Question about Landice Pro Sport Trainer Treadmill
Error reads no motor voltage and the belt will not run. Everything else checks out ok in the diagnostic review. Machine was purchased December 2007. Safety cord is attached. Speed indicator flashes when motor is rotated.
  • munsoro289 Jul 14, 2010
    The last solution provided was just a Landice trouble shooting quide that I already reviewed and was of zero help. I was hoping for more than I can read on line. When I ran the diagnostic it reported no motor voltage but if I turned the belt by hand/foot while running the diagnostic it reported no motor error.
  • munsoro289 Jul 15, 2010
    Just a confirmation of what I had already concluded but at least I know there is good reason to call a repairman
  • 2,926 Answers
The motor is most likely in need of replacement. But you can verify this by running these tests.
Test for a motor control failure. Typically if you have a failure, the treadmill will continue to turn on and operate normally until you try to input speed. If the treadmill operates on what we call a closed-loop system, it will give you some type of error message. If it operates on an open-loop system, the computer will run normally but the motor will not turn.
If you have a multimeter, you can test to make sure you have DC output from the controller spades. First make sure you have 120 VAC going in to the controller.T
The DC output spades should output DC voltage if the control is good.
The motor can be tested by using a simple DC cordless drill or lantern battery. MAKE SURE TO USE A DC POWER SOURCE…DO NOT USE AN AC POWER SOURCE OR YOU CAN RUIN THE MOTOR. We use an outside DC power supply in our shop or field. See our test topic on motor testing for info on how to test a DC motor.
Posted on Jul 15, 2010
  • 2 more comments
    Don't have a multi meter. Guess i will need to call a repair service as it appears to be a motor problem as you indicated. If I turn the belt by hand/foot the diagnostic shows no error for the motor voltage. Not sure if this means anything. What did you mean by "See our test topic on motor testing for info on how to test a DC motor." Where would I see this ? I was kind of hoping I was missing something simple.
  • GetMeOttaHere Jul 15, 2010
    Ok.....good luck to ya. No voltage...no motor.
    Nothing real simple, just voltage verification. I believe your motor is shot, which is not uncommon.
    Yes, you are correct in using a professional service for an electrical problem with this unit. Thanks for using Fixya.
  • 17,970 Answers
I dotn know if this doc is excalty for your model, but could be interesting that yoy check it: Landice_WebForms/HomeDiagnostics
Good luck.
Posted on Jul 14, 2010
    Already looked at this but not any help as I already have the diagnostic. The diagnostics of holding down menu etc do not apply to this machine.Probably because it shows a diagnostic that checks each component and the only problem showing is no motor voltage. If I turn the belt by hand/foot the diagnostic reports no problem so it would appear connections are good. The problem probably lies with the motor.
Error code 660 & 595
test the output control board motor, if there are NOT voltage for to input voltage terminal motor, the control board is faulty, replace.
2) If there are voltage terminal motor, the motor need to test, take out the belt, and try again if the motor RUN the problem is deck belt board, LubE IT. see my personal TIPS for motor.
Oct 15, 2013 | Nordic Track Nordictrack C2050 Treadmill...
Precor 933i belt error
Please read my personal TIPS for treadmills and test it.
However LUBE inmediately the deck belt, this happen because the lack of maintenance by 5 hours aprox, So the system protect itself for electronic system and shut down.
2) LUBE the rollers bearing too.
3) Test the main motor bearint, measure the input voltage motor, if there are the motor is faulty. Repair. see my personal TIPS
God bless you
Nov 15, 2012 | Precor Exercise & Fitness
Treadmill FN 10282 shows code E3
Try to RUN the software calibration for diagnostic, troubleshooting and fix it.
2( However LUBE the deck belt, very IMPORTANT
3) LUBE the rollers bearing too.
4) Test the input voltage motor, if there are the motor need repair, see my persona TIPS.
