My wintair AC unit ap08ck1fds is leaking water from the front - i dont know why this is happening, as i dont have the manual but the 'water full' light is not on. help me!
5 Suggested Answers
crouchdash
  • 83 Answers
SOURCE: LG 18000 ac leaks water in the front of unit.
the drain pan is either clogged or the unit is not mounted properly. If the drain pan is clogged simply clean it and the problem goes away. In the case of the unit mounting, check the angle of the unit and the drain pan inside, if it tilted to the front even just a little then water would leak. the drain pan should lean toward the drain and away from the front.
I hope this helps.
Posted on Jun 05, 2009
SOURCE: leaking water from ptc ac unit in front .vents all open
make sure unit is has slight fall toward outside.
Posted on Jun 15, 2009
  • 4 Answers
SOURCE: My wintair portable ac is leaking from the bottom
same problem.....
Posted on Jul 24, 2010
SOURCE: lost manual for Wintair AP08CK1FDS Portable Airconditional
I have a Wintair portable air conditioner as I bought thru craigslist and it didnt come with a manual so I want to know how to use it.
Posted on Aug 31, 2010
Old Maytag portable AC leaking. an hwar water when I move , don't know how or where to drain
Make sure the drain line is not stopped up and that the drain pan is empty. The pan relay on the heat from code see to evaporate water and with a full pan that isn't going to happen. Drain line or pan full.
Jun 05, 2016 | Maytag Heating & Cooling
Whers does water evacuate from portable ac unit
there is a holding tank in the bottom of the unit, on the front right by the floor is a rubber cap that plugs this tank. water evaporates from there, if the tank gets too full, the power button will flash red and the unit will not turn on. put pan under, pull plug and drain if this happens. if it doesnt happen, don't worry about exhausting the water as its not a problem.
Jun 10, 2014 | Maytag Portable Air Conditioner M6P09S2A
Haier portable AC water collection tank full in one hour.
My unit was working fine for a couple years but now it won't evaporate. It still cools fine but it also collects about 16 ounces of water every hour and then shuts itself off until I drain it. I'm wondering it the evaporative mechanism it broken some how.
Jul 24, 2013 | Haier CPN12XH9 Portable Air Conditioner
When i run the ac it leaks on the floor from the inside n i dont know what to do about this problem.
All portable or window ac units are mounted or standing with the back lower housing at a slope
so that the condensed water buildup from the evaporator can drain into a tray or thru a tube out
the back of the unit, depending on what kind of unit you have you may have to take it apart and
make sure the drain for the condensed water is not blocked. some times these units are not
installed correctly, they will not drain properly and standing water with time will turn to rust and
clog up the tube where it needs to flow from the ac unit. good luck!
Jul 31, 2011 | Windchaser PACR10000 Portable Air...
I just purchased a used wintair room portable a/c unit, works good its 8000btu, it cools great, but i dont know how to work the buttons, and it has started leaking on my daughters carpet, do i need to...
There should be a plug on the rear of the unit near the bottom of the back. If the plug is missing/removed, it should have a barbed or threaded end for a drain hose to be installed. Place the drain hose (a typical garden hose will suffice) over the end of the barbed/threaded section and secure with a an automotive hose clamp. Some units did come with a "male" hose end in which the "female" end (what you would screw onto a outdoor faucet) garden hose can be directly threaded onto the drain connection. In either case, this drain needs to be leak proof to prevent additional water (condensate) from leaking onto the floor. The drain is ideal for situations where there is high humidity in which the A/C condenses the water vapor out of the air during A/C operation.
Feb 06, 2018 | Danby Portable Air Conditioner
Model: KFR-32GW/Ac Will not stop leaking water from the front of the unit. Coils have no ice. Shut off unit for 30 min the leaking stops but resumes when AC is turned back on.
Possible one of two problems. first make sure the unit is tilted away from the inside slightly. Second there are very small drains that let water flow from the front coil to the rear of the ac if the unit has been dirty it can plug these holes. You can find the holes by pulling the ac out or just remove it and use a hose to clean it. You can buy coil cleaner at a hardware store just follow the directions.
Aug 08, 2010 | Heating & Cooling
Lost manual for Wintair AP08CK1FDS Portable Airconditional
Aug 18, 2009 | Heating & Cooling
LG 18000 ac leaks water in the front of unit indoors.
I hope this helps.
Jun 05, 2009 | LG LS-K1830CL Cool Mini Split Air...
Sears CAlypso
dont see why not, first t hing to do is find out where its leaking from, the fromt panel will need to come off to watch for leak in order to remove that , pop off the medalion on fron lip of the main top assy. ther should be a screw behind the emblem remove the screrw and the top will slide foward and then tio back. a few screws across the top of front panel will drop that panel down adn from ther you ll gain acces to watch unit work adn see where water is coming from
Apr 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Heating & Cooling Logo
227 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
