Question about HP Photosmart R607 Digital Camera
My R607 BMW camera doesn't turn on. I got fresh new battery in it newly charged but when I try to turn it on nothing happens. It's been sitting unused for probably 2 years or so but it worked then so not much could have happened to it since it has only sat in the drawer. Any ideas what might be wrong? There's no sound, no light, no nothing.
  • 72 Answers
You should reset the camera:
-Hold camera upside down -Open battery/card door -Remove card -Remove battery -Make sure A/C power is DISconnected -You should see a small hole above and to the right of the battery slot, insert a sharp object and press -Re-insert card and battery
If this does not work, try it again a few times, if still unresponsive, the camera may need to be serviced by HP.
Posted on Jul 15, 2010
Brand new Nikon 3100 with freshly charged battery will not turn on for the first time. When I install the battery and close the flap, a small green indicator light lights up, but that's it. On/Off...
Well you have 2 choices...don't go back to Best Buy because you don't want to and you'd rather live with a brand new camera that doesn't work or.....take it back!
Sep 04, 2011 | Nikon D3100 Digital Camera
Red "faulty battery" indicator with newly-charged Batteries
You can buy new batteries and buy the one it says to buy on the package.
Apr 09, 2010 | Canon Elura 100 Mini DV Digital Camcorder
My M753 doesn't seem to want to turn on. I have charged it,nothing. Any idea's what can be wrong.
Try the following: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 24, 2010 | Kodak Easyshare M753 Digital Camera
When trying to charge battery green light flickers for hours
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 09, 2010 | Kodak EasyShare V1073 Digital Camera
My Kodak easyshare M853 want charge.Itworked fine til I let it sit or a while now it want charge. Can you please help? I tried A NEW USB CABLE THE LIGHT FLASHES BUT ONLY FOR FEW SECONDS.I HAVE TRIED 2...
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 30, 2009 | Kodak Easyshare C813 Digital Camera
My P5100 will not turn on - no green light & lens is stuck in ''out'' position
If nothing happens with a fresh battery set, then nothing can be done. Some thing has to happen in order to be able to tell what is going on.
If there indeed nothing happening when a fresh battery set is in and the on button is pressed, that means the camera needs service or some serious repair. This could be something very simple inside such as a disconnected or loose cable. On the other hand, this can also mean that this camera is good for selling on a site such as Ebay as parts or a fixer.
There is a Nikon P5100. If it is a Nikon, then you may consider this link to call the Nikon co. and ask for either repair or a trade-off or trade up to a similar camera or better. Nikon does have a trade-in or trade-up program.
http://imaging.nikon.com/products/imaging/index.htm
Aug 31, 2009 | Cameras
I have a 1998 bmw 5 series and nothing works
Does all the dash lighs light up?
This happed to me in my 318i, car sat for 3 months and it turned out to be the starter moter seized up.
Aug 24, 2009 | 1990 BMW 5 Series
Won't Charge.
I just had this problem with my camera. all you need to do is get a new battery. But when you aren't using your camera take out the battery. If you don't, you will have this problem again.
Jan 29, 2009 | Casio Exilim EX-S880 Digital Camera
Weird problem. Camedia d-520 doesn't turn on. Blinks and Beeps.
I'm having the same problem with mine. Happens on rechargeables or brand new standard batteries as well. Very frustrating. I can't take more than 2 videos in a row without the dreaded orange/green lights flashing (low battery warning). Leaving it for 10-20 minutes and it works again, with the battery charge showing full.
Aug 14, 2006 | Olympus Camedia D-520 Zoom Digital Camera
Shutter lens won't go in
If I remember right it takes AA batteries. Correct? Perhaps one of your NiMH AA's is not charged properly. Try it again with two newly charged NiMH batteries. You might also try putting in two newly charged batteries and let it sit for 24 hours and then turn it on. Lastly you might try putting a little pressure on the lens when you turn the power on. I had to do this once with my Optio S4. Hope you can get it figured out.
Sep 08, 2005 | Pentax Optio S40 Digital Camera
HP Photosmart R607 Digital Camera Logo
124 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
