Question about Fujitronic FA-1300 Air Conditioner
Leaking water from the bottom - Fujitronic FA-1300 Air Conditioner
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 04, 2010
Why does my samsung fridge leak water under the fridge when I use my water dispensor?
hi Todd.
Problem: It's leaking water. ... Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leakingout of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself - CNET
https://www.cnet.com/.../three-common-refrigerator-problems-you-can-easily-fix-yourse...
Why is my refrigerator leaking water from the bottom?If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.17 May 2013SOLVED: Water leak in refrigerator? - Refrigerator - iFixithttps://www.ifixit.com/Answers/View/128713/Water+leak+in+refrigeratorSearch for: Why is my refrigerator leaking water from the bottom?
Why does samsung fridge leak water under the fridge Google Search
Nov 27, 2017 | Samsung Refrigerators
Why is water leaking from back of kenmore elite refrigerator?
Also, can be a crack on the plastic hose, close to the inlet water valve.
Aug 16, 2014 | Kenmore Refrigerators
Water leak from the bottom of washer
Hi friend, thank you for your post!
I understand that water is leaking from the bottom of your Frigidaire washer. There are many components that could cause a washer to leak the bellow (gasket), leak from drain hose, drain pump, or water valve. Since it could be any one of these underlying issues I would recommend having a technician come out to diagnose and repair your appliance. Hope this is helpful. -Matt
Jul 30, 2014 | Frigidaire Washing Machines
Water leaks at bottom of fridge
The same thing happened to me then I noticed ice had formed at the bottom of our fridge. It was covering a drain hole so water was leaking out the front of fridge instead of going to the drain pan or wherever the hole goes. After I chipped out the ice and cleared the hole with warm water the leak stopped. I also fixed another leak coming from bottom of fridge caused by a loose brass connection on water line going to the door.
May 25, 2014 | Hotpoint HSS25GFP Side by Side...
My bradford white 50 gallon hot water heater Model # M250S6DDs NCWW Serial # E610822231 D/N
Depends on source of leak: If gas water heater is leaking from bottom, then heater must be replaced.
http://waterheatertimer.org/Leaking-water-heater.html
http://waterheatertimer.org/How-to-install-water-heater.html
Add a comment and describe type of water heater, and what you discover about source of leak.
May 25, 2013 | Water Heaters
WATER HEATER LEAKING
1) Copy following link for troubleshoot walk thru
2) Electric water heater might be leaking from element, and water appears at bottom of tank:
Feb 12, 2013 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water coming out of the bottom of the machine
Sometimes, what may seem like a washing machine leaking from bottom locations is actually one that leaks slowly from other spots. Slow leaks can accumulate beneath your washing machine making it seem like you have a bottom leak. For more help identifying the exact point of the leak, see Washing machine leaking.
Bottom leaks may be better identified using a newspaper. Just dry the floor and lay the newspaper beneath the washing machine before you test for leaks. Darkened sections map out your water leak. This method is not always foolproof, however. The best diagnosis will come from a qualified service professional inspecting your machine.
If your washing machine is leaking from bottom in the rear, you may need a replacement pump and professional installation. The leak could also be caused by a faulty air dome seal or a hole in the tub. For more troubleshooting steps to tackle that leak, see Washing machine leaking from bottom. I hope that helps!
Sep 27, 2012 | KitchenAid KHWS01PMT Front Load Washer
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Coffee maker leaking from bottom
I have had a few of these machines leak.
I pulled off the bottom and found Mr Coffee is using low quality tubing that melts or leaks where it attaches to the heater element that boils the water. I replaced the tubes with higher quality silicone tubing that I bought directly out of China on Ebay and the problem was solved.
Dec 26, 2008 | DeLonghi Caffe Nabucco BCO70...
Fujitronic FA-1300 Air Conditioner Logo
93 people viewed this question
Top Fujitronic Heating & Cooling Experts
Bill Long
Jay Finke
Jay Finke
Are you a Fujitronic Heating and Cooling Expert? Answer questions, earn points and help others
