Question about Astoria Argenta AEP-2 Coffee Maker, Espresso Machine
I have a Astoria espresso machine Model AEP12N we have 208 Volts
Can I run machine on this voltage or do I get a booster to 230V
    President:
  • 1,618 Answers
The machine will use 200 -240 volts, if your voltage is lower than 200 then you will need a booster.
Posted on Jul 16, 2010
What amperage does my astoria machine require?
2GR 19.6 amps- 3GR 24.9 amps - 4GR 31.6 amps -->> This INFO From the site .........
http://prima-coffee.com/sites/default/files/astoria/automatic/plus-4-you.pdf
Rapallo - 18.2 amps
Gloria AL2 ...21.7 or 17.8 amps FOR 120 or 230 volts
If that is not the answer go tot he PRIMA-COFFEE site and dig in!
Aug 24, 2014 | Astoria Coffee Makers & Espresso Machines
Asotoria model aep12n - do I have to use a water softener?
You can use it without one but it would be best to install a water softener system like an everpure ql3 head with a 7S0 softener. That might run you about $200 installed.
Mar 31, 2014 | Astoria Argenta Coffee Makers & Espresso...
Can my 240 volt compressor run on 208 volts?
Being an Authorized Service Center for a couple air compressor companies I can tell you I have replaced several 240 volt motors because they were run on 208 volts. Not knowing what model you have or what motor is on it, yes your compressor will run on 208 volts but it is very ******* the motor. At startup, all voltages have a dropoff then come back up to their rated voltage. The dropoff is determined by the original voltage and length and guage of lines getting the power from your transformer to the compressor With 208 volts it typically drops to around 190 volts at startup then comes back up to 205 to 208 volts while running. The motor needs the full 240 volts when it restarts and there is already pressure in the tank If the motor's not marked, call the manufacturer and see if it's rated for up to 240 volts or only for 240 volts.
Feb 08, 2012 | Craftsman Air Tools & Compressors
I just need to know what my sp250 idlearc lincoln mig welder is single phase or three phase, my gurage has three phase running in how do i wire in ,if single phase
Hi:
Your Machine is single phase, and it could be a 208/230V or a 230/460/575V depending on the model. Check what kind of voltage do you have at your garage first, before attempting to do the following:
On a three phase wiring you will have 4 wires with the following colors; green, red, white and black. If you have 208/220/230 volts available at your garage you can connect the green, white and black wires, always green being the ground cable in the middle, black and white don't matter which side you screw them in.
Before attempting to connect a 480V to the machine check machine's plaque information in the front (or back) for real voltage, because this voltage can burn the PC board of you machine. The same color sequence applies to the 480V.
Good luck.
If this was useful to you, please vote.
Mar 19, 2011 | Welding Tools
Will not shut off.
Ok is that the correct model number and voltage? Do you have it connected to 208-277 volts? (230V at home) Is the dial turning? Do you have both on and off trippers installed on the dial (they are not the same). If all that is true be sure the two timer motor wires are on the same incomine L1 and L2 terminals so it will run
Jul 31, 2010 | Intermatic T104R 208-277Volt 40-amp Timer...
I have bought a used Astoria sae Espresso Machine and I need to know how to clean it - can you help?
You'll want to back flush the machine with espresso machine cleaning powder:
http://www.kaldi.com/cafe_supplies.htm and regenerate the water softener regularly.
May 21, 2010 | Astoria Argenta SAE-2 Espresso Machine
Need manual/schematics for espresso machine.
Your coffee supplier will be able to provide you with one.
www.kaldi.com
May 28, 2009 | Astoria Argenta SAE/JUN Espresso Machine
Voltage change from 120v to 230v
You bought a mashine for the Europen Market ....
Ask Mr. Obama to change the Power in you country to 230 V. The that mashine will work .......
Oct 05, 2008 | Miele CVA2660 Stainless Steel Coffee Maker
Astoria Argenta AEP-2 Coffee Maker, Espresso Machine Logo
130 people viewed this question
Top Astoria Coffee Makers & Espresso Machines Experts
Charles T Nevin
Charles T Nevin
J.D. Browning
J.D. Browning
obsteiner
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
