Question about HP Photosmart C4580 All-in-One - InkJet Printer
Will not print because the printer states that it has a paper jam and must be cleared. There is no paper jam and I have disconnected all connections to reset but it doesn't help.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 123 Answers
There must be a small piece of paper somewhere that got stuck. If you dont see anything close the printer and when you restart it hold down the on button or go button for 3 seconds this will reset the memoory and clear the jam. If this did not help please post to me and I will guide you further.
Please rate me 4 thumbs
Thank you
Posted on Jul 15, 2010
Xerox3124 jammed paper
Hi
Open and close the front cover.Turn the printer off and on.This automatically exits the paper from the printer.
You can also remove the stuck paper by gently pulling it out straight.
If there's no stuck paper,clear any print queues.
Disconnect the printer completely from power and then re-connect again.
Now try printing.
Mar 25, 2012 | Xerox Phaser 3124 Printer
Paper jam
Hi
Try turning the printer off and on.This is known to automatically push out the stuck paper.
Look through the paper paths and remove any obstructions/stuck papers.
Clear any print queues.
Disconnect the printer completely from power,wait for a while and then connect again.
Hope it helps.Thanks!
Mar 06, 2012 | Canon PIXMA MX860 All-In-One InkJet...
H p deskjet 3051a
Hi
Check through the paper path for any obstructions and manually remove them.
Check the cartridges and make sure nothing's trapped here [stuck papers].
Ensure there's no dry or damaged cartridges
Disconnect the printer from power and from the PC.
Connect again after a while.
Try printing now.
Feb 29, 2012 | HP Office Equipment & Supplies
HP photosmart all-in-one printer/scanner/copier b110A
Hi
Try disconnecting the printer completely from power and the PC.
Reboot the PC.
Connect everything again and try printing now.
Hope it helps.
Feb 22, 2012 | HP Office Equipment & Supplies
Canon MP198 error E3
Issue: ERROR LED: E, 3 Solution: Remove paper jam then press Black or Color button (MP150) If paper is jammed, remove the paper jam then press <Black> or <Color> to clear the error.If paper is jammed in the auto sheet feeder or paper output slot, paper will not feed through the printer. Please follow the instructions for Clearing paper jams from the auto sheet feeder (ASF) or paper output slot.If Credit Card sized or 4" x 6" paper is set in landscape orientation, it will jam. Please follow the instructions below for Clearing credit card-sized or 4" x 6" paper jammed inside the printer.Clearing credit card-sized or 4" x 6" paper jammed inside the printer:Power the printer off.Load the same paper type as the jammed paper in the portrait orientation. Power the printer on. (The printer feeds the paper, resulting in ejecting the jammed paper.) Load paper properly in the portrait orientation to resume printing.TOP Clearing paper jams from the auto sheet feeder (ASF) or paper output slot:Power the printer off.Pull out the paper gently.If torn paper remains within the printer, open the scanning unit (printer cover) to remove it.Caution: To prevent injury or damage to the unit avoid touching inner parts.Power the printer on and confirm that the Alarm lamp is off.Note: Any jammed paper that remains within the printer may be ejected automatically.Load paper properly to resume printing. Issue: ERROR LED: E, 3 Solution: 2 Press ON/OFF switch to reset the multifunction device Reset the device when it is not functioning properly.If the device is not functioning properly or to clear memory, reset it.Important: If resetting the printer's power does not clear the error or return the machine to a functioning state, it may be necessary to attempt a service reset. Click here for instructions to attempt a service reset.On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.Wait approximately ten seconds and then press the <ON/OFF> button again.Wait until the device has completed its cycling process before submitting another job request.Service Reset:On the operator panel, press and hold the <ON/OFF> button for one second to power off the printer. (The display will go blank.)Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.Confirm the printer is not on and then unplug the power cord from the back of the printer.If the power cord was disconnected (as stated in step 1) in order to shut off the printer, go to step 3.Press the <ON/OFF> button repeatedly five times.Re-connect the power cord.Press the <ON/OFF> button to power the printer back on.Wait until the device has completed its cycling process before submitting another job request.Important:This procedure will not resolve a physical hardware issue.For example, a paper clip is wedged between the paper feed rollers or gears; or, the scanner assembly is detached from the inside housing. This procedure will not resolve all service errors or LCD related anomalies.Service errors appear as four characters (a combination of alpha and numeric codes).
Oct 13, 2011 | Canon PIXMA MP150 All-In-One InkJet...
HP 6940 print head jammed.resume light flashing
Welcome to FixYa!
Usually print head/carriage jam is caused by paper jams or previously cleared out paper jams that left a small torn paper inside the printer.
Turn off the printer by pressing and releasing the power button.
After the printer turns off, press the power button to turn the printer on again.
The printer might go through a warm-up period of up to 2 minutes. Lights might flash and the print carriage might move. Wait until this warm-up period is complete. Then try to print a self-test page. If it is able to print, the issue is resolved. (See instructions at the end of this article on how to print a self-test page.)
If the printer does not turn off, clear any paper jam. Press the resume button on the printer front panel. If the paper jam does not clear, continue with this procedure.
Leave the printer turned on, disconnect the power cable from the printer, and then disconnect the USB cable from the back of the printer.
Push the two latch handles on the rear access door of the printer toward each other, and then remove the door. Please refer to the image below.
Remove any paper that is inside the printer by pulling the paper out from the back of the printer.
If the paper jam cannot be removed from the back of the printer, raise the printer cover, remove the paper jam from the front of the printer, and then lower the cover.
Remove the paper carefully. It is possible to damage the printer when removing paper from the front of the printer.
