Question about Microsoft Windows Vista Home Premium Edition for PC
IE stops working intermittently and and advice that website cannot be found, I've had this problem for awhile and is a nuisance because when it goes down it takes everything with it
  • 428 Answers
It happens when your network connection goes down. Please make sure that you have a reliable Internet connection. Please install Chrome or Firefox and check whether it happens with these browsers as well. If so it is a connection failure. Contact your Internet Service Provider.
If you are unable to check using browsers, please do the following.
  1. Click on Start menu.
  2. Type Run in the Search Box or if available on the menu Click on it.
  3. Type in cmd.exe and press enter (do this at the very moment that your Browser shows that message.
  4. On the Command Prompt type this command and press enter.
  5. ping www.google.com
  6. If there is a reply (in the form of Reply from 64.233.181.106 ...) your Browser has a problem.
  7. If you get Request Timeouts, your connection has dropped or has a very weak Signal Strength.
  8. If you see any other message like "Unable to connect ...", that means your Internet Connection is down.
  9. You have to contact your ISP for the last two issues.
Feel free to contact again.Don't forget to rate the answer Have a good day!
Thanks for contacting Fixya!
Posted on Jul 15, 2010
I found a fuse F4 250V. T1.6A blown. After replace it and turn on the power, my control panel, PSC box and motor doesn't have any power.
Mostly a fuse doesn't fail without a good reason. Sometimes the fault is intermittent and replacing the fuse makes the machine or device work again for a long or short time though it is almost a forlorn hope.
Best practice is to thoroughly check and discover the cause of a failed fuse before replacing it a second time (there usually is a second time).
In your case the reason the fuse failed was probably something else failing in a quite permanent way rather than an intermittent way. It is a nuisance but at least a permanent fault is easier to find than an intermittent one.
The wiring and internal circuitry will need systematic checking both visually and electrically.
Mar 28, 2016 | Sewing Machines
How to turn my sony tv back on
You are experiencing intermittent power supply failure
May 05, 2013 | Sony BRAVIA Televison & Video
HVAC Fan Blower Problem
sounds like the blower motor needs to be replaced.
Sep 05, 2012 | 2001 Lincoln Town Car
I have a Finepix xp50, with a fully charged, correctly installed battery, that won't turn on. It worked intermittantly for awhile. We have 3 batteries for this camera thinking it was the battery
Be sure your battery is in the right way. Try reversing it. My battery has 3 rounded corners and one square corner. The square corner goes against the latch.
Aug 21, 2012 | Fuji Finepix F50FD Digital Camera
Keyboard has major delays
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below..
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Aug 10, 2012 | HEWLETT-PACKARD Compaq Mini 110-1034NR...
My 04 trailblazer intermittently sounds like it is running over a rumble strip, then it stops after applying brakes a few times
What would a "rumble strip" sound like? Squeaking, metal clanking against metal? Trailblazers have lots of noises that are a nuisance, and I've fixed most of them.
May 09, 2011 | 2004 Chevrolet TrailBlazer
Both power window on my APV work intermittent. Goes about half inch and stops wait awhile and the same thing. Would disassembly and lube help?
No, it is the internal circuit breaker in the window motor that is the problem. You need a new window motor.
Aug 17, 2009 | 1992 Chevrolet Lumina APV
I have a GE 31 inch TV. Intermittently, it will
most likely buttons on front panel are going bad.
Aug 11, 2009 | Televison & Video
Acer n30 Screen Tap Freeze
Sounds as if the touch screen membrane is defective, which is a darned nuisance, but not impossible to fix .... if you are confident of dismantling the n30, you can buy a new touch screen membrane from Ebay for about 4 pounds/6 dollars.
It is a very skilful job to remove the old touch membrane from the actual display screen below it, not really for a novice, and all internal components are very delicate, so i suggest you find a tame technician before you buy the new membrane. The touch membrane connects to the motherboard via a tiny flexible 4 or 5 pin membrane ribbon cable, it's a miracle of miniature engineering inside the n30, so do ve very careful if you decide to do it yourself, best of luck!
Nov 22, 2008 | Acer n30 Pocket PC
RCA RCR311B Remote Control
if It is similar to most RCA universal remotes, to get the code follow these steps(Manual code search MAy take awhile):
1:Manualy turn on the component that u want to control
2: press and hold the component key (ie TV) while holding TV press ON-OFF key(button) for three seconds until all of the components light up and release the keys(button).
3: keep pressing ON-OFF key until your component turns off.(Note may take awhile)
4: one the correct code is found hit the STOP key and it will save your component IF YOU DO NOT HIT THE STOP KEY THE CORRECT CODE WILL NOT BE STORED.
Hope this works
Oct 26, 2008 | RCA 3-Device Universal Remote
Microsoft Windows Vista Home Premium Edition for PC Logo
57 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
