Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
My oven is reading f0 - Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
    President:
  • 1,891 Answers
F O CODE / DEPENDING ON WHAT WHIRLPOOL MODEL THE PROBLEM CAN CHANGE . F O analog to digital failure/ disconnect for 30 sec .. if display reappears . replace the control .. other models it states a failed transistor . also replace the electronic rane control/clock.. . hope this helped mm
Posted on Jul 15, 2010
Double wall oven F0 error code
The F0 error code means that the control board has detected a defect within the control board itself, the F0 code can be cleared by pushing the CANCEL/OFF button and if it goes away and returns all is well,however if a short time later the F0 returns the control board would need to be replaced.
GENE
Oct 04, 2011 | GE Profile 30" Built-In Double Electric...
A code appears on my Dacor oven/stove that reads FO, what does it mean?
Hi bevtrust,
The error code that appears on your Dacor oven is about a stuck function key which refers to F0 error code. To fix this problem, you need to replace the oven's touch pad. If the touch pad is part of the clock, you need to replace the clock or ERC.
Hope it helps.
Thank you for using FixYa.
Nov 16, 2010 | Dacor Epicure EO127 Stainless Steel Dual...
Error code - F0
F0 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Sep 14, 2010 | GE Profile JTP56 Electric Double Oven
GE Profile Performance Spectra Range error code F0
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jun 20, 2009 | GE JKS05 Electric Single Oven
F0 fault code
Hi ,
F0 is Function key faulty.
Replace touch pad or clock assembly (also called the ERC)
You can find parts online at partselect.com , or appliancespartspro .
May 29, 2009 | Jenn-Air Ovens
F0 error code on GE wall oven
I had the same FO error. It turned out that the ribbon cable from the front panel was not making good contact where it mated with the circuit board. Remove ribbon cable and clean contacts on ribbon cable. Replace cable and problem should resolve.
Oct 13, 2008 | Ovens
326B1230P001 GE TrueTemp Black Oven Error Code F0
We had the same problem with our GE Tru Temp Oven and the fix worked like a charm! Thank you for posting this fix - you saved our dinner party!
Jun 21, 2008 | GE JKS05 Electric Single Oven
Double Oven says "F0" and beeps continuously
The fault code "F0" is indicating a possible stuck or shorted key pad or oven control board failure.
Determine if the problem is with the key panel or the oven control board by:
1. Pushing Clear/Off pad.
2. Disconnecting the Ribbon Cable Connector from the control board and waiting at least 32 seconds to see if the Code recurs.
If the code recurs, problem is in the control. Replace control.
If the code does not recur the problem is the Key panel and it would need replaced.
This test is normally done by an experienced service technician to avoid any possibility of getting shocked. This has to be done with voltage applied to the wall oven. Extreme caution should be exercised while testing.
I recommend calling a service technician to diagnose and repair your oven.
Jun 13, 2008 | Kenmore 47732 / 47734 / 47739 Electric...
GE Profile Performance Double Oven
I was getting only the F0 error code. The wiring diagram inside the stove said F0 indicated a bad off button on the keypanel. There were instructions to check the ribbon cable on certain lines, with values for the resistance. It seemed to check out, so I ordered a replacement and voila, it worked.
Jun 11, 2008 | GE Profile JTP56 Electric Double Oven
F0 error - My GE Over displays an F0 error & constantly beeps
Appu, the F0 error for this built in means there is a shorted or stuck off key. Sometimes this can be resolved by removing the keypad ribbon cable from the board and cleaning the ends with an eraser. If that doesn't work, you want to find out whether its the board or keypad by ohming the ribbon cable, 3 to 4, probes on the conductor side...should read 125 to 1750 ohms while pressing the off key. Catriver..post back.
Apr 29, 2007 | GE Profile JK915 Electric Single Oven
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
149 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
