Question about Sta Rite 1 Hp Sta - Rite Abg Swimming Pool Pump
Self Cleaning pool problems
I have a self cleaning pool and it seems the jet power is much lower than before. Because of this the pool is more dirty. Also my filters on the bottom do not seem to be working either. I have been cleaning my filter at least 2 times per month. Any suggestions on what I can do to make my pool clean more efficiently like before? Thanks for your help.
    New Friend:
I shork pool three days ago and still blue green what do I do I need the pool for tomorrow night
Posted on Aug 03, 2014
  • Missy Brown
    Missy Brown Aug 03, 2014
    lpease help me with my pool.i shrok it three days ago.I put 5bl in it and still bluesh green please help.what can i do
  • 83 Answers
SOURCE: Sta-Rite S7M120
The brown-green gunk sounds like algae. You stated that you have cleaned the filter. Have you taken the cartridge completely out? If not, I would suggest that you do so. Scrub the inside of the filter tank with a 4:1 bleach water mixture, only 1 part bleach. Then soak the cartridge in an acid bath, like Muriatic Acid. This will kill any algae that is in the filter itself.
You may need to vaccuum your pool to waste, get rid of some of the water and refill it. This may help get the chemicals in order.
Another idea would be to run the system continuously for a couple of days. Vaccuum to waste, not to return lines, and clean the filter when it reaches 8 to 10 PSI above start-up. You may not be running the pump long enough to properly filter water. Keep trying to get chemicals in order.
Posted on Jul 08, 2009
MOTORWIZJ
  • 1389 Answers
SOURCE: Pool pump inflow/outflow handles and their position?
GO TO YOUR LOCAL POOL STORE AND SEE IF THEY HAVE A SIMILAR UNIT . IF THE FLOW IS NOT GOOD YOU MAY NEED A NEW DIFFUSER $20... .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
  • 333 Answers
SOURCE: i have a hayward 1hp pool filter/pump with the low
have you cleaned the filter?
Posted on Jun 15, 2010
  • 8404 Answers
SOURCE: High Pressure: STARITE 1.5 hp pump designed to
It is a cartridge issue in my opinion. I dont recommend cartridges ... Sand is so much superior as a filter medial. If this is an option for you ... I recommend it. If not an option, you might be able to get a different type cartridge that will filter at a lower rate and not get as dirty as fast ...
Posted on Aug 04, 2010
mpcheeseman1
  • 1400 Answers
SOURCE: Pool pump has been working
Hello
Check the pump impeller by shuting off pump taking out strainer and putting your fingers in to get any debris out.
After you put strainer back in put a bucket of water in collection basket to prime pump.
Also check your o ring on the strainer lid.If its cracked or worn the pump will not prime,but continue to **** air.
Also be sure your in filter mode before starting the pump up.You may need to lossen strainer lid a little to bleed ot air until water starts to flow again.
Possible bad o ring on stainer or impeller on pump is bad.
You may want to try putting the filter in backwash or drain mode and blow out any air also.
Posted on Jun 16, 2011
If I used chemical cleaner and rinsed it out well - can I chance on self cleaning
I use easyoff oven cleaner all the time on our self cleaning oven , never had a problem.as I do not like self cleaning systems as they waste lots of electric . getting as hot as they do .
Aug 01, 2016 | Ovens
I have a self cleaning oven and when I want to use it, I heard a deafening noise. what does it mean, it seems that cleaning will not start
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 18, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Older westinghouse stove won't unlock after self cleaning. I have tried to turn off main power and reset but won't work. Thanks
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 24, 2010 | Microwave Ovens
I am trying to clean the lower oven of a double wall oven... GE True Temp self-cleaining. However it seems only the upper oven turns on to clean...will the lower oven kick in later on? There is a STD and...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 26, 2010 | GE JBP71 Electric Kitchen Range
Ran self cleaning oven now the door will not open and all the electric will not work.. thank you
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Oct 13, 2010 | KitchenAid KGST307 Gas Kitchen Range
Hi! I am trying to self clean the lower oven in my built in oven. Yesterday I did the top one with no problem. Today I started it & it seemed to go correctly but it has been making clicking noises. The...
heatman101
Aug 24, 2010 | Thermador SC302T Electric Double Oven
I have a Whirlpool electric build in oven with self-cleaning feature. It is about 8 years old and we just used the self-cleaning feature for the first time last week. The oven was not that dirty, but...
Your thermal fuse or TOD mounted to the back of the oven went out during the self clean,it shuts off the power to the elements.
 The oven must be removed from the wall to change this.
Aug 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Dirty self cleaning oven
easy off has a new spray for self cleaning ovens start with that after getting loose grime then self clean
Oct 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Stove top difficult to light
your gas jets are dirty.. clean them with a toothbrush (after everything is cooled down).. you can use the selfclean to clean the iron pieces that cover the burners..
be careful with kitchen aid self cleaning.. there is a known issue with the thermal fuses blowing quite easily on most self cleaning cycles..
good luck
tpug
Feb 21, 2008 | KitchenAid KGRI801PBS Gas Kitchen Range
Sta Rite 1 Hp Sta - Rite Abg Swimming Pool Pump Logo
206 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
