Question about Audiovox Car Audio & Video
Lose signal and when signal comes back in, it changes the channel to channel 1 preview.
  • Audiovox Master
  • 17,129 Answers
Is it possible that you antennae if faulty. Please check if the insulatiion is weak or the antennae is shorting to ground. This can make the signals go bad and make the set hunting and go back to search mode .If the antennae is fine then the problem could be in the front end stage of the tuner. You will require an expert probe to look for signal weaking in this stage but if you can open the set and cean and solder the areas closer to the antennae output. hope this helps. Good day
Posted on Jul 20, 2010
Cant keep ipad2 connectd to netgear wnr1000 vs
Sounds like the Ipad is getting out of "readable" range of the WiFi signal. You might log into the router and change the channel to channel 1. If that does not work, try another channel. If no channels work, you will probably need a Wifi extender to get the signal upstairs and readable for the Ipad.
Jan 26, 2012 | NetGear WNR1000 Router
Dynex TV losing favorite channels
Try changing the batteries in your remote. If the batteries are weak they may not be sending strong enough signals to the TV thus sending different signals than you meant.
Jan 24, 2010 | Dynex DX-L19-10A LCD TV
I can only get the preview on channel 1. Trying
Do you have a paid subscription? If you don't, you'll only get CH 0, CH1 and CH247. Buy a subscription and leave it on ch1 to get it activated. IF you already have a subscription, leave it on channel 1, call XM radio and ask for a 'refresh' for your radio - after 1/2 hour you should have your paid channels back.
Dec 07, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
The Sky HD Box keeps losing the signal on every channel except terrestial 1, 2 3, 4 and 5. An error message comes up with 'no satellite signal being received' and codes 28 and 49 and to get the signal...
could be any of the following;
1 dish out of alignment (re-align dish),
2 faulty LNB (low noise block) on the dish (likely) replace
faulty box, even more likely
Oct 04, 2009 | Televison & Video
We had an xm radio installed in our 2010 prius after we bought it. It was ''satellite ready'' but needed the radio. We signed up for xm radio and tried to get the signal. The radio was tuned to channel...
go to who installed you sat radio have them pull the antenna and receck the the receiver number it sounds like you have the wrong reciever number even one digit off and it will never conect even tho you have preview and sat radio paired with an antenna will recieve preview
Jul 10, 2009 | 2009 Toyota Prius
Cannot keep all channels on tv
When you say you "lose" channels, you probably mean there's no signal there anymore but they are still in the channel memory. This is normal if you have a rotatable antenna. You need to mark the rotator (or just keep a chart nearby) with the heading for each channel.
If you mean you're losing channels from memory when rescanning after turning the antenna, the only solution I can offer is to record the channels found (and their signal levels) after scanning a direction. Then change directions and rescan. See what new channels have been found, what have been lost, or how signal level has changed on common channels. Then you can manually add whatever you need, and you'll know what direction is best for each. It's tedious, but you should only need to do it once.
Nov 24, 2008 | Insignia Digital-to-Analog Converter for...
Delphi roady home kit won't change channels
Solved my own problem! Press the Preset/Direct button located just above the 5and 6 on the bottom of the receiver. You should now have" Direct" displayed in the top left corner of the display.You are now good to go.
Oct 26, 2008 | Delphi Roady Xt Home Kit Sa1017611p1
Off air digital signal
What brand of tv is it ? You could have a bad tuner or a change in the voltage supply line feeding the tuner . What type of antenna do you have ? outdoor or rabbit ears ? Also does it retain the channel line up or does it clear them as well ?
Feb 27, 2008 | RCA HD52W66 Projection Television
Lose signal
While some loss is expected. You can change channels. 1-6-11 are the best for cutting signal loss because they do not overlap.. 2.4GHz device in operation, like a cordless phone or microwave oven can cause signal loss. Metal in walls, electrical devices and wires can also cause loss.
Jan 03, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
LG LCD HDTV 'NO SIGNAL'
To fix the problem, try turning off the TV and unplugging it from the outlet. Once unplugged, push the power button and hold it down for 1 minute. Then turn the TV back on and rescan for channels.
If the problem persists, contact LG customer service immediately as there is a problem with the memory card. The device is unable to retain scanned channels for immediate feedback.
All LG LCD automatically comes with a 1 year manufacturing warranty. You would have to provide proof of purchase to show when it was purchased. Hope this helps. The Guru
LG customer service: http://www.lg.com/us/support/index.jsp
Dec 07, 2007 | LG 42LC2D 42 in. LCD HDTV
Car Audio & Video Logo
70 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