5) test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram
God bless you
Sep 20, 2012 | Proform Performance 400 Treadmill Exercise...
Starts randomly when left alone...also dangerously accelerates for no reason
1) RUN the software calibration for diagnose, troubleshooting, and fix it.
2) if you can NOT run the s. c. LUBE inmediately the deck belt, this happen because producte enough friction between deck vs deck belt, and shut down the machine, for protection electronic system
3= Lube the roller bearing.
4= Test input motor voltage
5= Test the output voltage board, if there are NOT for input voltage motor the board is faulty. see the block d.
God bless you
Jul 06, 2012 | Proform Exercise & Fitness
F43
Hi.
If you have Bosch, Baumatic, or any other machine built by Bosch, then F43 is a motor issue:
Error F43 : Motor fault: do an emergency drain through the drain access in the front bottom side (see manual). Open door and check ig the drum rotates free when spin by hand. Disconnect power before performing maintenance.
Regards.
Ginko
Sep 14, 2011 | Washing Machines
Treadmill stop then display an error speed
If the is a Next Gen unit need to enter Diagnostic menu by pressing and holding pause then press clear twice. Continue to hold pause until until read service menu. press any arrow up and select system test ,then press enter the display will begin to automatically scroll thru available options. press enter to access Main Motor Module the next window will be Speed Automatic.
Upon entering this test mode you will able to check the drive motor and motor control board. By using the the speed arrows you will be able see the actual speed if functioning if not it could possibly be the speed sensor or wire harness ( SIMPLE CONTINUITY CHECK WILL RULE IN OR OUT THE HARNESS ) and point the problem. Now if their is no belt movement then hit clear and proceed over to SPEED CONTROL ERRORS hit enter this test allows seeing the motor controller conditions that are being displayed on the motor controller display if any of these come up then the controller need s to repair or replaced:
Max Temperature, Maximum voltage, Fault Line 1 error, Static current trip and dynamic current trip ( this also can a running belt tension this can result in a cannot obtain speed error message ) hit clear to get out of diagnostic once you eliminated the problem. Good Luck!!!
May 21, 2010 | Life Fitness 9500HR Next Generation...
Husqvarna 936: This machine was purchased on
Write a letter to Husqvarna/Viking.
Mar 07, 2010 | Sewing Machines
My Whirlpool WED8300SW stop turning yesterday. Clothes got really hot. I ran the diagnostic and got the F26 error code (motor drive failure). It is just 1 year old (about 15 months actually). I am fairly...
The standard warranty on appliances is two years, contact Whirpool at (866) 698-2538 to check warranty status.
Regarding the motor, the motor is tested by energizing it directly, and reading volts from MCU (motor control unit) or timer control board.
Here diagrams and parts for your model.
Call Whirpool first.
Aug 04, 2009 | Whirlpool WED8300S Dryer
Maytag MAH21 - main motor won't run
Please check microswitch block door/ Best result change this microswitch on the new. If terminal is shot - longered on wire.
Rashid Moscow (arashid@yandex.ru)
Dec 19, 2007 | Maytag MAH21PDD Commercial Front-Load...
Needle won't move
Make sure the clutch motor is powering up. make sure voltage toggle switch is on 110v and not 220v. Also rotation set correctly. Independently, make sure the motor runs. With your hands and motor belt disengaged, attempt to turn the handwheel toward you. If it is moving, then make sure motor is running. It handwheel does not turn it could be the machine. Make sure the stitch length dial is set at 2 or 3 and not 0 or 5. That could be that problem as well.
Nov 03, 2007 | Yamata FY811 Mechanical Sewing Machine
Landice  Pro Sport Trainer Treadmill Logo
414 people viewed this question
Top Landice Exercise & Fitness Experts
Howard
Howard
lloyd cole
Sportsmith LLC
Sportsmith LLC
Are you a Landice Exercise and Fitnes Expert? Answer questions, earn points and help others
