Question about Samsung SyncMaster 940MW 19 in. LCD Television
Monitor Screen I have a LCD TV / Monitor, the screen is fine as a tv but i have switched on my pc to find that i have green stripes running down the screen like blinds and when i move my mouse it covers more of the screen. Please could anyone help me with this.
    Genius:
  • Samsung Master
  • 1,635 Answers
It may be that the scan rate is not matched. Check that the resolution and refresh rate from the computer is set to be in the exact native mode for the TV screen.
Jerry G.
Posted on Apr 20, 2008
Lg55lv4400-va 55" flatscreen tv has developed a wide flickering vertical flickering stripe down the screen. any Ideas ?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 03, 2014 | Televison & Video
Luxor 40 914 tvb
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 13, 2014 | Televison & Video
Toshiba sl738b
- Flickering screen
- Dim screen
- Slow start
?Check the cables, connectors and connections.
Apr 11, 2014 | Toshiba Televison & Video
My 32LD30UA LCD TV is 16 months old, when you switch TV on the picture has a band of reds and greens running down screen for about 30 minutes then returns to normal.Help?
My HITACH 32LD30UA LCD TV when you switch TV on the picture has a band of reds and greens running down screen for about 30 minutes then returns to normal.
Dec 12, 2010 | Hitachi 32LD8700 32 in. LCD Television
I have a "purple" stripe running verticaly down the left side of my screen in all modes (Cable via HDMI and VGA) It looks like the video is wrapping around, and I do not know how to adjust it.
Purple stripe of "LCD panel Death". In most cases when there is a color strip across or down the screen, means the lcd panel it's self is gone down. In this case, cheaper to buy new flat panel tv. In some of thses models you could have a back lite out, not likely, as when the lites oare out you don't have color on that side.
Oct 09, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Black stripe down TV plasma screen
if your TV is still under warranty, call Samsung to get it fix. I seen this problem and is quite expensive to repair
May 27, 2009 | Samsung LN-T4665F 46 in. LCD Television
Green vertical stripes down right hand side of screen, no picture
Unfortunately this means that your TV may be damaged. I would suggest talking to a professional or consider replacing your TV depending on the cost of fixing it.
What it means is that the power to that line of LCDs in your screen is 'stuck' and it is generally not user-serviceable.
Jan 23, 2009 | LG 19LG30 19 in. LCD HDTV
Dark Vertical Stripe on Right Edge of Screen
I experienced the same approx. 1/2" vertical stripe on a Viewsonic vx1945 and ATI Radeon x1050 video adapter on Vista Business SP1, but the stripe appeared along the left edge of the screen, instead of right edge. I then temporarily decreased the monitor resolution, and the stripe went away. I then increased the monitor resolution back to its original setting, and the stripe did not re-appear. So, that was the 'fix' in my situation, hope this helps.
Dec 11, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Samsung SyncMaster 940MW 19 in. LCD Television Logo
108 people viewed this question
cce772000
Level 1 Expert
