replacing mine. Turn off power. Remove #15 torx screws (6) from the upper cover and lean panel forward. Remove board power . Diagram where connectors go back. Board is held in with 6 clips. Gently push clips open on one side and tilt board to remove board and ribbon cable. Reverse installation.
Sep 01, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
The fridge has completely stopped. There seems to be no power. Is this maybe a fuse thing?
hope your food isn t spoiled ,first of all grab a lamp and plug it into the same socket and if it doesn t light check your breaker second if you know which outlet does work get an extension cord and run that over to fridge and plug it in and see what happens could also be a breaker be careful electricity if the fridge starts your doin good
if not bad fridge sorrry
Aug 10, 2009 | Fisher and Paykel Refrigerators
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
286 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