Reconnect only the power cable. If the printer does not automatically turn on, turn it on by pressing the power button.
Again, the printer might go through a warm-up period of up to 2 minutes. Lights might flash and the print carriage might move. Wait until this warm-up period is complete. Then try to print a self-test page. If it is able to print, the issue is resolve. (See instructions at the end of this article on how to print a self-test page.)
If the Power light is blinking and the print carriage is still in a stalled position, continue with this procedure.
With the printer turned on, open the printer cover. The print carriage might move into the access area automatically. Allow it to move to that position.
If the print carriage does not move automatically into the access area, turn off the printer by pressing the power button.
Disconnect the power cord from the back of the printer.
Looking in through either the ink cartridge access door or the output paper tray, make sure that no obstructions under or around the print carriage are blocking it from moving.
Make sure that the print carriage can move freely across the width of the printer by gently pushing the print carriage to the left and then to the right. Clear any obstructions.
Remove and reinstall the print cartridges. Make sure that it is properly installed back.
Close the printer cover and connect back the power cord.
Print a self-test page. If it is able to print, the issue is resolve. (See instructions at the end of this article on how to print a self-test page.)
To print a self-test page, make sure the printer is turned on. The USB cable of the printer to the computer must be disconnected to make sure that we are isolating the printer problem.
Press and hold the Print and Cancel button at the same time. Make sure that the printer is loaded with paper. The self-test page will like the image below.
Keep me posted of your developments.
Thank you for using FixYa.
Jas247
Mar 03, 2011 | HP Deskjet 6940 InkJet Printer
I have a problem. When I turn on my printer, the first symbol from top constantly blinks and it doesn't print anything. How can I solve this issue?
Welcome to FixYa!
If the first symbol on the top is constantly blinking as shown in the picture below, It means that a paper or a foreign object has jammed your printer.
Jam can occur in 3 areas. Please refer to the image below.
1. Internal Areas
2. Input Trays
3. The Output Bins
To clear the jam, turn the printer off and disconnect the power cord. Be careful not to tear the paper in case of a paper jam. If a small piece of paper remains in the printer, it could cause additional paper jam.
Let's clear out the Internal Areas first. Push the button to open the print-cartridge door, and then remove the print cartridge. To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper. Please refer to the image below.
If jammed paper is visible, grasp it with both hands and slowly pull it out of the printer. Please refer to the image below.
If no paper was jammed inside the print-cartridge door, open the Output Bin or the back door
of the printer. To avoid damaging the printer, do not attempt to clear a jam in the top output bin by pulling the paper straight out.
Again, if jammed paper is visible, grasp it with both hands and slowly pull it out of the printer.
If no paper or foreign object is visible, close the back door of the printer.
Next, let's take a look at the Input Tray. (We have already taken out the print cartridge.)
Lift the Tray 1 roller cover, grasp the jammed paper or foreign object, and slowly pull it out of the printer. Please refer to the image below.
If no jammed paper is or foreign object is visible, open Tray 2 and see if a paper is visible. Again remove it slowly with both hands. Please refer to the image below.
Close Tray 2.
If no jammed paper is visible in the second tray area, pull down the upper media guide (we have already taken out the print cartridge). With both hands, grasp the jammed paper and slowly pull it out of the printer. Please refer to the image below.
Close the upper media guide and return back the print cartridge. Please refer to the image below.
These steps should clear out any jams that you are experiencing.
Connect back the power cord again and turn on your printer. You should be able to print now.
Thanks for using FixYa. Keep me posted.
Jas247
Mar 03, 2011 | HP LaserJet Black-and-White Laser Printer
States paper jam when I go click to print?
That's happened to me before on my HP printer. Try opening the printer and checking for any paper that might be jammed. Look very carefully, if you find paper that's jammed, carefully remove it. Close the printer. If you have the option to hit OK to clear the jam on the printer, do so, and then try re-printing.
Mar 01, 2011 | HP Office Equipment & Supplies
Printer status states paper jam although there is
Have you check the rear side of your printer?
Try the below..maybe it will help...
Disconnect the USB cable or parallel cable from the rear of the product then turn off the printer. Turn the knob on the rear access door counter clockwise, and then pull the door out to remove it.Check if there is any paper there..
May 24, 2010 | HP DeskJet 5550 InkJet Printer
Paper jam - can't clear error message
Hello Nj,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Paper jams are was very common on HP printer model.
Here are few instructions on how to clear the paper jam on your printer.
How to Clear a Paper Jam on an HP Inkjet Printer 1. Disconnect the power cord from the back of the printer before you begin. With the power disconnected, you will protect yourself from being shocked. This is an important step when you are fixing any type of electronic device.
2. Move your printer so that you'll have access the back panel. Unhinge the back access panel of the printer.
3. Look for paper through the opened back panel. Remove any paper you find jammed.
4. Close the back access panel. Make sure that it latches into place and looks the same way it did before you opened it.
5. Open the front or top access panel. This is the panel you use to access ink cartridges. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer. Go back and do that now. Look for paper that may be jammed in this area of the printer.
6. Remove any paper you find jammed here. There will be resistance from the paper feeder, so pull slowly or the paper will rip and create a more serious problem.
7. Close the front access panel. Make sure that it latches back into place.
8. Plug the printer in and attempt to print again. If you can print successfully, you have removed the paper jam.
Hope this helps.
Aug 08, 2009 | HP Office Equipment & Supplies
Open Questions:
See all HP Photosmart C4580 All-in-One - InkJet Printer Questions
HP Photosmart C4580 All-in-One -  InkJet Printer Logo
108 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
