Question about Whirlpool GHW9100L Front Load Washer
MODEL # GHW9100LW1 CONTROL LOCK IS LIT UP AND WASHER WON'T DO ANYTHING
  • 5,911 Answers
The Control Lock is a safety feature that enables the consumer to lock the control panel to prevent children from manipulating the controls and accidentally starting the appliance.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
If this is a Whirlpool manufactured appliance (such as Kenmore Elite, Maytag Epic or Whirlpool Duet), the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem other than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance.
Posted on Jul 15, 2010
Lid Locks- Fills for 2 seconds and stops
see this causes and fix it. God bless you
Door or Lid Latch Assembly If the washer lid won't lock the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer door won't lock the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Main Control Board If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
Oct 11, 2012 | Maytag Bravos MTW6600T Top Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
Control lock is lit up and will not go to any
This happens often, pressing buttons, sometimes it can be easy to slide into control lock. I have this link that shows how to turn it off.
http://www.managemylife.com/mmh/questions/193855-how-do-i-disable-the-control-lock-on-my-duet-washer
Jul 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control locked on whirlpool ghw9100lw1
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 27, 2010 | Whirlpool GHW9100L Front Load Washer
The control panel on my Whirlpool Duet model # GHW9100LW1 reads control locked. How do I get out of this?
There is a control lock so noone can start the washer washer or change your settings after starting the washer. There is a subscript under one of the option buttons that says (usually not very dark or prominant) Control Lock Hold for 3 seconds. Hold this button in for 3 seconds, sometimes slightly longer and the control lock should turn off. Most are not aware of this feature because it is never used. If this does not solve your problem unplug the washer for about five minutes and try again, if problem still persists please repost.
Thank you
Please rate this post
Jan 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light on
Hold the noise control button in for 4-10 seconds.
Jul 21, 2008 | Whirlpool GHW9100L Front Load Washer
Whirlpool duet washing machine ghw9100lw1
To turn off "Control lock" : press and hold the "End of cycle signal" button for three seconds.
Nov 17, 2007 | Washing Machines
Ghw9100lw1
Try holding the End of Cycle Signal button for about 3 seconds and see what happens. Mine started working again.
Ok Yankee
Nov 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9100L Front Load Washer Logo
324 people viewed this question
Dan Webster
Dan Webster
Sal De
