I'm having a booting problem with my asus K40IJ when I'm starting the unit it doesn't boot it only hang ing blue screen.. What maybe the cause and initial remedy i will do?
    Problem Solver:
  • 5 Answers
It's windows problem. Often windows is just corrupted. Run "Recovery Console", if you know how to do. If not, reinstall windows. For second case, you risk lose all data from the entire partition where your windows actually runs.
Take off your hard disk from laptop. Install windows on new hard drive. Make your actual sick disk as a secondary disk on using external box or connector. New windows can access to your sick disk without any problem.
Posted on Jul 15, 2010
My asus PC1005HA will not re boot after I upgraded BIOS
closed the unit down
now press the start button and hold down the delete button to get it to start in bios
check the boot sequence there
adjust as required and save
Aug 17, 2017 | ASUS Eee PC 1005HA-PU1X-BK Netbook
ASUS Eee PC 1001HA factory restore
start tapping f8 @ boot to see if you can get to boot menu, if it doesn't work then you'll have to get an external dvd player and boot from that to do a repair.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
May 12, 2012 | ASUS Eee PC 1001HA, ASU......
My asus k40ij series has crashed its system.. i inserted XP installer to cd ROM but it doesnt booth from cd.. can anyone help me...???
Check bottom of screen on boot-up
usually F2 or Del to enter setup
hange boot order to cd-rom first
Jun 25, 2011 | Computers & Internet
On start up only asus a8vx page comes up doesn't boot os and has green screen which hangs then goes back to asus motherboard page. can not even use safe mode bt f8 goes right back to motherboard page.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem hope this helps
May 24, 2011 | Computers & Internet
My laptop is on but the screen is blue and won't go to the desktop
A Mac that shows you a blank blue screen instead of logging you in may be afflicted by a malfunctioning startup item. Most people have a number of programs that start up whenever you log into your computer, and it's likely that one of these programs is causing issues. The startup item is unable to load, and so it causes the rest of the computer to hang.
In order to get your Mac past this hanging blue screen, you need to boot into safe mode and figure out which startup item is causing problems. The Apple Support article "I see a blank blue screen when I try to start up my computer" tells you exactly how to go about this procedure. Basically, you must remove all your startup items and add them back in one-by-one, rebooting each time until you find the one that causes the hanging blue screen.
Dec 28, 2010 | Computers & Internet
The computer is on, but the screen is all blue
Dec 28, 2010 | Apple MacBook Mac Notebook
Blue screen appears on start up and has no icons on screen cannot do anything does anyone know what this is
How many days you working in you laptop befor coming the blue screen? -- many days, 2 days. or 3 days, then comes blue screen?..
if the blue screen come few days working.. 1) check the programs anti virus.. maybe infected of virus or programs adware.. if yo always connected to the internet posseble happen this case.. or maybe you insert somthing in your system.. like usb flash, mmc. or any device.. be carefall sometime the computer making blue screen if some system error. even you didn't see error before... 2. try make restore system if can.. just go to Start, program., accessories, system tools then, system restor..
May 31, 2009 | Asus Eee Pc 701Sd Notebook
My Asus notebook series X52S is not booting up, it is turning on, and saying that there is a critical error and then requests whether i start windowns normally of start up in safe mode. I request safe...
There's a selection on that screen for "last known good configuration" - try that, sometimes a driver that has been recently installed can cause a machine to crash on boot. If that doesn't help, you can attempt to boot from the installation CD that came with the computer and repair the system. Boot from the install CD, select ENTER in order to continue with the setup program (trust me, we're not going to do a full setup, but you have to choose the first option here...). More files will load from the CD - the next screen should be the repair screen - it should say "To repair the selected Windows XP installation, press R" - press R, and the repair should begin. Reboot after it's done.
Please rate this answer if it's helped you out, thanks!!
May 08, 2009 | ASUS Computers & Internet
Building new computer with ASUS M2A motherboard and AMD 749 processor. Computer starts, displays ASUS setup screen, goes to blank screen with blinking cursor and then hangs up.
Try to check connections to hard drive...If OK..then check boot device priority in BIOS and change 1st boot device as Hard drive..Then If not worked then chnage 1st boot device as cd rom and boot from a bootable CD and installl OS..
Dec 09, 2008 | Computers & Internet
Computers & Internet Logo
214 people viewed this question
Alun Cox
David Payne
David Payne
