Question about LG Dryers
LG dryer DLE2516W keeps flashing check lint screen but screen and exhaust all the way to outside is clean.
That's just a reminder to clean the filter before every use.
Posted on Sep 04, 2010
No error code but if you push setting it and check lint screen flashes. I have checked lint screen all the way to vent outside. I can feel cool air from outside comming through lint screen so im sure it is...
That Kenmore dryer is a hybrid of a LG dryer that check filter lite is only a reminder for the customer to check their lint screen every load... You can call customer service at sears to confirm this. I have may customers call me and say it wasn't there before, I goto there house call customer service in the home, hand them the phone and collect a service call about 5 times a month. If every thing is drying well, just leave it alone.
Mar 26, 2015 | Dryers
LG DLG5988W
check your door interlocks and connections
Mar 15, 2008 | LG DLG5988 Gas Dryer
Dryer heats up and finishes cycle, but clothes still damp. It actually smells like something is burning. I already checked and redirected the hose, blew the pipe leading outside, cleaned the filter and...
check air flow were heat exhausts outside. good air flow? sounds like lint clogged. couuld be in dryer, in exhaust hose, id start with hose make sure clear and not kinked.
Mar 10, 2014 | LG DLE2532W Electric Dryer
My lg 2240 clean filter light blinks even though the filter is clean. when started it runs for 3 to 4 seconds then shuts off. if you wait for about a minute it will start again then shut off after 3 to 4...
This problem usually is caused by a restricted or blocked vent. The filter itself can be clean, but the duct work in the dryer after the filter, or the vent hose attached to the dryer, or the exhaust door attached to that hose is either restricted, plugged or blocked. Lint likes to build up in all areas the exhaust air goes, so check them all. The dryer has a sensor that will shut the dryer off if there is a restriction. Cleaning all of the duct work, from the filter all the way to where it exhausts outside, will usually solve this problem. An easy way to check is to unhook the exhaust hose from the dryer and run it. Does it keep running now? It is possible the sensor in the dryer has gone bad, but that is rare. 99% of the time it is lint build up in the venting.
Dec 12, 2013 | LG WM-2277HW Front Load Washer
When door is open its hot inside but clothes are still wet
sounds as if your exhaust/air exit/lint thorough fare may be plugged-blocked or building up thus holding moisture in unit, You may wish to use a shop vac hose hooked to exhaust side of vacumn to force air thru lint clean out after removing lint screen and/or also make sure dryer has not been forced back into the wall thus crimping exhaust chute and perhaps check outside to see if exhaust vent flapper chute is clear of obstruction and also opening as dryer runs, Good Luck and keep an eye out-fire hazard if dryer overheats and is actually a blocked exhaust, take care.
Jan 26, 2013 | Kenmore Elite Oasis 6809 Electric Dryer
What's your problem? Check filter light keeps flashing
SERVICE MANUAL
NOTE:
I have several manuals on hand and they all read the same
That could be the lint has a partial blockage in the outside vent and the vent thermal limit is tripped.
DRYER VIDEO
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 18, 2012 | LG Dryers
LG Tromm DLE8377NM check filter but filter is clean
You say lint hose is disconnected. Are you referring to the exhaust vent to the outside? I would suspect this vent is clogged or a vent flapper outside may be stuck shut.
Feb 14, 2012 | LG Dryers
Dryer keeps saying check filter - lint screen is clean-dryer won't run
Had the same problem. Filter was clean. Vacuumed out the area under the filter. Still had problem. Unplugged the dryer. Removed the hose vent (back of dryer) and checked the exhaust -- all clean. Plugged the dryer back in and was fine. Still going to check the vent to the outside for lint buildup.
Jan 17, 2011 | LG DLG2524 Gas Dryer
LG DL2610 model does not dry, it turns on properly
Check your vent. Make sure there is a strong flow of air out the outside vent cap. If not, your dryer is not able to get rid of the moisture. Check for lint build up inside vent piping and for crushed flex vent pipe behind dryer which would obstruct air flow.
Sep 16, 2009 | Dryers
I have a large capacity front load LG electric dryer. I keep getting the "check filter" message & the filters are clean. The dryer will not stay on. HELP!
The message does not only refer to filters, badly written.
There is an air flow restriction that the machine senses and is warning about.
check the fan and fan housing for lint that has got past the screens, then pull the dryer away from the wall and check the exhaust duct for lint, all the way to the wall
then check the outside wall vent for lint build up in the rodent screen
before clean
239f28d.jpg after clean
a605f7e.jpg no clean
Oct 10, 2008 | LG Dryers
Dryers Logo
369 people viewed this question
Top LG Dryers Experts
Mike
Mike
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
